Pagina 3 di 5 primaprima 12345 ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 45
[ROM] [Z5S] [Android 7.1.1] LineageOS 14.1 unofficial
  1. #21
    Androidiano L'avatar di Maegorn
    Mar 2016
    Lecce
    Nubia z5s
    Ringraziato 39 volte in 32 Posts
    Quote Originariamente inviato da rop12770 Visualizza il messaggio
    Hi
    Thanks for the answer.
    But, there is no ROM that can use the full amount of space??
    With my rom you will extend the userdata partition and you will get 14,68 GB for app and data (if you have 16gb version) or 29,72 GB (if you have the 32gb version).
    In other words you won't have the lack of space problem anymore
    May 2017
    请问什么时候增加网速显示功能?
  4. #23
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da bluefox Visualizza il messaggio
    请问什么时候增加网速显示功能?
    Mmmhn mate, i'm a simple italian guy, i didnt understand anything that you wrote, english please
  5. #24
    May 2017
    Status bar can increase the download speed display?please!!!
    Ultima modifica di bluefox; 03-05-17 alle 11:28
  6. #25
    Jun 2017
    hmmmm, is it just me or the sound got much quieter/less bass compared to other firmwares? guess it's cause of a different EQ =/
    Is it possible to get the good old Dolby Sound back or it's completely not compatible with 7.1?
    Apart from that, thanx for a great firmware!!!!! It gave new life to the z5s
  7. #26
    Mar 2016
    Lecce
    Nubia z5s
    Quote Originariamente inviato da blackrox Visualizza il messaggio
    Fist of all, thank you I worked hard on this rom.
    Second point, i noticed the same thing but i didnt modify any audio configuration since cm-13.0, so i guess it's 7.1 fault.
    Btw i solved this "issue" installing dolby atmos
    https://forum.xda-developers.com/and...atmos-t3412342
    you must take lenovo a7000(6.5) it's the only compatible zip with our firmware, the sound on my device it's great with dolby atmos, i unistalled audio fx too, so let's get a try if you want
  8. Il seguente Utente ha ringraziato Maegorn per il post:
    blackrox (10-06-17)
  9. #27
    Jun 2017
    Quote Originariamente inviato da Maegorn Visualizza il messaggio
    thx for the fast reply ^_^
    of course will try it out tomorrow =) can you give a tip of which soft did you used to uninstall audiofx?
  10. #28
    Mar 2016
    Lecce
    Nubia z5s
    Yup, Titanium Backup
    1. backup your app 2. unistall or freeze the selected one
  11. #29
    Jun 2017
    Tried out Dolby atomos, still kinda quiet, but sound quallity is way higher, can you include it in the next build?
    Can't completely kill audiofx completely though with titanium (start to work after restart) so will wait for the next release)
    And again thanx for the firmware ^_^
  12. #30
    Mar 2016
    Lecce
    Nubia z5s
    In dolby atmos you have to enable "Volume Leveler" to make the sound louder.
    Btw i can't included it in my build, i just wanna a similar stock firmware and i dont know if the other people want dolby atmos
