Pagina 2 di 2 primaprima 12
Help needed for Italian Translation of GeoStar (can help localize in French)
  1. #11
    Sep 2010
    Maybe i didn't click the right button...(with Italian...)
    The content was :
    "Here is the link to the spreadsheet :
    https://spreadsheets.google.com/ccc?...thkey=CPeytbQH
    Feel free to mail me if you have any question and if you want me to make some translation to French.
    Charlie "Kafeine" Hurel"
    Can you mail me ?
    Android.geostar (at) dontneedcoffee (dot) com
    Edit : ok...I send it now. (My message was in : "messaggio del visitatore" on your profile. So not ok )
    Ultima modifica di Kafeine; 27-09-10 alle 21:41
    Feb 2010
    Translated it, except for numbers 13, 59 and 62. Could you explain those better?
    edit: domanda per gli italiani. Come lo tradurreste "Numero massimo di risposte corrette di fila" in modo più conciso?
    Ultima modifica di eafkuor; 27-09-10 alle 22:26
  4. #13
    Mar 2009
    Portogruaro
    Massimo numero di risposte corrette in sequenza.
    Forse si può togliere "massimo", ma bisogna vedere il contesto
  5. #14
    Feb 2010
    Purtroppo mi sa che non si possa togliere.
  6. #15
    Sep 2010
    You can make it short using : translating "Best Sequence" instead of Streak.
    How would you tranlsate Best Sequence ? or Best Series ?
  7. #16
    Feb 2010
    Sequenza Migliore
  8. #17
    Sep 2010
    Ok. So GeoStar v1.16 is now available on the market with Italian and bigger map.
    Many thanks to : Simone Russo
  9. #18
    Androidiani Power User L'avatar di androgiallo
    Feb 2010
    Trento
    Oneplus 2
    Ringraziato 1,276 volte in 897 Posts
    very good work.... thx
    Gianluca
