# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=20120418
ro.build.display.id=20120418.eng.jacky.20120418.18 1433
ro.build.version.incremental=eng.jacky.20120418.18 1433
ro.build.version.sdk=15
ro.build.version.codename=IceCreamSandwich
ro.build.version.release=4.0.3
ro.build.date=Wed Apr 18 18:15:14 CST 2012
ro.build.date.utc=1334744114
ro.build.type=user
ro.build.user=jacky
ro.build.host=linux-server
ro.build.tags=test-keys
ro.product.model=MEDIACOM
ro.product.brand=MID
ro.product.name=f04ref
ro.product.device=f04ref
ro.product.board=f04ref
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=Embel
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=14
ro.wifi.country=EU
ro.board.platform=
# ro.build.product is obsolete; use ro.product.device
ro.build.product=f04ref
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=f04ref-user 4.0.3 20120418 eng.jacky.20120418.181433 test-keys
ro.build.fingerprint=MID/f04ref/f04ref:4.0.3/20120418/eng.jacky.20120418.181433:user/test-keys
ro.build.characteristics=tablet
# end build properties
# system.prop for M1 reference board
# This overrides settings in the products/generic/system.prop file
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=160
keyguard.no_require_sim=1
#set keyguard.enable=false to disable keyguard
keyguard.enable=true
ro.statusbar.widget=true
ro.statusbar.button=true
ro.statusbar.yearmonthdayweek=true
#wifi.interface=ra0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
#wifi.supplicant_scan_interval = 60
#alsa.mixer.playback.master=DAC2 Analog
#alsa.mixer.capture.master=Analog
#configure the Dalvik heap for a standard tablet device.
#frameworks/base/build/tablet-dalvik-heap.mk
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=256m
hwui.render_dirty_regions=false
# Disable un-supported Android feature
hw.nopm=false
hw.nobattery=false
hw.nophone=false
hw.novibrate=true
hw.cameras=2
hw.hasethernet=false
#hw.hasdata=true
ro.platform.has.touch=true
# Wi-Fi sleep policy
ro.platform.has.sleeppolicy=false
#set to 0 temporarily so touch works without other changes
ro.sf.hwrotation=90
#0~7 You are required to get the correct install direction according the sensor placement on target board
ro.sf.gsensorposition=1
ro.sf.ecompassposition=4
allow_all_orientations=1
# Use OSD2 mouse patch
ro.ui.cursor=osd2
# Enable 32-bit OSD
sys.fb.bits=32
# Disable GPS
gps.enable=false
# Enable player buildin
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=asf,wav,aac,mp3,m4a,ape,flac,alac
media.amplayer.enable=true
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
media.amplayer.thumbnail=true
# Status bar customization
ro.statusbar.widget.power=true
# HDMI
ro.hdmi480p.enable=false
rw.fb.need2xscale=ok
#media.amplayer.osd2xenable=false
media.amplayer.osd2xenable=true
#camera DCIM dir. 0:sd only; 1:nand only; 2,sd first
ro.camera.dcim=1
# Disable preload-class
ro.amlogic.no.preloadclass=1
#default time zone
#persist.sys.timezone=Asia/Shanghai
#yitaly time zone,language
persist.sys.timezone=Europe/Rome
persist.sys.language=it
persist.sys.coutry=IT
# App optimization
ro.app.optimization=true
#Dual display
#ro.vout.dualdisplay2=false
ro.vout.dualdisplay2=true
# ADDITIONAL_BUILD_PROPERTIES
ro.opengles.version=131072
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
