Nuova Versione TWRP 2.4.2.0 touch recovery
se ti sono stato utile, clicca THANKS grazie !!!
In prima pagina il file da flashare in recovery...
What's new in 2.4.2.0:
Add screen timeout - screen will turn off automatically after 60 seconds, saves battery and prevents screen burn-in especially on AMOLED devices
Add a brightness setting (requires device specific setup and only some devices have been added)
Add a root checker and offer to install SuperSU if the device isn't already rooted
Add a write buffer to libtar backups, significant improvements to speeds when backing up to exFAT target, minor improvements for other file systems
Check and offer to fix root permissions if broken
Add an option for a 24 hour clock display instead of AM/PM (aka military time)
Move stock recovery reflash check to occur during the reboot cycle
Add support for some MTK6xxx devices
Change libtar to vfork to help prevent memory problems
Add a "clicked" effect to most buttons, file selector, and listbox
Improve timezone listbox to be more like file selector (per pixel kinetic scrolling, etc)
Remove some no longer used settings (Forced MD5 sum on zips, size checking on image backups)
Other minor bugfixes and improvements
framir (25-02-13)
Francesco
Smartphone: LG Nexus5 - ROM: Stock - Kernel: Stock - Boot: Sbloccato - Recovery: TWRP
A te l'onore.. eccoti la piallata https://www.androidiani.com/forum/mo...ml#post2618995
framir (25-02-13)
Se non uccide fortifica
FIGLIO - PIXEL45GStock11
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
IO - S205G Stock11-TabSamA-TicwatchPro
SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
<-- Se ti sono stato utile, ricordati il THANKS
Se cerco di usare l'usb otg mi dice: Unable to mount usb OTG...qualcuno ha soluzioni?
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
