Pagina 5 di 5 primaprima ... 345
Visualizzazione dei risultati da 41 a 43 su 43
[Huawei Ascend G330]Come compilare il kernel Huawei v3.0.21
  1. #41
    Senior Droid L'avatar di Ikon
    Dublino
    Moto G 2ng Gen 5" Dual SIM
    Ringraziato 61 volte in 45 Posts
    Quote Originariamente inviato da dark706i Visualizza il messaggio
    Si potrebbe provare a compilare questi source del kernel 3.4 della cm10 per g510 http://link2.tapatalk.com/?id=11082X...26c9e0c&sref=4
    Qui trovi i miei progressi:
    https://www.androidiani.com/forum/mo...ml#post3602773
    Ikon, thanks a lot for your great efforts!
    I discovered this Github Page a few days ago:
    https://github.com/derekhe
    "Derekhe" modified the G330-D kernel and fixed compile issues. I just tried to compile and flash the kernel on my device but Wifi and Bluetooth still doesn't work. Instead of modifying the board-msm7x27a.c file he modified board-msm7627a.h and removed this part on line 104:
    codice:
    struct bt_vreg_info {
    	const char *name;
    	unsigned int pmapp_id;
    	unsigned int min_level;
    	unsigned int max_level;
    	unsigned int is_pin_controlled;
    	struct regulator *reg;
    Do you have any progress in porting the G510 kernel?
    Regards,
    DemonFirefox
    EDIT: Just found something pretty interesting! According to mengzhuos git page you just need the set this before compiling:
    codice:
    export ENABLE_BTLA_VER30=true
    Just used the original/unmodified kernel and it compiled flawlessly! Still the Wifi/Bluetooth problem remains. Maybe I'm doing something wrong (toolchain, copying drivers, etc)? Would be great if you could check it, thanks!
    Ultima modifica di DemonFirefox; 21-07-13 alle 15:25
  4. #43
    Dublino
    Quote Originariamente inviato da DemonFirefox Visualizza il messaggio
    codice:
    	const char *name;
    Regards,
    DemonFirefox
    codice:
    Thank you for the hints.
    I am still not able to compile the g510 kernel. I can't find the reason. About the derekhe fix, I am not confident on removing code or make other kind of invasive changes. I mean, the kernel is original and released by the vendor: it must work as it is. No changes should be needed. My patch just mask some compiler warnings handled as errors by GCC v4.7. I just fixed the board-msm7x27a.c because the fix is pretty straightforward (they were missing an #ifdef). For the G510 the problem is about the same. My opinion is that a lot of customers were asking for the kernel and this was bothering them. So they just released a kernel! They didn't check if it was working or not...
    Anyway I am not working on the kernel since I am busy with my job. Please, continue to post here your progresses.
    I will try to contact someone in Huawei that can support me compiling a working kernel!
    Ultima modifica di Ikon; 21-07-13 alle 17:24
