galofornia
ALLORA HO FATTO IL ROOT. ho instalato la recover del rom manager selezionando o1. Ho messo il zip sul sd. Riaciato in recovery da rom manager. Instala rom da sd. Parte poi mi da questo. Instaling:/sdcard/LOL_V1.4.2-2.zip Finding update package... opening update package... Installing update...Amend scripting (update-scripy) is no longer supported. Amend scripting was deprecated by Google in Android 1.5. It was necessary to remove it when upgrading to the clockworkMod 3.0 Gingerbread based recovery. Please switch to Edify scripting (updater-script and update-binary) dto create working update zip packagers. Instalation aborted.
Voglio dire che nel rommanager ce la scritta recovery attuale 3.1.0.0 e inoltre ho un: Brandizatto wind.
Vers. Android 2.2.1
Vers. Kernel 2.6.32.9
Lg-electronics@si-rd10-build120#1 Wed dec 8 10:54:53 EST 2010
Numero build frgt83
Versione software v10b-07-2010
Dai raga dami una mano cosa sbaglio.
