Perfetta...scarico flasho e appena posso provo le prestazioni e vedere quanto regge...
★Device0: Samsung Galaxy S7 EDGE "Exynos"★
★Device1: Samsung Galaxy S6 EDGE+ SM-928F★
★Device2: Samsung Galaxy S5 SM-G906F★
★Device3: Samsung Galaxy S4 GT-I9506★
★Device4: Nexus 7 2013★
★Device5: Nexus 7 2012★
★Device6: Nexus S I9020★
Tutti Customizzati..
Provo la versione 06-08-2013 vediamo come va comunque ad ogni aggiornamento sempre meglio e per la prima volta mi retto i 2322MHz e le prestazioni sono assurde.
Ultima modifica di IlNik97; 18-06-13 alle 10:47
nuova versione disponibile
10.6.2013
1. Fixed Linaro -O3 optimizations flags for MORE SPEED!!!!!!!!!!
2. Linux 3.4.48
3. Made a couple patches to mainline Linux to try stopping random reboots from the last_kmsg's some people have provided
4. AOSP ONLY: Merged in some missing MDL source and some ME4 source from Samsung
5. Allow non samsung app to update firmware for sensors (camera, etc...)
6. FAST CHARGE IS WORKING AMAZINGLY NOW. When activated you will NOT be able to do file transfers. USB 2.0 will be a touch faster but not too much since 2.0 will only output 460-520 mA. USB 3.0 will go all the way up to 840-1000 mA (on my PC USB 3.0 port is charging at 36% per hour)
7. KTweaker: Fixed issues with "Screen OFF Mhz"
8. Removed ME4 code from TW version since it was causing issue for some people
Modello: Motorola DROID TURBO ballistic 64GB
Operatore: Vodafone
AGGIORNAMENTO DEL KERNEL:17.6.2013
1. Linux 3.4.49
2. jf: JC: allow non samsung app to update firmware
3. sched: Set MC (multi-core) sched domain's busy_factor attribute to 1 (big speed bump from this commit)
4. Disable Screen Off Mhz Call: GOES LIVE
5. dmesg log spam: remove more cypress keypress spam and haptic feedback
6. driver:video: Remove some dmesg log spam
7. Lots of patches for AOSP to kill the reboot issues
PRIMA DI AGGIORNARE IL KERNEL REIMPOSTATE I VALORI STOCK DALL'APPLICAZIONE "KTweaker" tramite l'apposita funzione "Load default" nella schermata iniziale;
Potete anche farvi un backup delle impostazioni tramite la voce "Backup prefs to sdcard" sempre nella schermata iniziale ed una volta aggiornato il kernel ripristinarle con la funzione "restore prefs from sdcard".
buongiorno a tutti
volevo sapere se installo questo kernel sul mio s4 che ha già installato TWRP v2.5-I9505 [Agg. v.2.5.0.2]
avrò problemi? il TWRP mi funziona ugualmente?
