lo ho fatto, ma lo fa ripetere, prima di creare quel file esce:
device model not supported (or not detect -check root) !
generate a dump file that may help make this device compatible? this takes 30 minutes!
if this is the paid version, do not do this, it will prevent refused!
if you device dupports external sd cards, please inser one now
no - yes
premendo yes esce
Dumping...
this could take 30 minutes!
