Utilissima news, grazie!
Parliamo comunque sempre della ROM stabile inglese cinese?
Possessore di Galaxy Note 3 Neo
ex Possessore di Galaxy S2 i9100
ex Possessore di Google Nexus GT-i9023
eciv (22-01-16)
Se faccio la richiesta con updater, mi appare l'aggiornamento 7.0.11
Devo fare prima questa per vedere la 7.1.6?
@eciv: si devi fare tutti gli aggiornamenti
eciv (22-01-16)
Confermo quanto già detto da darkmirko, con l'ultimo aggiornamento il problema è risolto, ho fatto un paio di chiamate e sembra funzionare bene.
Qualcuno per caso riesce a recuperare il changelog?
Ecco a te:
Lockscreen, Status Bar, Notification Bar
Fix - Sometimes lockscreen password did not work when using some third party themes (01-07)
Music
New - Audio settings support Mi Piston earbuds color edition (09-02)New - Brand new UI with more music resources (09-15)Optimization - The current playing music will be displayed in visible area when entering music list from playing now page (11-05)Optimization - Support choosing from several modes when playing with car bluetooth (11-10)
Market
New - Similar searching key words will display in search result page (11-10)Fix - App language did not change with system language (11-10)Fix - Home screen perfect icons did not update after updating the app in third party app store(s) (11-10)Fix - Start page tabs were misaligned in some devices (11-10)
File Explorer
New - Added private folders (10-20)New - Support listing starred files by editing time (11-03)New - Support adding folders to private folder (11-09)New - Allow selecting restore path when disabling private settings (11-09)New - Support moving files in private folder (11-18)New - Private folder supports file name encryption (11-18)New - Added space clearing prompt for phone management (11-18)New - Support setting default video player (11-18)New - Support adding File Explorer shortcut to home screen (11-18)Optimization - App more compatible with custom themes (09-08)Optimization - Optimized Mi WiFi Router entry display mechanism (09-08)Optimization - Optimized images display method (11-03)Optimization - Progress status display method of compressing/decompressing etc. (11-03)Optimization - Changed Mi Drop category page default ordering method to descending by time (11-03)Fix - Mi WiFi Router entry did not show in start page (09-08)Fix - Thumbnails are not displayed in searching result (11-03)
Downloads
New - Support downloading torrent and magnet links (10-08)New - Support searching online resources (11-02)New - Support adding home screen shortcut for searching online resources feature (11-19)Optimization - Optimized account mechanism (11-19)
Calendar
Optimization - Optimized app widget style when using different font sizes (09-08)Optimization - Card view style for displaying events (10-29)
Cleaner
New - Unused apps clearing notification (10-19)New - Recommendation page after clearing trash (10-20)New - Clearing animated effects (10-20)
Battery Usage
Optimization - Low battery warning message will not pop up when there's an incoming call (10-12)Optimization - Optimized the prompt text when power on and off time are set as the same (11-17)
Security
New - Added ''Connection' shortcut in security to view each app's realtime connection speed (10-26)Optimization - Increased check process efficiency (10-27)
karlinze (24-01-16)
