Visualizza i risultati del sondaggio: Quale rom state usando?
Chi ha votato
46. Non puoi votare questo sondaggio
  • Io ho la rom di BB72&Cuoco92 vers. 1-3
    2 4.35%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite recoverry
    16 34.78%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite OTA
    15 32.61%
  • Io ho la rom LEWA multilingua
    4 8.70%
  • Io ho un'altra rom
    9 19.57%
Pagina 327 di 489 primaprima ... 227277317325326327328329337377427 ... ultimoultimo
Visualizzazione dei risultati da 3,261 a 3,270 su 4883
[Alcatel/TCL IdolX+/S960] Guide Root- Recovery- Rom Custom
  1. #3261
    Ringraziato 10 volte in 8 Posts
    Quote Originariamente inviato da Cuoco92 Visualizza il messaggio
    ** KITKAT 4.4.2 RELEASE **
    - Gapps 4.4.2
    - Root
    - Supporto OtaUpdates
    Aggiornando ho perso i permessi di root
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Quote Originariamente inviato da trip007in Visualizza il messaggio
    I doubt they would go all the way to develop a pure vanilla ROM for their device. But again I am hoping I will be wrong and we get a taste of Pure Android 4.4.2 on our device. You are doing a great job Cuoco92 and we appreciate and acknowledge all the efforts you have been putting for improving the software experience our device.
    Dear Cuoco92, I have been trying to flash MIUI latest version and few older version, but every time my ROM flash gets stuck at formatting system... and never proceed further. I have never been successful till now flashing my device, though I had succeeded once flashing LeWa before i switched to your ROM. Do you have any suggestions for me anything I am doing wrong here? This I am asking out of curiosity, is there any problem with the recovery? A point to note after system got stuck at formatting system and forced reboot in to recovery I cant restore back up the mounting system fails...But flashing the system update released by you works to restore the functional ROM....That's weird....
    Thanks trip007in 😃
    That's very strange 😣 you may have to Fix permissions from recovery. Maybe it helps.
    Or try to flash the recovery again...
  4. Il seguente Utente ha ringraziato Cuoco92 per il post:
    trip007in (21-07-14)
  5. #3263
    Sardegna
    Quote Originariamente inviato da mariosavio Visualizza il messaggio
    Si hai ragione...eppure ho proceduto come sempre 😒 ti faccio sapere...
    Ho appena rilasciato un'aggiornamento per chi avesse installato kitkat, con il supporto per la lingua italiana e tedesca 😄
    Non penso di fare molti progressi con questo firmware, in quanto come già detto, aspetterò la release ufficiale della Alcatel...che spero sia davvero a breve 🙌
    Ultima modifica di Cuoco92; 21-07-14 alle 14:13
  6. #3264
    Jun 2014
    Thanks trip007in ��
    That's very strange �� you may have to Fix permissions from recovery. Maybe it helps.
    Sorry my dear Friend, I tried everything possible. Yes even fixing permissions. I also tried with a different recovery (Cofface CWm), but nothing worked. So I was curious and asked you this question.
    I have a question regarding Kitkat ROM, Do we still have a Custpack partition for 4.4.2? I hate it.
  7. #3265
    Sardegna
    Yes custpack partition ist still there 😁 I hate it too..
  8. Il seguente Utente ha ringraziato Cuoco92 per il post:
  9. #3266
    Redmi Note 3 Pro, Honor 6
    Ringraziato 803 volte in 570 Posts
    Io sto in ferie come ogni anno a luglio anche se quest anno è stato una mezza fregatura visto il tempo altalenante. La provo fine settimana mi domandavo ma ha questa rom ha il launcher tipo miui o quello stile Android?
    Inviato dal mio TCL S960.
    "Seguire le regole del forum aiuterà te e gli altri a trovare risposta"
  10. #3267
    Sardegna
    Per risolvere il problema dei permessi Root...
    - Vai nel recovery e monta la partizione System
    -Avvia il File Manager e cancella il binario 'su' dalle cartelle xbin, bin e ext e il programma Superuser dalla cartella system/app
    - vai su reboot e il twrp ti chiede se vuoi effettuare il Root...
    - fai lo swip per confermare 😉
  11. #3268
    Sardegna
    Quote Originariamente inviato da palasix Visualizza il messaggio
    Beh dipende dove vai in vacanza...in Sardegna d'estate c'è il sole costante ☀ tutta la stagione, raramente piove 😄
    Il firmware kitkat dal punto di vista grafico è uguale al JellyBean...
    Il launcer è lo stesso...
    Cambia qualche menu, ma niente di speciale 😉
  12. #3269
    Questa è stata un estate anomale te lo dice uno che vive al sud e di sole ne capisce ... Fortunatamente sto in vacanza all'Elba non lontano dalla Sardegna ed il tempo è stato migliore rispetto al resto dell Italia ma di certo peggiore rispetto ad altri anni ci vuole pazienza non esistono più le stagioni di una volta
  13. #3270
    Sardegna
    Si hai ragione, ormai le stagioni sono diventate come le donne...fan quello che gli pare 😂
    Tornando al tema kitkat...
    Sotto 'Opzioni sviluppatore' trovate la una nuova funzione introdotta con KitKat con la quale si puo cambiare il runtime dal 'Dalvik' al 'Art'
    Riporto qui una breve spiegazione a tale proposito, presa dal sito thomsw.it
    'Google è finalmente pronta ad abbandonare Dalvik, la macchina virtuale (VM) di Android che gestisce la maggior parte delle applicazioni.*
    Cos'è una macchina virtuale, e perché ce n'è una dentro Android? Sintetizzando al massimo, possiamo dire che si tratta di un computer dentro a un altro computer: si usa per rendere più semplice la scrittura e l'esecuzione di software, ed è particolarmente importante quando – come nel caso di Android – si ha a che fare con una grande varietà in termini di dispositivi e configurazioni hardware.
    Il problema è che in questo modo si aggiunge un livello di complessità che riduce le prestazioni: una cosa è avere codice eseguito direttamente dal processore (nativo), e un'altra un programma gestito prima dalla macchina virtuale – che in un certo senso lo traduce – e poi dal SoC del nostro smartphone. Questo doppio passaggio può rendere tutto più lento e aumentare i consumi.
    ART cerca di risolvere o almeno mitigare il problema con una soluzione intermedia chiamata AOT (Ahead Of Time compilation): il codice dell'applicazione non è più interpretato a ogni esecuzione, ma una volta sola quando la installiamo. In questo modo dovremmo ottenere prestazioni comparabili a quelle del codice nativo, ma senza compromettere il lavoro dello sviluppatore.
    Questo approccio rende comprensibilmente più lungo il processo d'installazione, ma il ritardo dovrebbe notarsi solo con le applicazioni più grandi. L'eventuale aggiornamento di uno smartphone da Dalvik ad ART potrebbe richiedere diverso tempo – dipende da quante e quali app sono installate – ma poi i vantaggi dovrebbero essere evidenti.
    I primi test suggeriscono che alcune applicazioni sono veloci fino al doppio passando dal vecchio sistema a quello nuovo, e similmente si riducono i consumi. Vantaggi che valgono anche per la stessa interfaccia grafica di Android, con meno latenza.
    In termini assoluti ART potrebbe "finalmente rendere Android reattivo e fluido come iOS" scrive Sebastian Anthony su ExtremeTech. E in effetti c'è un dibattito aperto praticamente da sempre, alimentato da chi sostiene che Android funzioni al meglio solo con hardware abbastanza potente.'
  14. Il seguente Utente ha ringraziato Cuoco92 per il post:
    nsourm (21-07-14)
