Visualizza i risultati del sondaggio: Quale rom state usando?
Chi ha votato
46. Non puoi votare questo sondaggio
  • Io ho la rom di BB72&Cuoco92 vers. 1-3
    2 4.35%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite recoverry
    16 34.78%
  • Io ho la rom di BB72&Cuoco92 vers.4 installata tramite OTA
    15 32.61%
  • Io ho la rom LEWA multilingua
    4 8.70%
  • Io ho un'altra rom
    9 19.57%
Pagina 337 di 489 primaprima ... 237287327335336337338339347387437 ... ultimoultimo
Visualizzazione dei risultati da 3,361 a 3,370 su 4883
[Alcatel/TCL IdolX+/S960] Guide Root- Recovery- Rom Custom
  1. #3361
    Mar 2014
    Greece
    TCL IDOL X+ S960
    And it works through ota?
    I can't install even7.1
    can you upload it on a mirror(7.2)?
    Ultima modifica di nsourm; 23-07-14 alle 18:45
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Quote Originariamente inviato da nsourm Visualizza il messaggio
    You have to download the update through system updates, then go into recovery, select install, go to Otaupdater/downloads and select the update 😉
    Quote Originariamente inviato da spavian Visualizza il messaggio
    All working fine after 7.2 update including google play, for now. Cuoco ,maybe you have time to make audio setting appears on mobile uncle, engineer setting like you did on 6.0 because to me the volume in the headset seems low. Thanks and keep the good work.
    Yes I'm trying to make it work, but no luck till now😔
  4. #3363
    Mar 2014
    Greece
    TCL IDOL X+ S960
    [QUOTE=Cuoco92;5901422]You have to download the update through system updates, then go into recovery, select install, go to Otaupdater/downloads and select the update ��
    i've already done it with no luck even from 7.0 to 7.1
    just a request chef. can you make a step by step how to make su work?i'm a litlle bit confused
  5. #3364
    Sardegna
    Just install this from twrp recovery
    https://www.dropbox.com/s/1bvb5f06e7...erSU-v2.01.zip 😉
  6. Il seguente Utente ha ringraziato Cuoco92 per il post:
    nsourm (23-07-14)
  7. #3365
    Mar 2014
    Greece
    TCL IDOL X+ S960
    Quote Originariamente inviato da Cuoco92 Visualizza il messaggio
    https://www.dropbox.com/s/1bvb5f06e7...erSU-v2.01.zip ��
    Thanks chef.
    Just a little tutorial to other having mine problems.
    1. Install rom
    2. do not reboot
    3. install super user
    4. reboot
    5. download ota
    6. install through recovery
    7. reboot
    8. download 7.2
    9. reboot into recovery
    10. install it
    11 well done
    thanks a lot chef
    awesome job
    Ultima modifica di nsourm; 18-08-14 alle 11:10
  8. #3366
    Cagliari
    Jiayu G2s
    Ringraziato 14 volte in 10 Posts
    sto chef suona tanto laboratorio di anfetamine
    Inviato dal mio ALCATEL ONETOUCH 6043D usando Androidiani App
  9. #3367
    ALCATEL IDOL X+ 6043D
    Ringraziato 19 volte in 13 Posts
    Ciao,
    ho un problema con Google Now , non riesco più a farlo cercare all'interno del telefono ( nei contatti , mail , ecc... ).
    Nelle sue impostazioni in "ricerca sul telefono" non appare più nessuna voce , mentre prima potevo selezionare dove poter eseguire la ricerca , appunto su contatti , mail , documenti , ecc....
    Prima per intenderci con la ricerca vocale dicendo "chiama Pinco Pallino" , il tel. chiamava il contatto , ora non lo trova e vuole che sia selezionato manualmente.
    Problema sul apk di ricerca Google forse ?
  10. #3368
    Sardegna
    Quote Originariamente inviato da dannyghost Visualizza il messaggio
    Ciao,
    Si l'ho notato pure io...io cmq uso questa applicazione
    https://play.google.com/store/apps/d...ols.alice_lite
  11. #3369
    Androidiano L'avatar di safalvofo
    Ciao ragazzi ho riscontrato uno strano problema sul display.... A volte quando sono sulla home e scorro le pagine, è come se si bloccassero o che non prende bene il touch.... Adesso non lo so spiegare bene....Ma poi mettendo il pollice bene riesco a scorrere tra le pagine.... Cosa molto strana..... Come se per scorrere il display ha bisogno proprio di sentire il polpastrello del pollice.... Riuscite a capire?
    Inviato dal Mio Galaxy NeXuS usando Tapatalk
  12. #3370
    Bellina , ma non ha l'italiano :-(
