Pagina 324 di 463 primaprima ... 224274314322323324325326334374424 ... ultimoultimo
Visualizzazione dei risultati da 3,231 a 3,240 su 4629
[ROM][MM 6.0.x] Stock modded by Cuoco92 per Lenovo K3 Note [K50-T5]
  1. #3231
    Jan 2016
    Quote Originariamente inviato da mrlude Visualizza il messaggio
    I have 1552dev installed and my only trouble is xposed not working...
    Could you post me the link to the correct working version??? Please
    Use arm64 version of Xposed, v80 works fine on 1552dev.
    Feb 2016
    Quote Originariamente inviato da plou13 Visualizza il messaggio
    I have chomp sms installed and is working properly
    why LED notifications does not support the application sms stock then?
    Cuoco very good work on the Rom ... very fluid
  4. Il seguente Utente ha ringraziato Richarddco per il post:
    Cuoco92 (06-03-16)
  5. #3233
    Baby Droid L'avatar di plou13
    Jan 2016
    Quote Originariamente inviato da Richarddco Visualizza il messaggio
    I don't know!! But you can replace the stock sms app with one other.. There are so many nice sms apps out there
  6. #3234
    Jan 2016
    1 - wheel all three files on your SD card
    2 .Go purely into TWRP Recovery.
    hold all 3 buttons pressed VOI minus plus power
    3.Install xposed-v79-sdk23-arm64.zip or xposed-v79-sdk22-arm64.zip
    4.Rebooting ... that takes time some apps are optimized
    5.Install XposedInstaller_3.0 alpha 4.apk
    6.Rebooting
    7.7 - Install Gravitybox Lollipop 5.1.4.apk
    8.Rebooting
    9.9 - Xposed modules put the hoe in purely Gravitybox LP
    10.Rebooting
    Here the files: https://www.dropbox.com/sh/xz7sazdhj...9kV2gphca?dl=0
    No thanks. Continue to View →Download
    Google Italian
    1 - ruota di tutte e tre le file sulla scheda SD
    2 .andare puramente in TWRP Recovery.
    contenere tutti i 3 tasti premuti VOI minus più potenza
    3.Installare xposed-v79-sdk23-arm64.zip o xposed-v79-sdk22-arm64.zip
    4.Rebooting ... questo richiede tempo alcune applicazioni sono ottimizzate
    6.Rebooting
    7.7 - Installare Gravitybox Lollipop 5.1.4.apk
    8.Rebooting
    9.9 - I moduli Xposed messo la zappa in puramente Gravitybox LP
    10.Rebooting
    Qui i file: https://www.dropbox.com/sh/xz7sazdhj...9kV2gphca?dl=0
    No grazie. Continuare a Visualizza → Scaricare
    arrivederci - Tschüss - Bye
    Ultima modifica di German1; 06-03-16 alle 20:50
  7. Il seguente Utente ha ringraziato German1 per il post:
    Cuoco92 (06-03-16)
  8. #3235
    Feb 2016
    shame ... thank you for your answers
    Chomp sms working properly
    Ultima modifica di Richarddco; 06-03-16 alle 21:26
  9. #3236
    Baby Droid L'avatar di rockets
    Oct 2015
    hey @Cuoco92 e tutti,
    sono ancora in VIBEUI_V2.8_CUOCO92_ROW_1540D, che rom devo effettuare l'aggiornamento a: LENOVO_K3_5.1_1552DEV_ROW_002_CUOCO92 o K3_NOTE_MM_6.0_1608_v12_ROW_GOOGLE_D_CUOCO92? che è meglio della tua esperienza?
    grazie per l'aiuto.
    hey @Cuoco92 and all,
    i'm still on VIBEUI_V2.8_CUOCO92_ROW_1540D, which rom should i upgrade to: LENOVO_K3_5.1_1552DEV_ROW_002_CUOCO92 or K3_NOTE_MM_6.0_1608_v12_ROW_GOOGLE_D_CUOCO92? which is better in your experience?
    thank you for the help.
    perdono il mio italiano, sto usando google translate
  10. #3237
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Hello @rockets
    I suggest you to install this one:
    Or the 16010 with vibeui 3.1
  11. Il seguente Utente ha ringraziato Cuoco92 per il post:
    rockets (08-03-16)
  12. #3238
    Senior Droid L'avatar di ilsaggio
    ROMA
    Lenovo K3 Note K50
    Ringraziato 54 volte in 43 Posts
    Scrivete in italiano per favore?
  13. #3239
    Jan 2016
    hey @Cuoco92 è possibile fissare dati mobili passare nel 1610, 3.5? I dati funziona solo per SIM1. Grazie
  14. #3240
    Moderatore SENIOR L'avatar di ghost45
    Troppi.. Mtk in generale.
    Ringraziato 1,247 volte in 782 Posts
    Quote Originariamente inviato da ilsaggio Visualizza il messaggio
    Hai perfettamente ragione... Se volete riproporre dei testi in inglese, almeno fate una traduzione al testo.... Cosi sarà comprensibile a tutti.
    Usate il tasto "thanks" se vi sono stato d'aiuto non usate posts per ringraziare....contribuiamo a mantenere puliti i threads!!
