Pagina 16 di 46 primaprima ... 6141516171826 ... ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 457
HDC 9002-9006 NOTE 3 1:1 S-PEN e tanto altro
  1. #151
    Senior Droid L'avatar di shopngoit
    SZ
    MEIZU X4
    Ringraziato 146 volte in 129 Posts
    Quote Originariamente inviato da corel68 Visualizza il messaggio
    Grazie del supporto Shopngo ti copio ed icollo quanto scrivono loro nelle specifiche:
    HDC Galaxys Note 3 N9000 Android phone Tech Info
    HDC Galaxys Note 3 N9000 owns a 5.7inch HD IPS screen with 1280*720 pixel(System shows 1920*1280 pixel) display, and MTK6589 Quad Core 1.2Ghz(System shows Eyxons 5420 Octa Core) processor, 1GB RAM, and 4GB storage(System shows 3GB Ram, 16GB Rom).
    HDC Galaxys Note 3 N9000 installs Android 4.3 and supports Air Command/ Air View/ Gesture Control/ Smart Scroll/ Multi Task/ 3 Colors Indicators, later we will release a new rom to support Smart Stay Function. HDC Galaxys Note 3 N9000 uses same leather back case as the original one.
    HDC Galaxys Note 3 N9000 is the first Android 4.3 Phone on FCT and carries with Amoi HD Screen.
    Altre specifiche:
    General
    Manufacturer: HDC
    Model: HDC Galaxys Note 3 N9000
    Phone Style: Bar, multi-touch screen, 5.7inch Capacitive touchscreen
    Operating System: Android 4.3
    Processor: MTK6589 Quad Core 1.2Ghz
    Google Play Store: Can be pre-installed
    Display
    Screen Size: 5.7 inch HD IPS touchscreen
    Display reulotion: 1280*720 pixel(System shows 1920*1280 pixel)
    Color Support: 16 million colors
    Screen Technology: Multi-touch screen, 320PPI(System shows 441PPI)
    Camera
    Camera Resulotion: 13MP rear cmos camera + 1.3MP Front Camera, digital zoom
    Connectivity
    Connectivity Technology: GSM + WCDMA(Single Micro Simcard)
    Network Band: GSM 850/900/1800/1900MHz + WCDMA 850/2100MHz
    Data Technology: GPRS/EDGE/HSPA
    Bluetooth: Bluetooth 4.0 + HID
    WLan: WiFi Display, WiFi Direct, 5GHz WiFi
    USB: USB 2.0
    GPS: GPS + GLONASS, AGPS(Built-in GPS chipset)
    Features
    Video Player: AVI, MP4, 3GP, MOV, MKV, FLV
    Audio Player: FLAC, APE, MP3, OGG, AMR, AAC
    Image: JPG, PNG, BMP, GIF
    Ringing Tones: Downloadable
    Message: SMS, MMS, Email
    Phone Book: 10000 contacts
    Brower: HTML
    Interface/Port:
    Game: Downloadable
    Radio: FM
    G-sensor
    Interface/Port: 3.5mm earphone jack / mini USB
    Battery
    Battery: Li-on battery(2800mAh)
    Standby Time: 150-200 hours
    Memory
    Built-in Memory: 1GB RAM, 4GB ROM(System shows 3GB Ram, 16GB Rom)
    Size
    Dimensions: 151.3*79.2*8.4
    Weight: 170
    What in package
    1 * HDC Galaxys Note 3 N9000 Android Phone with Stylus Pen
    1 * Charger
    2 * Batteries
    1 * USB Data Cable
    1 * Headphone
    P. S.
    Può essere il N9006 con etichetta cambiata e firmware diverso in quanto le caratteristiche sono uguali. Di mono sim mi pare ci sia solo il N9006 che dopo altri produttore cambiano il n. di serie è un altro. Ad esempio alcuni N9006 marchiati se caricati via eroot visualizzano il codice N9000 invece di N9006, ma sono lo stesso cellulare. I dati che appaiono (FHD,3GB) ecc stanno ad indicare che il cellulare probabilmente è marchiato samsung quindi il firmware è modificato (come il N9006 marchiato e non, nel non marchiato i dati sono corretti ed esce N9006, nel marchiato il più delle volte appaiono i dati modificati e n. di serie N9000)
    Ultima modifica di shopngoit; 21-11-13 alle 14:29
    FIRMWARE/ROM DOWNLOAD esclusivo: http://cinafoninidual.altervista.org
    AM3
    AM3 non è in linea
    Senior Droid L'avatar di AM3
    Modena
    Samsung Galaxy Note 2 n7100
    Ringraziato 34 volte in 30 Posts
    Quindi....su n9006 la batteria samsung è compatibile e su n9002 no? N9006 è un vero monosim oppure gli hanno tappato lo slot sim2???
  4. #153
    ciao volevo acquistare l'hdc 9006 ma a leggere dai commenti pare abbia grossi problemi copn il play store. qualcuno che lo possiede potrebbe spiegare se è una cosa risolvible^ grazie ciao
  5. Il seguente Utente ha ringraziato roncisvallex per il post:
    smaverick (16-03-14)
  6. #154
    Jul 2010
    Ringraziato 25 volte in 20 Posts
    Io ce l ho e non ha nessun problema col playstore....
  7. #155
    Quote Originariamente inviato da androidiano2306 Visualizza il messaggio
    grazie mike78 per avermi risposto e confermato che il venditore è lo stesso, molto serio se pensiamo alle tante sole e truffe che abbondano sulla baia. Anche la flip cover che non amo particolarmente è una bella sorpresa. Credo che la tua mini recensione confermi la qualità del prodotto che pur non paragonabile all'originale è però di tutto rispetto. Per il display confermo che non è vetro ma plastica come quello del mio star n9500 ma se lo tratti bene anche senza pellicola resiste ai graffi. Ho un note n7000 originale e durante un lavoretto l'ho inavvertitamente appoggiato su una piccola vite. Risultato, il display gorilla glass si è purtroppo graffiato.....quindi dipendeda come lo tratti. Per la rom devi calcolare il sistema operativo che occupa spazio e tutte le memorie non sono mai il pieno di quanto dichiarato, quindi essendo un 8gb dovrebbe averne circa 6 liberi o poco meno.P?eccato tu lo voglia vendere subito. Io ne cambio spesso ma lo tengo almeno un mese per valutarlo bene. Ho notato che anche il mio n9500 quando spento non carica il 100% ma lo fa se acceso.Allora adesso utilizzo un caricabatterie esterno, molto più delicato e che in alcune ore carica esattamente al 100%, in maniera che alterno le due batterie. La carica dura un tempo maggiore proprio perché caricata più lentamente. Spero che la cover al silicone tipo guscio sia adattabile in quanto è l'unica che preferisco. ancora grazie.Roberto
    salve, scusate una domanda mi inviereste il nome di questo venditore in mp? quanto lo avete pagato?
  8. #156
    Quote Originariamente inviato da robillo Visualizza il messaggio
    che versione? dove lo hai preso? grazie
  9. #157
    Apparte Snote quale funzione ha in meno N3 rispetto HDC n9006? E N3 ha il touchwiz come l'originale?
  10. #158
    Apr 2011
    Ciao qualcuno mi sa dire come posso utilizzare la sd esterna anziché quella interna? Grazie ciao
    Inviato dal mio GT-N9000 usando Androidiani App
  11. #159
    Nov 2013
    Quote Originariamente inviato da shopngoit Visualizza il messaggio
    Quindi ammettendo che si tratti del n9006 com'è come device ???
    Ho appena chiesto tramite live chat e mi hanno detto che nonostante sia un clone 1:1 le batterie originali del note 3 non sono compatibili.
    Che devo fare me lo consigliate oppure no ??
  12. #160
    Androidiano VIP L'avatar di mike78
    BdG
    Ringraziato 656 volte in 582 Posts
    Il mio è clone 1.1. Con tutti gli accessori tranne la batteria che quasi sicuramente è come quella del note 1 in questi giorni un utente che lo sta aspettando uguale al mio e ha anche note 1 mi confermerà compatibilità... E a questo proposito se serve a qualcuno una batteria trovate le polarcell leggermente maggiorate di amperaggio ma non di dimensioni su ebay sui 13€ dalla Germania... La stiamo usando su s4 e vanno benissimo
