Pagina 61 di 90 primaprima ... 1151596061626371 ... ultimoultimo
Visualizzazione dei risultati da 601 a 610 su 897
[INFO] RACCOLTA E RAFFRONTO OCTACORE mt6592
  1. #601
    un nuovo telefono da prendere in considerazione che si trova a partire dai 150 a salire fino hai 200 escluse spese di spedizione ed eventuale dogana,e questo qua con caratteristiche niente male -Mx69tpro h9008 mtk6592 mobile phone cpu 1.7g 5.7 screen 3g-
    model mx69t pro / h9008 tianhe
    basic parameters
    time 2013 12 year month
    appearance design straight
    mobile phone color white and pink and black
    cpu mtk6592 1.7g eight nuclear processor
    gpu arm mali-450mp4 quad-core gpu graphics processor
    keyboard type virtual qwerty keyboard
    input method multi touch
    operating system android 4.2
    fuselage measurement high : 155mm , wide : 79.5mm , thick : 8.2mm
    fuselage weight 175g
    capacity
    ram ram rom 2g + 16g ( preparability ram 2g + rom32g )
    expansibility largest flash memory 64g
    network
    standard network gsm wcdma gsm / + / td-scdma multi mode dual standby domestic first section double slot all can support and 3g unicom mobile 3g td
    frequency network 2g : gsm 850/900 / 1800 / 1900 mhz
    3g : wcdma 850/900 / 1900 / 2100 mhz
    data service gprs edge , , hsupa , hsdpa2 , sdpa + , td-cdma
    data rate hsdpa 7.2mbps , hsupa hsdpa 5.76mbps + 42mbps
    gps agps + network + built-in gps positioning chip
    bluetooth bluetooth 4.0
    wifi wifi n 802.11 / / b g
    battery
    capacity 3000 mah lithium polymer battery removable
    screen
    screen measurement inch 5.7
    screen material hard ips screen perspective the whole joinings ogs full technology
    resolution super hd fhd 1920 * 1080 pixels
    touch screen Koningii american gorilla touch glass screen , reinforced ogs hardness , capacitance screen and multi touch
    take photo
    postpositon webcam 1300 stackable webcam , micro single stage effect ( maximum support 4096 * 3072 pixels filming , support camera 1920x1080p )
    prepositioned webcam 1300 pixels af
    sensor type cmos
    flash light led flash light highlight the
    coronae f / 2.0 wideraperture
    dyeling iso mode optional support
    metering optional support
    white balancing optional support
    for focus system optional support
    af regional optional support
    af support
    filming optional support
    scene optional support
    other performance face recognition , af , support 99 beat , support hdr , function support pannign
    anti-shake , real-time filter
    wide angle 35mm
    camera
    video recording 1080p ( 1920x1080 , 30 frame / seconds ) hd camera
    other video nocturnally mode
    multimedia player
    music player support mp3 , acc , amr , ogg , m4a , mid , , , wma flac ape aac , , etc wav format
    video player support rmvb , mp4 , h . 263 , h . 264
    player pictures support jpeg , png , gif , etc bmp format
    flash player support
    radio support
    sensor
    gravity sensor support
    sensor distance support
    light induction support
    electronic compass Support
    other function
    automatic switching support
    power off alarm clock support
    hall switch support
    adapter otg function support
    wifi hotspot function support
    double mike xiangzao function support
    wi-fi direct support
    charge reminder light support
    multi-colored breathing light support
    flip mute support
    flip screen quenches support
    usb interface 3.0 support
    fast charge support
    quindi mi sembra da prendere in considerazione,soltanto chiedere per le altre funzioni che non sono scritte tipo air gesture,nfc ecc,purtroppo non hanno risposto e non so cosa pensare sia per il prezzo basso sia per le caratteristiche
    Ultima modifica di lillo74; 19-02-14 alle 01:54
    Senior Droid L'avatar di shopngoit
    SZ
    MEIZU X4
    Ringraziato 146 volte in 129 Posts
    Quote Originariamente inviato da JoJo2000 Visualizza il messaggio
    Facendo una ricerca su Pandawill ho trovato il Tengda S9 Smartphone Android 4.2 MTK6592 5.0 Inch FHD Screen 2GB 32GB OTG NFC 3G. Qualcuno conosce questa marca?
    Quello è lo STAR S9, TENGDA è solo un marchio "inesistente", di fatto il cellulare è prodotto dalla STAR
    FIRMWARE/ROM DOWNLOAD esclusivo: http://cinafoninidual.altervista.org
  4. #603
    Jan 2014
    Bergamo
    iPhone 11 128GB
    a lillo74:
    Sbaglio o ricorda anche dal nome il mlais79t pro?
    C'è pure una discussione in cui si parla dei problemucci che avrebbe.
  5. #604
    Androidiano L'avatar di zatto00
    ZTE Nubia z7 max
    Ringraziato 30 volte in 16 Posts
    chiamalo pure gophone n3... restituito a tempo di record...
  6. #605
    wlf
    wlf non è in linea
    Androidiano VIP L'avatar di wlf
    Ringraziato 259 volte in 221 Posts
    Quote Originariamente inviato da freedgt Visualizza il messaggio
    scusate per l'intromissione ma le vere novita si avranno in estate o dopo, con i nuovi 6595 con il supporto 4g e il caricamento della batteria via wifi, inoltre e previsto il supporto fino a 20 megapixel per la fotocamera, e supporto video per le alte risoluzioni, dunque consigliato attendere un attimino
    Ni.
    E dopo gli octa-core MT6595 si apriranno le danze per i nuovi processori 64-bit sia quad che octa-core!
    E dopo di questi ci saranno nuovi passi in avanti ...
    Finora, dai mono core, dual-core, quad-core, octa-core abbiamo avuto una escalation tecnologica non indifferente; si parla di memorie RAM e ROM più veloci, di GPU sempre più efficienti, processi produttivi (40Nm, 32Nm, 28Nm, etc), efficienza energetica, etc. Limitandoci poi a considerare solamente gli aspetti che riguardano la CPU; ma poi c'è pure una evoluzione di tutto quello che gli sta attorno.
    Tu quindi consigli di attendere un attimino? A mio avviso anche se attendi è probabile che tu scelga un prodotto che sarà comunque transitorio ... servirebbe la palla di vetro!
  7. Il seguente Utente ha ringraziato wlf per il post:
    ludolo (20-02-14)
  8. #606
    Nei giro di un anno sono passato da uno Huawei Honor a uno Zopo 910, ad uno Jiayu G3t ad uno Jiake X3s ( mtk6577, mtk6589, mtk6589t e mtk6592). La mia è passione: c'è chi cambia l'auto ogni 2-3 anni e chi cambia telefono ogni 3-4 mesi. E i produttori lo sanno. La tecnologia non si può arrestare: se sei un appassionato ti butti su ogni novità!
    Inviato dal mio ZP900H usando Androidiani App
  9. #607
    Provincia di Treviso
    Galaxy s4, Leeco Le Pro 3
    Ringraziato 203 volte in 189 Posts
    COME TI TROVI CON IL JIAKE?
    non ci sono molte info al riguardo...
    Te ricordito de chea volta? Ierimo mi ti fax e i wurstel...
    Ahhh...ghe ne gavarò contae 8...
    E RICORDATEVI DEL THANKS SE SONO STATO UTILE!
  10. #608
    Mi deve ancora arrivare. Pubblicherò le mie impressioni appena lo avrò fra le mani!
    Inviato dal mio JY-G3 usando Androidiani App
  11. #609
    non lo so,perchè non ho seguito la discussione sul mlais79t,io ho solo visto che visto il prezzo,e le opzioni,non sembra male,poi se lo vedi bene e una copia spudorata del galaxy note 3 ,se ha problemi non so,perchè non lo preso,ho solo dato un'occhiata,cmq ora guardo la discussione sul mlais,o come dice zatto00 gophone n3 che sembra simile
  12. #610
    ZTE Nubia z7 max
    per dovere di cronaca, la mia non bella esperienza con gophone n3 si è conclusa con il completo risarcimento. tanto di cappello alla professionalità di gophone.
