Pagina 5 di 7 primaprima ... 34567 ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 69
[Thread Ufficiale] Timmy E82
  1. #41
    Banned
    Aug 2013
    Ringraziato 145 volte in 115 Posts
    Quote Originariamente inviato da crwm74b4x Visualizza il messaggio
    Qualcuno è riuscito a fare il root?
    Ho trovato questa guida Timmy E82 CWM and Rooting instructions , ma non ho i permessi per scaricare il tool.
    Use the following link to download find attach a copy of the CWM and scatter file for a Timmy E82 smartphone. I found for some reason the scatter file only works with MediaTek SP Flash Tool V5.1343.1. Any other flasher gave me errors.
    Once you have CWM recovery, I did the following to root the device:
    Here's what I did:
    1. Ensure you have CWM flashed first.
    2. Root with this root tool
    3. Download SuperSu from Google Play and install it
    4. Run SuperSU and install via CWM method when prompted, phone should reboot and installed SuperSU in recovery.
    5. Now run SuperSU again and install via normal method.
    6. Go into SuperSU options and use "delete other superuser apps" option.
    7. It should hopefully remove KingUser (Chinese Super User) and then you have a working SuperSU and full reboot.
    8. Check with root checker basic or pro
    9. Download a Busybox installer and install Busybox as well.
    The above worked for me. But I had a lot of trouble rooting this phone, so if it doesn't work don't ask me what I did, because honestly I'm not 100% sure Big Grin
    But, if the above helps or works, hit the thank button
    Ringraziato 2 volte in 1 Post
    Quote Originariamente inviato da basiliom Visualizza il messaggio
    Here's what I did:
    I need the "root tool" because I don't have the privileges to download it.
  4. #43
    Banned
    Aug 2013
    Ho messo il link? Non lo vedi? ' link to download find attach '
  5. #44
    Quello è il link della CWM... quello che mi occorre è il tool di root!
  6. #45
    Banned
    Aug 2013
    Scusami... prova questo:
    Fileecessari:
    PDAnet ADB MTK Drivers
    New Graphical Auto Root
    Istruzioni:
    What to do:
    Make sure USB debugging is enabled. Go to settings > developer options > enable USB debugging
    Install the PDAnet Drivers
    Extract the Graphical Auto Root file from the .rar download
    Connect your phone to PC visa USB
    Run the extracted .exe
    You will see some Chinese mumbo. Tap the button and it will begin to root your MTK6589, MTK6577, MTK6575 phone
    After finished, now reboot
    Bam, you’re rooted. Verify root with a ‘Root Checker’ app from Play, or run any app you know requires root and you should see a root permissions request
  7. #46
    Banned
    Aug 2013
    Un mio amico l'ha preso da ******* ed il root l'ho fatto io con quest'ultimo sistema
  8. #47
    Ho ordinato il telefono per mio padre che non è molto esigente in termini di spazio (al massimo più in là vedrò di aumentare la capacità della memoria interna a 2,5 GB e il resto lo salverò sulla SD esterna). Tra i tanti mt6582 questo mi ha colpito più di tutti sia per gli accessori a corredo sia per la personalizzazione anche se minima del sistema (ed ero indeciso tra il jiake p6, inew v3, il "vecchio" thl w200 e questo). Spero non vada nel dimenticatoio questo thread perchè, apparte il nome bimbominkioso, può dare molto questo telefono imho.
    Basiliom : oltre il root si sa nient'altro per questo terminale? ho girato un po' ma non ho trovato granchè, nemmeno su xda
  9. #48
    Ringraziato 24 volte in 21 Posts
    Io continuo a seguire, non si sa mai ...
  10. #49
    Androidiano L'avatar di SuperScarabeo
    Atri
    xiaomi Redmi Note 4 Global
    Io lo ho appena preso....e bellissimo. Fluido al punto giusto. Sinceramente credo sia più bello dell' i new v3
  11. #50
    Riesci a fare una recensione o un test abbastanza esaustivo delle componenti? In particolare connettività 3/4G, wifi e GPS?
