Pagina 4 di 35 primaprima ... 2345614 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 347
Clone 1:1 Samsung Galaxy S5
  1. #31
    GrossoShop
    Uno dei pochi che al momento utilizza la versione 6592 da 2.0GHz é TCL Idiol.
    Ma non ha nulla a che vedere con i cloni.
    Apr 2014
    ma il prezzo?
  4. #33
    Feb 2014
    Su un sito ho trovato un clone con le seguenti caratteristiche:
    Manufacturer: CEC
    Model: Galaxy s5
    Phone Style: Bar, multi-touch screen, 5.1 inch FHD Gorilla 3 Glass screen
    Operating System: Android 4.4
    Processor: 2.0GHz Octa-core MTK MT6595 processor
    RAM:2GB
    ROM:32GB
    Display
    Screen Size: 5.1inch Gorilla 3 Glass touchscreen
    Display reulotion: FHD screen, 1920*1080 pixel
    Color Support: 26 million colors
    Screen Technology: Multi-touch screen
    Camera
    Camera Resulotion: 16MP rear camera
    2.1MP front camera, digital zoom,Auto Flashlight.
    Connectivity
    Connectivity Technology: GSM + WCDMA + LTE 4G
    Network Band:
    2G:GSM 850/900/1800/1900 MHz
    3G:WCDMA 850/2100MHz
    4G:LTE 4G 5 Bands
    Data Technology: EDGE, GPRS (HSDPA 7.2Mbps, HSUPA 5.76Mbps; EDGE; GPRS)
    Bluetooth: Bluetooth 4.0 + EDR
    WLan: Wi-Fi IEEE 802.11 b/g/n
    USB: USB 4.0
    GPS: GPS/A-GPS (Built-in GPS chipset)
    Features
    Sim card: Single sim(micro sim)
    Dual sim: Dual sim(2 micro sim)
    Color: White,Black,Blue,Golden(leave comments of color and sim type before check out on step 2 of 3),Both color have stock now
    Pre-installed Google Play store.
    Root status:Rooted already(pre-installed Root explorer and Supper User
    Video Player: AVI、MP4、3GP、MOV、MKV、FLV
    Audio Player: FLAC、APE、MP3、OGG、AMR、AAC
    Image: JPG、PNG、BMP、GIF
    Ringing Tones: Downloadable
    Message: SMS, MMS, Email
    Phone Book: 100000 contacts
    Brower: HTML5
    Interface/Port:
    Game: Downloadable
    Radio: FM
    G-sensor
    Range sensor
    Multi-task
    Hand motion
    Getures
    NFC
    S beam
    Nearby devies
    Screen Mirroring
    Eye scroll
    Dual camera
    Smart pause
    LTE 4G
    S health
    Finger Scanner
    Auto brightness adjust
    Interface/Port: 3.5mm earphone jack / mini USB
    BatteryBattery: Li-on battery 2800mAh
    Standby Time: 160-220 hours
    Talking time:22-28hours.
    Multi-Language support:support 39 countries language.
    Memory
    Memory: 32GB(ROM) + 2GB RAM
    Memory Card: Support microSD/microSDHC memory card, up to 64GB, support App2SD
    Please note:this phone have android logo and samsung logo optional,we will send samsung logo version if you not specify.
  5. #34
    Senior Droid L'avatar di shopngoit
    SZ
    MEIZU X4
    Ringraziato 146 volte in 129 Posts
    Da oggi il modello 6572 e' disponibile anche in colorazione oro.
    Il modello 6582 (512+4) ha ottenuto un aggiornamento rom aggiungendo funzionalita' precedentemente non supportate,boot screen modificato (immagino sia quello nuovo presente anche nell'originale S5, il precedente era quello standard presente nel NOTE3 (4.3)) e funzione fotocamera nella lock screen.
    FIRMWARE/ROM DOWNLOAD esclusivo: http://cinafoninidual.altervista.org
  6. #35
    Ma la funzione s-view della flip cover sarebbe realmente funzionante o no? Io l'ho provata ma non fa proprio nulla aprendo e chiudendo..
  7. #36
    Senior Droid L'avatar di ngnr Frank
    Ringraziato 101 volte in 90 Posts
    Interessante questa comparativa tra i due modelli dual/quad core
    DHGate Galaxy S5 Quad Core/MTK6582 VS Dual Core/M…: http://youtu.be/2PnExJNmX9I
  8. #37
    SZ
    MEIZU X4
    Quote Originariamente inviato da Mustaine635 Visualizza il messaggio
    Non ho ancora provato, ed ora non ho terminali qui con me per provare, prossima volta ti so dire. (comunque hai attivato le voci nelle impostazioni?)
  9. #38
    Ringraziato 2 volte in 1 Post
    chi può uppare la rom di una dei due telefoni ?
  10. #39
    Quote Originariamente inviato da shopngoit Visualizza il messaggio
    Ho girato parecchio nelle impostazioni ma nn ho trovato niente al riguardo, in genere sta sotto Display.. Mi sapresti dire sotto che menù sono? Ma credo che sia solo per bellezza la flip..
  11. #40
    Puoi sempre installare una app dal PlayStore, io su un telefono che avevo feci così e feci funzionare la cover, solo che ti consuma più batteria perché i sensori di prossimità rimangono sempre attivi.
