Pagina 1 di 17 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 165
Kingzone n3 lte
    Ringraziato 53 volte in 47 Posts
    Kingzone n3 lte
    Nuovo terminale della Kingzone.
    Caratteristiche:
    GENERAL
    Model KINGZONE N3 LTE
    Dimensions 143.8X71.8X7.5mm
    Weight 139g
    OS Android 4.4 Kitkat OS
    Colour Black 、White
    MAINBOARD
    CPU MT6582+6290 1.3GHz QUAD-CORE 28 nanometer
    GPU MALi-400MP
    Internal Memory 8GB ROM storage , 1GB RAM
    SIM Standard-SIM & Micro-SIM
    Card slot microSD, up to 64 GB
    3.5mm Jack Yes
    DISPLAY
    Size SHARP HD 5.0 inch, 1280 x 720 pixels
    Pixel Density 320 ppi pixel density
    Type LTPS capacitive touchscreen, 16M colors
    Multitouch Yes 5 points
    Protection Corning Gorilla Glass 3, Touch screen waterproof
    CAMERA
    Primary 13.0 MP, phase detection autofocus, LED flash, check quality
    Features Stack Multilayer CMOS(Exmor RS),Simultaneous HD video and image recording, geo-tagging, touch focus, face and smile detection, image stabilization, HDR
    Aperture F/2.0
    Video Yes, 1080p@60fps, 720p@120fps, HDR, video stabilization, dual-video rec., check quality
    Secondary Yes, 8.0 MP, 1080p@30fps, dual video call
    NETWORK & INTERFACE
    Network mode Dual card three mode, LTE FDD +WCDMA+GSM
    Network Band GSM:850/900/1800/2100MHz
    WCDMA:850/900/1900/2100MHz
    LTE: FDD 800/1800/2100/2600MHz
    Standby Mode Dual SIM card Dual standby
    Speed Downlink 150 Mbps, Uplink 40Mbps
    GPRS Yes
    EDGE Yes
    WLAN Wi-Fi 802.11 a/b/g/n/dual-band, DLNA, Wi-Fi Direct, Wi-Fi hotspot, Wifi-display
    Remove Mobile AP Yes
    Navigation GPS,A-GPS
    Bluetooth Yes, v4.0 with A2DP, EDR, LE
    NFC Yes , MT6605N/A
    Infrared port NO
    USB 5 PIN, USB On-the-go, USB Host
    OTG Yes,5 PIN
    Earphone interface 3.5MM
    FEATURES
    Fingerprint Identification PASSION U101,password function; secure communication; moving your Finger left or right 、
    down or up over the sensor to control the app
    windows function Yes,working with case
    Operating system Android 4.4 Kitkat OS
    Sensors Electronic compass、Hall IC、 Light sensor、Proximity sensor、Graximty sensor
    Breathing light Yes
    Messaging SMS(threaded view), MMS, Email, Push Mail, IM, RSS
    Browser HTML5
    Radio Yes,FM Radio
    AUDIO AND VIDEO SYSTEM
    Audio decoder YAMAHA HIFI YDA165
    Sound System AAC BOX
    Sound Effect DTS Dolby
    Microphone Patch type double silicon microphone
    Video shoot RMVB、3GP、 MPEG-4、AVI
    Video playback 1080P
    Audio Codec AAC/AAC+/AMR/AWB/MP3/VORBIS/FLAC/APE/MIDI/ IMELODY/WAV
    Audio and video format mp3、mp4、3gp、ogg、amr、aac、flac、wav、midi
    Ring Type MIDI,MP3,AMR-NB,WAV,OGG,AAC
    Flash Player Support
    BATTERY
    capacity Li-Ion 2800 mAh battery
    Stand-by Up to 390 h
    Talk time Up to 21 h
    Music play Up to 67 h
    Standard Accessories
    Battery 2800 mAh x 1 PCS
    Charger 1A
    Headset 3.5mm Interface
    Data Cable 5 Pin
    OTG Cable 5 Pin
    User Manual ENGLISH
    Giftbox 162.5x151.5x36.5mm
    Optional Accessories
    Smart windows cover With NFC antenna, you can see time/ data、
    play music through the window and also can get the message prompt from window sleep funtion
    In uso da circa 10 giorni. Il massimo per il prezzo di vendita.
    Ottimo schermo, GPS perfetto, audio Ok.Unico problema se cosi si può definire, è che non si possono spostare i programmi sulla SD esterna.
    Oneplus 8T 12/256
    Ringraziato 3,575 volte in 2,637 Posts
    speriamo che abbia maggior supporto della casa costruttrice rispetto allo ZERO dato al K1, bellissimo e subito abbandonato...ma ho forti dubbi che sara' cosi'...
    Sembrano animati da buona volontà. Rispetto alla settimana scorsa hanno aggiornato la pagina N3 con link per futuri aggiornamenti
    Inviato dal mio KINGZONE N3 LTE usando Androidiani App
    Quote Originariamente inviato da bluemask Visualizza il messaggio
    Messaggio sul sito ufficiale:
    ANDROID 5.0 WE BE AVAILABLE VIA OTA.
    In questo caso sembra che non abbandonano lo sviluppo come col K1.
    Oneplus 8T 12/256
    Quote Originariamente inviato da zagoweb Visualizza il messaggio
    mah lo spero per te e per chi si avventura ad acquistare prodotti di questa fantomatica azienda (e come ce ne sono tante altre di questo tipo)...
    Piu' che altro l'augurio e' che l'ipotetico WILL BE proclamato si traduca realmente in IS (c'e' una bella differenza a far proclami..e poi a mantenere quanto detto) ...anche di kitkat avevano assicurato per il k1 che ci sarebbe stato l'upgrade disponibile in settembre poi ottobre poi novembre e poi... e poi...e poi....il nulla..e sono ancora lì nel thread ad aspettarlo (penso in pochi ormai)..
    Ultima modifica di bluemask; 02-01-15 alle 08:19
    Mi auguro che il tuo pensiero si sbagliato. Magari fanno anche la sorpresa per i possessori del K1 con l’aggiornamento a Lollipop. Penso che se vogliono entrare nel mercato europeo devono garantire un minimo di assistenza e aggiornamenti ai loro prodotti. Dobbiamo anche dire che produttori molto più famosi (S…..) hanno abbandonato gli aggiornamenti per prodotti di punta molto presto (vedi S2, S3, etc), perché meravigliarci se lo fa un produttore sconosciuto o quasi. Probabilmente è il marketing che porta a ciò.
    Dopo oltre 20 giorni di utilizzo sono molto soddisfatto del cellulare; provengo da uno ZP780 (ceduto a mia moglie) che, comunque, è un buon prodotto (una pecca il gps), ma realizzato con materiali qualitativamente inferiori. Il cellulare presenta un ottimo design, ha una sua linea e non è sicuramente un clone, è sottile e leggero, costruito con materiali di ottima qualità e con dettagli ottimamente curati. Offre una dotazione completa con caricabatteria, cavo USB, uno screen protector, cuffie, un guscio in silicone, un cavo OTG, e come extra una cover a libro in pelle (alcuni venditori la regalano). La qualità delle foto è buona. Il display è luminoso. Buone le prestazioni in 3G e 4G. Quello che lascia a desiderare è la batteria con la quale non si riesce ad arrivare a sera con un uso medio/alto. Serve un power bank al seguito.
    Annunciata la versione N3 Plus
    N3 Plus is equipped with MT6732A,it's a 1.5GHz 64Bit processor. The memory is 2GB RAM+16GB ROM,support TF card up to 64GB extended. The more powerful CPU and bigger memory will undoubtedly make this phone an excellent "N3 Plus".
    The Rom for N3 Plus is based on Android 4.4KitKat,with a brand new UI design and more humanized operation experience. Besides, this rom is also integrated with the new battery life enhancement technology, which is a great help to make the battery more stable and last for a longer life. Also,Android 5.0 will be upgraded in the future.
    Intanto il K1 ha avuto l'aggiornamento a KK. Tanto fantomatica come azienda non sembra.
  9. #8
    Oneplus 8T 12/256
    finora lo é stata...cmq buon per voi se migliora
  10. #9
    Dal sito ufficiale: primo aggiornamento di KK
    N3 ROM
    Documentation:1. The problem of slow response when playing large games is solved.
    2. System stability is optimized.
    Document size: 425MB
    Updated: 2015-01-07
  11. #10
    Androidiano L'avatar di Beikurt
    Palermo
    Redmi Note 3 Pro 3/32 Kenzo
    Ringraziato 97 volte in 61 Posts
    Ciao ragazzi, stavo pensando di cambiare il mio Brondi Gladiator 2 per via delle tante delusioni avute, prima fra tutte l'assenza totale di aggiornamenti e la pessima assistenza della casa madre, per non parlare della totale mancanza sul web di ROM per il ripristino in caso di errori.
    Leggendo le schede e comparando le offerte, ho notato che per ora ***fox lo spedisce dalla germania con un coupon da 20 euro di sconto per un totale di 150 euro.
    Adesso, avendo anche visto unboxing e video, ma avendo trovato ben poco materiale mi rivolgo a voi per un paio di domande veloci prima di comprarlo.
    -Si può rootare? Non ho trovato guide in merito a questo modello sul web.
    -Al cellurare manca davvero della frequenza 900 mhz per il 3g? Alcuni dicono non sia supportata ma sulle schede tecniche c'è scritto di si.
    -Il cellulare riceve aggiornamenti FOTA dalla casa madre? Avrà Lollipop?
    -La batteria dura davvero poco per via di una cattiva gestione del deepsleep?
    -Avete notato difetti di sorta? Lo consigliate?
    A me piaceva, nonostante il processore non potentissimo per la ricca dotazione (NFC e 4G) e il prezzo competitivo, ma vorrei saperne davvero di più.
    Ultima modifica di Beikurt; 17-01-15 alle 13:33
