Pagina 16 di 184 primaprima ... 614151617182666116 ... ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 1839
Tablet Altroconsumo - Modello RK312x (CPU RK3126 quad core 1.2GHz)
  1. #151
    Androidiano L'avatar di cioce
    Ferrara
    Sony Xperia Z5 Compact
    Ringraziato 71 volte in 50 Posts
    Ragazzi ma se lo volessi usare senza la SD?
    Avevo fatto tutta la procedura con una SD dentro, e dentro questa SD mi aveva creato tutte le classiche cartelle di Android, ma se volessi usarlo senza c'è modo di gestire la MOD che forza la SD come se fosse la memoria interna?
    Devo editarmi a mano il file /etc/vold.fstab ? Se si come?
    ## Vold 2.0 Generic fstab
    ## - San Mehat (san@android.com)
    ## Regular device mount
    ## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
    ## label - Label for the volume
    ## mount_point - Where the volume will be mounted
    ## part - Partition # (1 based), or 'auto' for first usable partition.
    ## <sysfs_path> - List of sysfs paths to source devices
    ## Example of a standard sdcard mount for the emulator / Dream
    # Mounts the first usable partition of the specified device
    #dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
    #dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
    dev_mount flash /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
    dev_mount sdcard /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9
    dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb
    ## Example of a dual card setup
    # dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
    # dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1
    ## Example of specifying a specific partition for mounts
    # dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
    Ultima modifica di cioce; 21-05-15 alle 11:20
    Sony Xperia Z5 Compact (E5823 ITA) | Operatore Wind
    Tablet "Nameless Altroconsumo" | ROM 4.2.2 Jelly Bean custom root Oma ESP build v1.2
    kav
    kav non è in linea
    Feb 2014
    Ringraziato 10 volte in 6 Posts
    Quote Originariamente inviato da sycret Visualizza il messaggio
    non ho resistito..
    ho installato la rom di Ova..
    sembra funzionare tutto..
    solo che non ruota lo schermo nella pagina delle applicazioni.. quando si apre un'app invece si, ruota..
    .. sembra piu reattivo..
    con la rom che hai installato funziona la modalita' OTG? io non ho fatto nessun root, ho acquistato il cavo otg (usb---- mini usb) e collegando la pennina usb non succede nulla e non funziona, sapete se questa funzionalita e' supportata (io penso di di) c'e' qualche modo per farla funzionare o bisogna fare il root e cambiare rom?
    siccome da molte recensioni ho letto che supporta OTG, vorrei farlo funzionare senza fare root, e instalare rom.
    ma se dovesse funzionare con il root potrei pensarci a farlo. qualcuno di voi ha provato la modalita' OTG?? IO VORREI USARLA PER COLLEGARE CHIAVI USB E UN TASTIERINO QWERTY.
    Ultima modifica di kav; 22-05-15 alle 02:56
  4. #153
    Apr 2011
    Torino
    GT-i9100 & GT-P3110 & SM-G900F
    Ciao ragazzai per caso qualcuno ha messo cyanogenmod come rom?
    ______________________________________
    SM-G900F
    Rikomagic MK802III
    GT-i9100
    GT-P3110
  5. #154
    Androidiano L'avatar di DeepRed89
    ma perché? esiste per questo tablet la CM?
  6. #155
    Aug 2014
    Win 7 non riconosce il tablet, lo ricarica solo. come devo fare? risolto, sbagliavo porta usb sul tablet
    Ultima modifica di ciccioven; 23-05-15 alle 10:10
  7. #156
    Senior Droid L'avatar di xandreasx
    Sep 2010
    Xiaomi Mi8
    Ringraziato 90 volte in 80 Posts
    Ciao ragazzi!
    A me ancora deve arrivare,ma avete provato a fare un overclock?(root+setcpu)
    E' possibile oppure bisogna mettere un kernel modificato?(che forse non esiste :/)
    Recensioni,Test e molto altro!
    Vienici a trovare su Youtube
  8. #157
    kav
    kav non è in linea
    Feb 2014
    ragazzi qualcuno usa la modalità OTG in questo tablet. mi serve una risposta il prima possibile per favore. E se qualcuno la usa mi dice come ha fatto per usarla?
    Io ho letto in molte recensioni che ha la modalità OTG, ma quando inserisco il mio cavo-adattatore OTG (USB FEMMINA - MINI USB) NON FUNZIONA NIENTE
  9. #158
    Mar 2010
    tutto bene, ma quando provo ad installare cwm mi da errore
  10. #159
    Quote Originariamente inviato da kav Visualizza il messaggio
    se vai in impostazioni--->memoria (archiviazione), in basso al menù ti dice se è presente una memoria USB?
  11. #160
    Nov 2010
    Qualcuno potrebbe confermarmi che sia possibile disdire entro 15 giorni dalla scadenza dei 60 giorni di prova? Avevo letto di questa possibilità, ma non ne trovo traccia nelle "Note legali" di Altroconsumo.
    Ho effettuato due abbonamenti tra i miei familiari, che oramai sono arrivati uno al 55° ed uno al 57° giorno dalla sottoscrizione, ed ancora nessuna traccia dei tablet, e vorrei capire se devo inviare la disdetta subito o posso attendere ancora un paio di settimane nella speranza che li spediscano.
    Ultima modifica di mauveron; 25-05-15 alle 15:16
    Ho felicemente concluso trattative con: Frank7plus, winning, antonycapo, maxdal89, fcm86
  12. Il seguente Utente ha ringraziato mauveron per il post:
    xandreasx (25-05-15)
