Pagina 23 di 127 primaprima ... 1321222324253373123 ... ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 1265
[INFO][ZE551ML] Aggiornamenti Ufficiali ZE551ML
  1. #221
    Moderatore L'avatar di MatteXperiaU
    Nexus 5X
    Ringraziato 229 volte in 186 Posts
    【Version】
    V2.20.40.97_20150917
    【Model Name】
    ZenFone2 (ZE551ML)
    【Release Date】
    2015/09/22
    【Release Note】
    1 Fix Power and Boost duplicated icon issue
    2 Fix System UI randomly crash issue when in Turkish language
  2. Il seguente Utente ha ringraziato MatteXperiaU per il post:
    harlandraka2 (22-09-15)
    Ringraziato 20 volte in 16 Posts
    Vi riporto il messaggio di un rappresentante ASUS attivo nel subreddit del zenfone2:
    Hey everyone!
    I know I haven't posted too much on here, but I wanted to keep you all up to date with what's going on. I just met with a great guy from a part of our team responsible for the UI/UX of our phones. We had a long discussion about the progress they are making and trying to do what's best for customers and for ASUS, but these are the things that came out of it:
    The team will be reducing the amount of bloatware on all devices
    They will also change how Auto-Start Manager works, or at the very least notify what changes are being made. I spoke in depth about everyone's concerns and how it made one of our community members late for work - so they'll look into either keeping the settings you've got and/or give everyone the ability to change upon updates
    Possibility of customizing apps if you have a View Flip Cover so it can notify you of messages from Gmail vs. Email, and/or Hangouts/(messaging app of choice) vs. ASUS Messaging
    Minimum brightness filter. So instead of being a filter, they'll try to resolve this and make it built into the kernel...so hopefully battery will be improved here.
    5.1 or 6.0...nothing official yet, but I will talk to our phone business unit soon. Word on the street is that the team has been possibly working on some gooey goodness. I don't know more than that and cannot confirm. Stay tuned.
    Nulla di nuovo su Android M :/
  5. #223
    Ringraziato 25 volte in 20 Posts
    ho letto dei reset e l'aggiornamento solo ora, quindi ora è uscito questo, come devo procedere coi reset?
  6. #224
    Feb 2011
    Ringraziato 123 volte in 77 Posts
    Quote Originariamente inviato da Pocho Visualizza il messaggio
    Fai il ripristino solo se necessario. Queste modifiche sono minime. Se non l'hai mai fatto dopo il cumulo di aggiornamenti dopo l'acquisto alla tuo conviene farlo
    Inviato dal mio ASUS_Z00AD usando Androidiani App
  7. Il seguente Utente ha ringraziato paolodoc per il post:
    Pocho (22-09-15)
  8. #225
    Nov 2014
    ????? Scusa l'ignoranza Paolodoc ma esattamente di quali reset parliamo??? ho sempre fatto gli aggiornamenti ma nessun reset?? devo farli?? Come???
    Quote Originariamente inviato da paolodoc Visualizza il messaggio
    Ultima modifica di thereferee; 22-09-15 alle 15:27
  9. #226
    Quote Originariamente inviato da badtwin1970 Visualizza il messaggio
    Dopo aver fatto gli aggiornamenti fai un hard reset: https://www.youtube.com/watch?v=ry6x0PpjlQ8
    Come ha già detto paolodoc se il reset è già stato fatto dopo gli aggiornamenti pesanti dei mesi passati non conviene rifarlo dopo aggiornamenti piccoli come ques'ultimo.
  10. Il seguente Utente ha ringraziato hein per il post:
    badtwin1970 (23-09-15)
  11. #227
    Non basta reset wipe cache?? Io dopo ogni aggiornamento faccio solo quello l'hard reset sarebbero ore ed ore di lavoro dopo per ripristinare tutto
  12. #228
    Feb 2011
    Quote Originariamente inviato da Turrican74 Visualizza il messaggio
    Dovrebbe bastare il wipe cache. Tuttavia ormai sono così tanti gli aggiornamenti che almeno a chi lo compra nuovo gli conviene prima di iniziare a configurare il telefono. Ci sono tanti che si lamentano di problemi di consumo che spariscono dopo il ripristino. Se tu non hai problemi non lo fare. È solo una garanzia che tutto funzioni bene dopo un corposo aggiornamento.
  13. #229
    NOTE 2
    Ragazzi con l'ultimo aggiornamento di asus Launcher vi capita che se create le cartelle smart, la cartella produttività e quella strumenti vengono visualizzate male in quanto si vedeno le app tagliate a lato dello schermo?
  14. #230
    Perfetto... Per ora va bene.... Unica cosa strana dopo gli aggiornamenti corposi tendeva i primi 2 giorni a riavviarsi spesso da solo... Poi è andato tutto bene... Mistero
