Utente del mese: megthebest con ben 21 Thanks ricevuti nell'ultimo mese
Pagina 9 di 127 primaprima ... 78910111959109 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 1265
[INFO][ZE551ML] Aggiornamenti Ufficiali ZE551ML
  1. #81
    Aug 2015
    Quote Originariamente inviato da scorpion90 Visualizza il messaggio
    Hai qualche file di sistema danneggiato, hai i permessi di root?
    Hai mai provato a scaricare l'intero firmware dal sito asus e ad installarlo?
    no, ma non capisco come mai visto che ho solo fatto aggiornamenti ufficiali e tramite OTA. mah comincio a spazientirmi.
    Ringraziato 43 volte in 33 Posts
    E' uscita una nuova versione: ZE551ML_ WW_V2.20.40.59
    【Version】
    V2.20.40.59_20150807
    【Model Name】
    ZenFone2 (ZE551ML)
    【Release Date】
    2015/08/12
    【Release Note】
    # Optimization for WW
    1 Fix WIFI info sync-up issue
    2 Improve System UI and lock screen stability
    3 Improve Launcher App stability
    4 Fix Alarm function issue after set up in Snap View mode
    5 Improve Task Manager
    6 Optimize Multi user and Do not disturb mode function stability
    7 Fix camera sphere panorama issue
    8 Improve Auto Start Manager stability
    9 Fixed when AC removed, UI still shows in charge mode.
    10 Fixed Cisco Anywhere VPN connectin fail issue
    11 Fix Wi-Fi hot spot MAC address
    12 Fixed issue that noise comes out when use earphone.
    13 Fixed UI shows only can making emergency call issue
    14 Fixed vibrate function fail.
    15 Fixed NFC can not auto connect to BT earphone.
    16 Fixed can't transfer files through NFC(android beam)
    17 Fixed can't use Kingston 32G SD
    18 Fixed auto enable MTP issue.
    19 Fixed Screen won't turn on after hang off the phone.
    20 Fixed no show PCCW issue.
    21 Fixed Wi-Fi hot spot can not be access by Xbox360
    22 Fixed 4G internet issue.
    23 Fixed ID operator can't get H+ issue
    24 Fixed internet icon disappear issue.
    25 Fixed charge issue.
    26 Implement Android security patch for Stagefright
    27 Fixed tha issue: In vibrate mod, the ringtone is too loud by using headphones.
    28 Fixed Puzzle & Dragons crash issue.
    # New Features for WW
    1 Add Hands up
    As phone is ringing, hold phone in portrait mode and lift to touch the ear to answer the phone.
    2 Added Mobile Manager app which has six major functions:
    - Data usage: Controls the apps' data usage
    - Notifications: Manages annoying notifications
    - Auto-start Manager: Manages auto-start apps running in the background
    - Boost: Boosts memory
    - Power Saver: Provides various battery modes to extend the battery life
    - Virus Scanner: Scans virus and malwares
    3 Add Flip cover function
    Add new Clock theme
    Add VIP icon in Clock view for SMS/email/missed call
    Add timer reminder
    Add charging reminder
    4 Add Cover View function
    New clock theme
    Allows detail checking of everyday events in Calendar view
    Supports Spotify on Music app
  4. #83
    Asus Zenfone 2 ZE551ML
    Ringraziato 31 volte in 30 Posts
    Hai provato il ripristino dati di fabbrica?
    One Plus 3
    HTC EVO 3D
  5. #84
    Aug 2015
    riguardo l'aggiornamento state facendo un po' di confusione:
    metodo 3
    scaricate l'aggiornamento e posizionatelo nella memoria interna, questa volta è la memoria interna, non la micro sd, e rinominate il file in "UL-Z00A-WW-2.20.40.58-user.zip" e riavviate normalmente il telefono. dopo il riavvio lo zenfone dovrebbe rilevare automaticamente l'aggiornamento chiedendovi se volete installarlo.
    sto provando ad attuare il metodo 3 ed anche così non riesce, mi da nuovamente errore.
    Ultima modifica di MatteXperiaU; 12-08-15 alle 10:11 - Motivo: Modificati i quote
  6. #85
    Il metodo 1 lo hai provato? Ricorda di salvare i dati personali, non si perdono i dati ma un backup è sempre meglio.
    Potresti provare questo https://www.androidiani.com/forum/sh....php?p=7010530
    Ultima modifica di scorpion90; 12-08-15 alle 10:07
    One Plus 3
    HTC EVO 3D
  7. #86
    Moderatore L'avatar di MatteXperiaU
    Nexus 5X
    Ringraziato 229 volte in 186 Posts
    Quote Originariamente inviato da paneb73 Visualizza il messaggio
    Ti ho modificato i quote sballati..attenzione che l'app androidiani a volte lo fa
  8. Il seguente Utente ha ringraziato MatteXperiaU per il post:
    paneb73 (12-08-15)
  9. #87
    Baby Droid L'avatar di mathd
    Jul 2015
    Campania
    Asus ZenFone 2
    Segnalo che stamattina mi ha fatto il 2.20.40.59
    Da quello che ho trovato in rete per il changelog il .59 si limita solo a: "Implement Android security patch for Stagefright"
    Ultima modifica di mathd; 12-08-15 alle 10:40
    Asus ZenFone 2 ZE511ML + Asus Flip Cover Deluxe - v.5.0
  10. #88
    Leggi il post numero 82 oppure vai su zentalk e troverai il changelog completo.
    One Plus 3
    HTC EVO 3D
  11. #89
    May 2014
    Dopo che per giorni non mi trovava l'ultimo aggiornamento, effettuata la ricerca e trovato il .58, installato ed effettuata nuova ricerca, trovato il .59, installato ed adesso vediamo come va.
    Inviato dal mio ME301T usando Androidiani App
  12. #90
    Aug 2015
    RISOLTO il problema dell'aggiornamento firmware in errore: ricapitolando non riuscivo tramite OTA e metodo 3 di cui al post precedente l'aggiornamento dal v. 18.40 al 19.40.20 . Grazie all'intervento dell'assistenza ASUS che mi ha risposto entro 24 ore, ho potuto risolvere il problema :ho scaricato prima sul pc il firmware completo da 1,1 GB e dopo averlo copiato nella memoria interna ed aver scollegato il cavo USB , è partito subito l'aggiornamento che ha richiesto un pò di tempo, ha ottimizzato 119 app e riavviato regolarmente il cell.
