Pagina 6 di 13 primaprima ... 45678 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 127
[Thread Ufficiale] Doogee Y100 PLUS 5.5" HD MT6735M 2Gb/16Gb
  1. #51
    Jan 2011
    Ciao, a me è stato appena consegnato, ordinato sabato su Amazon.it in offerta a 103,99. Chi conosce una procedura buona per il root senza usare kingoroot che installa tutte quelle cineserie difficili da rimuovere? Grazie
    Feb 2014
    Marche
    Grandi, Grossi... Cinafonotti
    Ringraziato 8,542 volte in 6,492 Posts
    Quote Originariamente inviato da pippopelo Visualizza il messaggio
    se non vuoi usare Kingroot, serve la recovery TWRP da compilare partendo dal kernel e la rom stock presente su needrom..
    alternativa, non testata su Y100 Plus (ma testata con successo su Y100 pro)
    Root access
    Usually Mediatek devices come rooted out of the factory with a SuperUser toggle to enable in the security settings, this device does not but I found a way to flash SuperSU using the stock recovery.
    This process has been tested but it might soft brick your phone and, as of today, there is no FlashTool flashable rom that will recover a device from such brick state.
    Anyway, if you feel brave enough, download this zip
    https://mega.co.nz/#!cx4xmT7a!OOv35G..._HGYgaQOCEVFvo
    (please don't re-host it or alter the link as I would like to track down the download statistics) and copy it to your MicroSD card.
    Power off the device and turn it on keeping VOL+ and Power until you see some tiny text.
    Select the first option (Recovery mode), use VOL+ to navigate and VOL- to confirm.
    Once booted to stock recovery select "apply update from sdcard" using VOL+/- to navigate and POWER to confirm, and select the zip file you copied to the MicroSD.
    After the flash has completed you will be back to recovery's main screen and just select "reboot system now".
    PS: this zip file should work with any MT67** device running a stock Mediatek recovery
    Però devi essere consapevole che potrebbe bloccare il telefono alla schermata di boot, poi devi rimettere la rom stock che trovi su needrom tramite il programma flashttool mediatek tramite pc con windows
  4. Il seguente Utente ha ringraziato megthebest per il post:
    pippopelo (15-03-16)
  5. #53
    Baby Droid L'avatar di cogand
    Jun 2015
    BAT
    Huawei P8 Lite - ME372CG
    Buonasera, domani è in offerta sulle amazzoni con cover posteriore e stand kkmoon...credo intorno ai 100-110 €..
    Lo ritenete un buon acquisto a quel prezzo o mi consigliate di indirizzarmi su altro??
  6. #54
    Jan 2011
    Devo farmi un backup dei dati prima di rimettere la stock in caso di blocco? Ho messo nelle opzioni del telefono che deve usare la sd esterna per la memorizzazione e ora la legge come sdcard0 mentre nel vecchio samsung era riconosciuta come extsdcard. Non vorrei che con questa opzione cancellasse il contenuto di sdcard0.
  7. #55
    Jan 2011
    Scusatemi se faccio un altra domanda. Come firmware ne ho uno di ottobre 2015. Su needrom ho visto che ce ne sono due, uno di dicembre e uno (algerian) di gennaio 2016. Non so la differenza tra uno e l'altro. Se cerco aggiornamenti dalle opzioni mi dice che è aggiornato.
  8. #56
    Feb 2014
    Marche
    tutto Ok, è una funzione di swap che quando metti la sd la imposta come primaria..
    quello algerian lascialo stare.
    attendi un update ufficiale da Dogee.
  9. Il seguente Utente ha ringraziato megthebest per il post:
  10. #57
    A chi puo interessare si trova sulla baia a circa €.82,00 e anche meno, io ancora non mi decido perchè ho necessità di uno smartphone con un altoparlante dal suono veramente forte e sono titubante per questo!!
  11. #58
    Jun 2015
    BAT
    Quote Originariamente inviato da camelotto Visualizza il messaggio
    io mi sono appena aggiudicato un asta a 77,00 € da un venditore (cinese??) con spedizione da formello...speriamo bene!!
  12. #59
    Jan 2011
    In questo momento è di nuovo in offerta Prime sulle amazzoni, 89,99. A saperlo aspettavo qualche giorno.
  13. #60
    Jun 2015
    BAT
    Io alla fine con un coupon del 10% per il pagamento con paypal mi è costato 69,00..credo un ottimo prezzo alla fine..certo è che con 20€ in più lo avrei preso dalle amazzoni che è una garanzia..sono ansioso di riceverlo!!
