[APP] Smart Screen ON
    Jan 2011
    Perdonatemi se posto in inglese, ma la traduzione italiana con google translator è pessima:
    After the success of Smart Screen OFF, I decided to publish another app called Smart Screen ON available in LITE and PRO version too.
    Smart screen ON
    Smart Screen ON LITE
    DESCRIPTION:
    Smart screen ON is an innovative app which turns your proximity sensor into a power button. If you have a big phone with no physical button on the front(Galaxy Nexus for example, you can turn on or turn off the phone just tapping or waving your hand (finger) on proximity sensor.
    FEATURES:
    When you change the settings, remember saving and restarting service using built in app specific button.
    There are two mode available, both mode can coexist:
    +WAVE MODE:
    Wave (move) your hand/finger on proximity sensor, even without touching it.
    You can set the amount of waves you want to use to turn on/off screen and the time between each wave.
    Do you want to wave your hand quickly or slowly?
    +TAP AND SWIPE MODE:
    1) Tap proximity sensor using your finger;
    2) Wait for the first vibration;
    3) Swipe (remove) quickly your finger, before it vibrates for the second time.
    You can set the time before the first and the second vibration.
    +DISABLE SENSOR
    You can also disable sensor after an amount of time you can set in the app panel.
    The app will disable the whole service and proximity sensor after X time of inactivity.
    +STATISTICS
    Statistics include:
    A)Smart Screen ONs;
    B)Smart Screen OFFs;
    C)Total power button saves;
    D)The power used by your proximity sensor (which is very very low).
    +START ON BOOT
    If you check this, the app will start on boot.
    +HIDE ICON
    If you hide the icon, the app could be instable and could be killed by Android in low memory conditions.
    +ENABLE FOR TURNING SCREEN OFF
    The app has been created to turn screen off, but I also give you the ability to turn screen off.
    +DISABLE WHEN LANDSCAPE
    The sensor will stop working when landscape.
    +INCOMPATIBILITY
    -HTC Desire HD is not compatible with "wave mode" because its proximity sensor doesn't work as it should.
    If you want to suggest new features, please contact me on this thread, at ddeleted@gmail.com or use my site AndroidHD - Trucchi e Applicazioni Android HD!
    Banned
    Io ormai non ne posso fare a meno sul mio g nexus.. senza toccare nulla solo col movimento del dito o su o giu i destra e sinistra lo attivo dal stand by o lo spengo.. ovviamente crakkato
    Androidiano VIP L'avatar di alenyc
    Aug 2010
    Bergamo provincia
    Galaxy S4 white frost
    Ringraziato 114 volte in 99 Posts
    Comodo è comodo ma non consuma più batteria?
    In pratica il sensore prossimità è sempre attivo....
    2010: htc desire
    2011: samsung galaxy s2
    2012: samsung galaxy nexus
    2012: samsung galaxy s3
    2013: samsung galaxy s4
    2014: samsung galaxy note 3
    2015: LG G4
    Androidiano L'avatar di qamrij
    Aug 2009
    Galaxy nexus
    Ringraziato 14 volte in 11 Posts
    a parte che il sensore non ciuccia cosi tanta batteria ma cmq puoi scegliere anche il tempo per disattivare il servizio. cosi non consuma niente.
    Ah ovviamente IO L'APP L'HO ACQUISTATA XKE 99 CENT SN NIENTE E PER FAVORE NON SCRIVETE SE LI INSTALLATE CRACCATI PERCHE ANCHE SE SONO APP CHE COSTANO POCO NON SIGNIFICA CHE NON VALGONO. E RISPETTATE IL LAVORO DEGLI ALTRI
    Androidiani Power User L'avatar di d128b
    Jun 2010
    spica,wave,nexusS,xperiaZ
    Ringraziato 722 volte in 409 Posts
    Ricordo a tutti gli utenti di leggere il regolamento (che avete accettato di rispettare alla registrazione dell'account) dove è scritto che in questo forum il warez non è tollerato.
    Xperia Z 1 compact @ stock
    Flash! - un amaro racconto di vita
    che ha riportato in vita il mio nexus S quando tutto sembrava perduto)
    Jan 2011
    Quote Originariamente inviato da qamrij Visualizza il messaggio
    Grazie! Se fossero tutti come te il Play Store sarebbe stracolmo di ottime applicazioni. Altro che app store...
