Visualizza i risultati del sondaggio: quale utilizzi???
Chi ha votato
65. Non puoi votare questo sondaggio
  • iNsertCoin HD A2SD+
    49 75.38%
  • iNsertCoin HD DATA2EXT
    15 23.08%
  • iNsertCoin Z
    1 1.54%
Pagina 20 di 99 primaprima ... 1018192021223070 ... ultimoultimo
Visualizzazione dei risultati da 191 a 200 su 983
[ROM][16/02]iNsertCoin HD/Z Port 1.9.1 /1.8h 720p REC|STABLE|FAST|1.84/1.72 Base
  1. #191
    Senior Droid L'avatar di lisoform2003
    Feb 2011
    Samsung Galaxy Alpha Silver
    Ringraziato 15 volte in 8 Posts
    grazie... ma esiste un changelog per vedere le differenze?
    Feb 2011
    - added back dalvik to sd
    -1.9.3
    - optimized all apks
    - removed lot of crap
    - due to optimization and removing crap => sd-ext is no longer used for rom files
    All are on nand. Only market apps and a2sd use sd-ext
    - browser icon is back to orginal (not the orange one - heh was an orange base)
    - again due to optimization and removing crap - should be a lil speed gain
    - chinese handwriting SUPPORTED - thx anonymous2183 for telling me what to edit
    - symlinking done for better openvpn support - thx anonymous2183 for pointing it out
    - all animations (bootanimation.zip, downanimation.zip, shutdownanimation.zip)
    are stored on /data/local - yes NOW you can use UOT to cook ur bootanimation
    yes forget all u've learn about changing ur bootanimation on my rom
    adb push bootanimation /data/local from now on - can be done via recovery or with phone on - now show me some love
    - removed davlik to sd - lets see how this acts for now
    - and as always what I forgot
    - P.S if you don't want leftovers - WIPE DATA CACHE SDEXT DALVIK, don't be lazy :B
    l'autore della rom consiglia il wipe...
  4. #193
    Androidiano L'avatar di bonifax1982
    Aug 2010
    Ringraziato 3 volte in 1 Post
    OMG! Questa rom non ha la App news e meteo che invece io uso spessisimo x tenermi aggiornato. Qualcuno ha idea di come si possa installare? Tenete presente che ho gia provato col file .apk ma l'installazione non va a buon fine.
    Sent from my HTC Desire using Tapatalk
  5. #194
    Jan 2011
    Ho appena notato che non ninna funziona flash nel browser...
    Se ti sono stato d'aiuto premi il tasto Thanks
  6. #195
    Androidiano VIP L'avatar di alvarotodini
    Mar 2010
    corchiano vt
    Ringraziato 108 volte in 97 Posts
    Buongiorno a tutti, leggo che la 1.9.4 ha dai bug,mi confermate questa situazione?,conviene passare dalla 1.9.1 alla .4, cosa mi consigliate?
    Attenzione a Manule Tibaldi di ivrea (TO),è un truffatore
  7. #196
    Jan 2011
    Ringraziato 28 volte in 23 Posts
    Nessun bug da me..anzi ho deciso di prendere questa rom come base della rom che andrò a fare..mi sembra una delle migliori rom DHD per Desire..
  8. #197
    Androidiani Power User L'avatar di cesco
    Sep 2010
    Bg
    TYTN2,desire,desireHD, oneX
    Ringraziato 1,346 volte in 724 Posts
    Quote Originariamente inviato da ALESSIO13 Visualizza il messaggio
    idem!
    nessunissimo bug riscontrato!!...passato dalla 1.9.2 alla 1.9.4 senza wipe ed e' tutto ok!
    Follow me on:
    <!-- Place this tag where you want the widget to render. -->
    <div class="g-person" data-width="180" data-href="//plus.google.com/113012341277613226011" data-theme="dark" data-rel="author"></div>
    <!-- Place this tag after the last widget tag. -->
    <script type="text/javascript">
    window.___gcfg = {lang: 'it'};
    (function() {
    var po = document.createElement('script'); po.type = 'text/javascript'; po.async = true;
    po.src = 'https://apis.google.com/js/plusone.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(po, s);
    </script>
    <br>
    <a class="twitter-timeline" href="https://twitter.com/xcesco89" data-widget-id="398762031488040960">Tweets di @xcesco89</a>
    <script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementB yId(id)){js=d.createElement(s);js.id=id;js.src=p+" ://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}} (document,"script","twitter-wjs");</script>
    Androidiani app
    Estensione Androidiani per Google Chrome
  9. #198
    Senior Droid L'avatar di noviz
    Oct 2010
    Molise
    Pixel 6 pro ; oneplus 7 pro
    Ringraziato 271 volte in 207 Posts
    Quote Originariamente inviato da cesco89 Visualizza il messaggio
    idem!
    idem anche per me
  10. #199
    Jan 2011
    Ciao a tutti, ho appena installato questa rom venendo da un 'altra sense hd.. ma non capiscio alcune cose...
    Ho fatto full wipe ma al riavvio è come se mi avesse ripristinato tutti i dati e applicazioni (solo quelle scaricate dal market) in automatico... possibile ??
    NN mi era mai successo....
    Altra cosa non mi funziona (fc continui) google voice??
    Installato e reinstallato + volte...
    Suggerimenti??
    Senior Droid L'avatar di newandroid
    Nov 2010
    Anche io ho fatto tutti i wipe e al riavvio mi ha ripristinato tutte le applicazione scaricate dal market.
    Ho notato in informazioni software: insertcoin hd port 1.9.3.
    Ma io ho flashato la 1.9.4
    Spigazioni?
