[DEVS]Dump motorola droid cdma
    Androidiano VIP L'avatar di nk02
    Mar 2009
    Ringraziato 506 volte in 260 Posts
    tempo fa girava il dump dello sholes prerelease.. beh questo è il dump del motorola droid, la versione in vendita.
    se a qualcuno interessa, questo è il link:
    http://www.androidspin.com/downloads...ile=system.rar
    codice:
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=ESD20
    ro.build.display.id=ESD20
    ro.build.version.incremental=17572
    ro.build.version.sdk=5
    ro.build.version.codename=REL
    ro.build.version.release=2.0
    ro.build.date=Tue Oct 20 19:37:27 PDT 2009
    ro.build.date.utc=1256092647
    ro.build.type=user
    ro.build.user=android-build
    ro.build.host=apa25.mtv.corp.google.com
    ro.build.tags=test-keys
    ro.product.model=Droid
    ro.product.brand=verizon
    ro.product.name=voles
    ro.product.device=sholes
    ro.product.board=sholes
    ro.product.cpu.abi=armeabi
    ro.product.manufacturer=Motorola
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=omap3
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=sholes
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=voles-user 2.0 ESD20 17572 ota-rel-keys,release-keys
    ro.build.fingerprint=verizon/voles/sholes/sholes:2.0/ESD20/17572:user/ota-rel-keys,release-keys
    # end build properties
    # system.prop for generic sdk
    rild.libpath=/system/lib/libmoto_ril.so
    rild.libargs=-d /dev/ttyS0
    ro.sf.lcd_density=240
    # Default network type.
    # 4 => CDMA / EVDO.
    ro.telephony.default_network=4
    wifi.interface = tiwlan0
    # Time between scans in seconds. Keep it high to minimize battery drain.
    # This only affects the case in which there are remembered access points,
    # but none are in range.
    wifi.supplicant_scan_interval = 15
    # Indicate carrier OTA SP number schema
    # refer to frameworks/base/telephony/java/com/android/
    # internal/telephony/cdma/CDMAPhone.java for the schema:
    ro.cdma.otaspnumschema=SELC,1,80,99
    # The OpenGL ES API level that is natively supported by this device.
    # This is a 16.16 fixed point number
    ro.opengles.version = 131072
    # This is a high density device with more memory, so larger vm heaps for it.
    dalvik.vm.heapsize=24m
    # ADDITIONAL_BUILD_PROPERTIES
    ro.config.notification_sound=droid.ogg
    ro.config.ringtone=DroidInvasion.ogg
    ro.config.notification_sound=OnTheHunt.ogg
    ro.config.alarm_alert=Alarm_Classic.ogg
    ro.com.android.wifi-watchlist=GoogleGuest
    ro.error.receiver.system.apps=com.google.android.feedback
    ro.setupwizard.enterprise_mode=1
    ro.com.google.clientidbase=android-verizon
    ro.com.google.locationfeatures=1
    ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
    ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
    ro.config.ringtone=CaribbeanIce.ogg
    ro.setupwizard.mode=OPTIONAL
    ro.cdma.home.operator.numeric=310004
    ro.cdma.home.operator.alpha=Verizon
    ro.cdma.homesystem=64,65,76,77,78,79,80,81,82,83
    ro.cdma.data_retry_config=default_randomization=2000,0,0,120000,180000,540000,960000
    ro.config.vc_call_vol_steps=7
    ro.telephony.call_ring.multiple=false
    ro.telephony.call_ring.delay=3000
    ro.url.safetylegal=http://www.motorola.com/staticfiles/Support/legal/?model=A855
    ro.setupwizard.enable_bypass=1
    ro.media.enc.hprof.file.format=mp4
    ro.media.enc.hprof.codec.vid=h264
    ro.media.enc.hprof.codec.aud=aac
    ro.media.enc.hprof.vid.width=720
    ro.media.enc.hprof.vid.height=480
    ro.media.enc.hprof.vid.fps=25
    ro.media.enc.hprof.vid.bps=3000000
    ro.media.enc.hprof.aud.bps=96000
    ro.media.enc.hprof.aud.hz=16000
    ro.media.enc.hprof.aud.ch=1
    ro.media.enc.hprof.duration=60
    ro.media.enc.lprof.file.format=mp4
    ro.media.enc.lprof.codec.vid=m4v
    ro.media.enc.lprof.codec.aud=amrnb
    ro.media.enc.lprof.vid.width=320
    ro.media.enc.lprof.vid.height=240
    ro.media.enc.lprof.vid.fps=15
    ro.media.enc.lprof.vid.bps=200000
    ro.media.enc.lprof.aud.bps=12200
    ro.media.enc.lprof.aud.hz=8000
    ro.media.enc.lprof.aud.ch=1
    ro.media.enc.lprof.duration=30
    ro.media.enc.file.format=3gp,mp4
    ro.media.enc.vid.codec=h264,m4v,h263
    ro.media.enc.aud.codec=aac,amrnb
    ro.media.enc.vid.h264.width=176,720
    ro.media.enc.vid.h264.height=144,480
    ro.media.enc.vid.h264.bps=64000,8000000
    ro.media.enc.vid.h264.fps=1,30
    ro.media.enc.vid.h263.width=176,720
    ro.media.enc.vid.h263.height=144,480
    ro.media.enc.vid.h263.bps=64000,8000000
    ro.media.enc.vid.h263.fps=1,30
    ro.media.enc.vid.m4v.width=176,720
    ro.media.enc.vid.m4v.height=144,480
    ro.media.enc.vid.m4v.bps=64000,8000000
    ro.media.enc.vid.m4v.fps=1,30
    ro.media.enc.aud.amrnb.bps=5525,12200
    ro.media.enc.aud.amrnb.hz=8000,8000
    ro.media.enc.aud.amrnb.ch=1,1
    ro.media.enc.aud.aac.bps=8192,96000
    ro.media.enc.aud.aac.hz=16000,16000
    ro.media.enc.aud.aac.ch=1,1
    ro.media.dec.aud.wma.enabled=1
    ro.media.dec.vid.wmv.enabled=1
    ro.media.cam.preview.fps=0
    ro.config.sync=yes
    dalvik.vm.dexopt-flags=m=y
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    PS: NON E' UNA ROM, NON PROVATE A FLASHARLA, ASD
  2. Il seguente Utente ha ringraziato nk02 per il post:
    htcuser (07-11-09)
    Jun 2009
    e io che speravo in un'anteprima come per Donut che abbiamo avuto il piacere di provare un mese prima della release
  5. #3
    Mar 2009
    Quote Originariamente inviato da Mettiuz88 Visualizza il messaggio
    eh stavolta niente source..
  6. #4
    Aug 2009
    Bassano del Grappa
    Quote Originariamente inviato da nk02 Visualizza il messaggio
    Ma secondo te a breve avremo una ion 2.0 o dovremo aspettare ancora molto? Coma mai stavolta ci mettono tanto a rilasciare i sorgenti? almeno ci sarebbe già uno cyanogenmod experimental basata su eclair
Discussioni simili
  1. Motorola Droid (USA) con USIM Italia
    Da giuseppem82 nel forum Motorola Milestone
    Risposte: 14
  2. Aggiornamento 2.0.1 Motorola Droid
    Da nk02 nel forum Motorola Milestone
    Risposte: 11
