cioe' lo lasci a caricare 4 ore e ti da un 45% in piu'di ricarica oltre a quella del telefonino,giusto?
[Smartphone] Huawei G330 - U8825-1
[ROM] Stock
[Kernel] Stock
[Root] √
[Smartphone] Galaxy s GT-I9000
[ROM] Stock
[Kernel] Stock
[Root] √
[Tablet] galaxy Tab GT-P7300 Cyanogenmod 10
Se ti sono stato di aiuto clicca il pollice in su che si trova in basso a sinistra del mio post!
Ho fatto qualche ricerchina. Sembra che il jack utilizzato dal nostro G330 sia a 4 poli e compatibile con Iphone...
Esisterebbero infatti 2 standard CTIA (Apple) OTMP... (Nokia, Ericsson, etc)...
Sarebbe da provare se le cuffie dell'iphone funzionano.
Qui un utente usa un semplicissimo splitter per iphone da pochi euro...
Earphones problem - Huawei Ascend G300 - G300.MoDaCo.com - MoDaCo
Su un'altro forum che frequeto questa cosa sarebbe confermata, ma esisterebbero delle limitazioni:
http://www.head-fi.org/t/621744/fiio...nal-thought/15For most current gen. android phone:
What work:
Play, pause (so are taking / ending call), next (double click), bass boost.
What don't work:
volume control, previous track (triple click)
Volume control on iDevice needs special chip so they won't work on Android. You can still use E02i as an inline amp / bass boost on any mp3 player. Since most mp3 player (beside Apple's) doesn't even support remote, you won't get any of those functions.
Ultima modifica di Viggo; 23-01-13 alle 15:25
Alexgn (23-01-13)
Per maggiori info anche sugli standard CTIA/OMTPdate un'occhiata qui:
OMTP and CTIA (both are organizations for mobile standards). For OMTP, the TRRS plug is wired as [Left-Right-Mic-Ground] (from tip-to-sleeve); for CTIA, the TRRS is wired as [Left-Right-Ground-Mic]. Since OMTP was initially endorsed by Ericsson (and Nokia, which still uses the OMTP standard), all of their cellphone, including those under the Sony Ericsson branding, uses this standard. It also got adopted by a few other cellphone manufacturers as standard before mid 2011, such as LG, Motorola, Sony and Samsung. In mid 2010, the OMTP organization transitioned itself into another organization (the WAC, if you are interest to know), and the OMTP standard for headset was subsequently being phased out by most manufacturers within the following year (* it takes time to sell off old models) in favor of the CTIA standard. Part of the big reason for adapting the CTIA standard might be due to the fact that it is the standard used by Apple on their iDevice, which represent a big share of the headset market. Standardization demands from political groups (i.e. the EU) also played a role to push for one headset standard that will work on both Android and iOS, as well as most dumbphones (except for Nokia, which doesn’t like to play with other for now).
Per farla breve in linea di principio tutti i telefoni android recenti supportano standard CTIA per questioni di standardizzazione richiesta dalla UE e per il fatto che la maggior parte dei produttori fa cuffie per iphone. Nokia invece va per i fatti suoi continuando ad usare il vecchio standard.
Esistono però degli adattatori (TRRS smart adapter ) OMTP>CTIA e viceversa molto economici che forse vale la pena provare.
A proposito di cuffie in-ear ho individuato le Sony Smart Headset MH-1C ( standard CTIA ovvero APPLE-Sony Experia) e le Sony Smart Headset MH-1 ( standard OMTP ovvero SonyEricsson). Sono interessanti perchè oltre ad essere delle ottime cuffie recensite molto bene anche a livello "audiofilo" sono disponibili nelle due versioni supportano i due standard.
Ultima modifica di Viggo; 24-01-13 alle 11:14
Salve a tutti. Circa 20 giorni fa avevo acquistato da un venditore di Hong Kong su ebay due cover a 3.50 euro. Le cover sono rigide e ovviamente sevono per non strisciare la parte posteriore, sono in plastica dura. e danno un buon effetto al tatto. Questo è il link dell'oggetto: 2x Hard Back Cover Case for Huawei U8825D Ascend G330 | eBay. Ecco qualche foto:
daniele0590 (31-01-13),paolsat (26-01-13),YnGWiE27 (26-01-13)
Io mi son preso questa: eBay Italia - Aste online e shopping a prezzo fisso
E' stata spedita il 19 gennaio; credo arriverà per Pasqua, ma appena ce l'ho, vi farò sapere! XD
Io ho comprato due cover in TPU..piurigide di quelle in silicone.. ma cmq ottime perattutire i colpi..
LG G2 D802 > Nokia Lumia920
ASUS TF300T 4.1.1 bootloader unlocked
Muletto i9000 4.1.2 AOKP
Huawei G330
Tende da sole e da Interno, Zanzariere, Tapparelle, a Peschiera del Garda
Ho chiesto a mia cugina di prendermi una cover per il cellulare visto che è in Cina..
Deve aver capita una cover per ogni giorno della settimana xD
PS la più nella, quella con i disegnini più che proteggere il cellulare ne attenta la vita tanto è scivolosa, ce un modo per renderla un po più ruvida? Pensavo magari a dare una pennellata di vernice trasparente...
Inviato dal mio HUAWEI U8825-1 con Tapatalk 2
