Pagina 449 di 1789 primaprima ... 3493994394474484494504514594995499491449 ... ultimoultimo
Visualizzazione dei risultati da 4,481 a 4,490 su 17884
Jiayu S3 - Modding
  1. #4481
    Androidiano VIP L'avatar di freedgt
    milano
    Oltre 180Mila.....Su Antutu
    Ringraziato 1,317 volte in 755 Posts
    The software version number is s3s-20150813-105957, system version android4.4.4, non latest UI. Preferred domain S3 latest stable version of the factory system, recommended for general users.
    The main updates are as follows:
    1 loss baseband and IMEI guide to the SIM card does not read the latest batch of fixes individual machines appear.
    2, should the user request to join 'Shutter sound' control options in the camera
    3, in response to user requirements in the Settings - Display in to add a LED control switch, you can set the time period, respectively, and message switch off the charging indicator lamp.
    4, to enhance the system hardware and software compatibility.
    5, optimization of some small bug, improve system stability and fluency.
    Special note: only provide wire brush package, please pay attention to back up important data on your phone before upgrading, to avoid unexpected loss of data occurs. Any data loss caused due to a software upgrade, we do not take any responsibility.
    download cloud wade ufficiale versione per flashtool
    s3s-20150813-105957.zip_??????|??? ??-?????
    link by @Superkey grazie
    https://mega.nz/#!ZxMUUDjK!08J3ILZvJ...uexAIFiK-gFLHw
    link by me
    https://drive.google.com/file/d/0B2z...ew?usp=sharing
    questa relase e ufficiale non ha gapps si presume che sia arrivato anche via OTA fatemi sapere grazie
    dunque si puo regolare il led notifica e spegnere indicatore di ricarica, si puo disabilitare suono fotocamera
    Ultima modifica di freedgt; 14-08-15 alle 20:44
    Oltre 180Mila Su Antutu.......
  2. I seguenti 3 Utenti hanno ringraziato freedgt per il post:
    cerquo (14-08-15),pluffo (18-08-15),Superkey (14-08-15)
    @freedgt
    Grazie per info e link.
    Puoi scaricare il file e hostarlo su host europei?
    @all
    Potete scaricare il file con JDownloader.
  5. #4483
    Senior Droid L'avatar di Superkey
    Jun 2014
    Genova
    OP7 OP5 JiaYu S3A
    Ringraziato 333 volte in 235 Posts
    @freedgt
    @all
    Lo sto scaricando io con un po' di pazienza.
    Non ho una connessione veloce.
    Poi posto il link.
    Inviato dal mio JiaYu-S3 Advanced usando Androidiani App
    " Per aspera sic itur ad astra "
    Dall' ERICSSON EH 237 (1995) ... allo
    OnePlus7 12/256 (2020)
    *** 25 anni di telefonia mobile ***
    OnePlus5 8/128 - OnePlus7 12/256
  6. #4484
    Jun 2014
    Genova
    OP7 OP5 JiaYu S3A
    @bovirus @all
    ecco il link alla nuova release di KK s3s-20150813-105957.zip (MEGA)
    @bovirus poi ci pensi tu a metterlo nel thread giusto (non voglio fare xposting )
  7. I seguenti 3 Utenti hanno ringraziato Superkey per il post:
    freedgt (14-08-15),instancabile (14-08-15),magicreal (15-08-15)
  8. #4485
    milano
    @Superkey
    ho aggiornato il mio messaggio con il tuo link grazie
    https://www.androidiani.com/forum/ji...ml#post7022530
    e rilancio anche io col mio
    sta rom e da provare secondo me va una meraviglia
    Ultima modifica di freedgt; 14-08-15 alle 20:31
  9. Il seguente Utente ha ringraziato freedgt per il post:
    Superkey (14-08-15)
  10. #4486
    Oct 2014
    leeco lemax2 4g Jayu-S3A
    Ringraziato 567 volte in 345 Posts
    scusa m'era sfuggita l'istallazione chiedo venia...
    Ultima modifica di antonioa62; 14-08-15 alle 23:09
    un thanks e' sempre gradito grazie
    leeco le max 2 rom 28S - M17r by CUOCO92 +
    JY-S3 advance NOUGAT RR-N-v5.8.5-20171227. by ANTONIOA62 TWRP 3.0.2.0
  11. #4487
    milano
    per flashtool
    e sempre bello vedere gente che legge
    Ultima modifica di freedgt; 15-08-15 alle 07:15
  12. #4488
    milano
    Vibe UI 2.8 20150813 LP 5.1
    Brush Method:
    1, you must first wire brush the official 5.1 system (if you are already 5.1 itself consciously ignored)
    2, you must use third-party Chinese recovery5.1 version (version 4.4 into the brush at your peril)
    3, 4 brush machine please clean are Dalvik Cache-System-Cache- internal cards (data partition)
    4, due to the Brush Script problem so for the first time the opportunity to open a little slower (about 10 minutes or so, but it will definitely boot)
    5, ROM packaged non-dat format
    Update log:
    Based on the latest development version produced VIBE2.8_1532
    Add perfect ROOT privileges, uninstall support no residual
    Add busybox instruction set, V4 sound normal installation
    Fixed open application Caton problem, several tests normal
    Desktop rearranged, brushing is not messy
    Advanced settings added to the status bar to switch, add time to the right of traditional status bar
    Streamlining the system useless components, harmonious system core
    Andrews lifted more than 4.4 external sd card limit
    Removing multiple systems program, simple and stable
    Upgrade prompt removal of third-party ROM does not support the official upgrade
    Add to the true meaning of global Dolby sound technology
    After opening Dolby sound, the sound crisp and the increase
    Status bar dropdown joining Dolby quick switch
    Mobile optimization framework, and enhance the ability WIFI
    Mobile RF optimization, reducing power consumption
    Add to personal self-compiled Advanced Settings -V6.0
    --- Status bar settings (both support switching) ---
    Top right corner of the status bar is added virtual buttons, click on the lock screen
    Intermediate status bar is added virtual home button
    Join the virtual task left corner of the status bar button
    Join the status bar operators show
    Join custom status bar operator text
    Join the status bar to switch to support the original status bar and status bar to select the right home time
    Enhancements settings --- ---
    Support volume wake the phone screen
    Support shake cool lock screen
    Join practical toolbox --- --- High
    Support ZTE screen assistant
    Support Software from Kai management
    Sound support Viper4
    Join sound settings --- ---
    Supports the opening and closing - pictures, focus, video recording and other voice
    --- Added Advanced Power menu, fast boot, reboot to recovery
    Zipalign ROM has been optimized to reduce memory footprint
    Global Optimization Network Optimization touch response effect
    Optimization of the underlying framework optimization of electricity consumption, more power
    Details of the modification, self-experience
    Recommend
    ★ Gallery: New Album hidden features
    Gallery
    New - Album hidden features
    Repair - resolved to enter the album from the camera interface, menu duplication issues
    Repair - to solve the album, group viewing interface, return key failure problem
    Contacts
    Repair - to solve the fixed telephone address book can not display the name, only numbers problem
    Repair - to solve the horizontal screen state association life categories, culinary map icon with the same background color problem
    Solve the problem [Contacts to display] in the contact settings, you can not set - Repair
    Repair - to solve the probabilistic notification bar when you receive a message is not displayed, no ringing reminder of the problem
    Repair - solved when using probabilistic timed messages flash back problems
    Repair - can not solve the problem call recording after playing
    Repair - solves the SIM card management, after the self-edit SIM card information, appears only with [SIM card two] to make phone calls and send messages of problem
    Calendar
    Repair - to solve the probabilistic Advent Calendar login account after [my account] stop running problems
    Repair - to solve the calendar does not reflect the lunar month of issue
    Lock screen
    Repair - to solve the pattern unlock and digital unlocked, you can not go directly to the desktop of the problem
    Repair - to solve the lock screen wallpaper time position on the issue too far
    Repair - to solve the main menu key probabilistic problem unresponsive
    Repair - to solve the lock screen down, you receive messages automatically unlock problem
    Repair - Repair solves the digital lock can not replace digital font problems
    Repair - to solve the lock screen anti inadvertently probabilistic failure problem
    Power management
    Repair - to solve the phone restart after battery problem is cleared
    System
    Optimization - enhance the QQ chat tool Return key user experience
    Repair - after inadvertently home key to solve the call, the call interface will minimize to the notification bar problem
    [Disclaimer]
    1. I have been tested by the ROM, as a result of improper operation of the consequences, and I've not and will not assume any responsibility;
    Please ensure that the battery has more than 20% of the electricity front 2. Brush, Brush process and to ensure that the mobile phone and computer without any exception;
    3. Brush risk, the first brush machine, please read the forum Brush tutorials, or peril;
    4. He does not hold the copyright ROM and the program, please study and learning for the purpose of lawful use;
    5. I declare the various users of the ROM does not provide any guarantee, does not guarantee the suitability of the ROM does not guarantee trouble-free production; no guarantee of security and stability;
    6. nor use or loss of this ROM actually encountered any theory of liability for any user;
    7. Never tamper with the publication of my works! In particular, no technical content of the secondary packaging integrated promotion software, rights reserved!
    8. If you download and brush into this ROM, it means that tacitly accept this agreement
    DOWNLOAD PASSWORD:bki9
  13. I seguenti 2 Utenti hanno ringraziato freedgt per il post:
    GIOBOT (15-08-15),pluffo (18-08-15)
  14. #4489
    milano
    sistemato messaggio grazie staff
    per tutti leggete qui un possibile CM 12.1 IN UN FUTURO PROSSIMO
    http://www.gizchina.com/2015/08/14/j...-cm12-devices/
    attualmente nel sito tedesco il contatore e zero questa notizia e in ritardo di 4 giorni (pubblicata il 14/08)
    http://jiayu.de/kundenservice/jiayu-...e-air-app.html
    in mio parere ad oggi se non c'e' una CM per S3 un motivo ci sara', i tedeschi mirano in alto ma i bug non si contano piu gia su quei 2 device inferiori, ufficialmente il produttore continua il proprio lavoro senza dar peso a questi venditori di fumo tedeschi a 280 euro S3 so pazzi, meglio una rom fatta su misura che un porting fatto male
    Ultima modifica di freedgt; 15-08-15 alle 08:49
  15. I seguenti 5 Utenti hanno ringraziato freedgt per il post:
    diego06 (15-08-15),GIOBOT (15-08-15),metrino (15-08-15),pluffo (18-08-15),Superkey (15-08-15)
  16. #4490
    Sep 2014
    [QUOTE=cicio71;7021867]
    Quote Originariamente inviato da Lukas27 Visualizza il messaggio
    @cicio71 cosa hai fatto per sistemare il bug batteria?
    Premetto che il mio s3 non mi da tutti i problemi presenti nel forum di fatto funziona egregiamente e sono super soddisfatto
    Ho ricaricato con la mia poter Bank (7 ore) poi battery calibration poi scaricato fino al 2% poi di nuovo caricato con power bank 😀
    Spero regga
    La mia power bank è deboluccia.. Era per il telefono che avevo prima.. Caricare il telefono da computer è la stessa cosa? Da acceso o spento? Battery calibrazione funziona davvero?
