Aggiornata alla versione 2.83
( di GO Launcher Dev Team )
https://play.google.com/store/apps/d...F1bmNoZXJleCJd
Novità:
-(New) A “News” center in Menu for update information
-(New) New GO Store interface and a 4x1 widget
-(Improve) Change default options for gesture settings (You can use gesture to active Menu now!)
-(Improve) Rearrange the buttons of “More” tab of Menu
-(Fix) Unable uninstall problem caused by gesture settings (Requires switch widget because of permission issue)
-(Fix) Crash issue of GO Store
