Soluzione per bootloop
    Apr 2011
    Geneve (CH)
    Google Pixel 7
    Ringraziato 52 volte in 49 Posts
    Salve a tutti, in rete ho trovato questa guida.
    There is a possible way to fix the bootloop issue and heres how to do it and i hope joe bara nunez can confirm this since he revive his phone using this step.....
    Download your KDZ stock lg g4 stock firmware according to your g4 model...
    Download LGUP from here http://www.filedropper.com/g4 or here https://www.dropbox.com/s/d2dw48uqh4hku8m/G4.rar?dl=0 or here Download LGUP.zip thank you hyelton for this link
    Install LGUP_8994_DLL_Ver_0_0_3_23 first and then LGUP_Install_Ver_1_14_3
    Or look for the newest version of LGUP
    Make sure you have downloaded the required KDZ file MM or LP
    Start LGUP prog on your computer "make sure your phone is plugged in"
    ARE YOU HAVING TROUBLE WITH LGUP NOT SEEING YOUR MOBILE?
    Try this....... take the back off your mobile so you can get at the battery. Connect your mobile via USB. Start LGUP, if it does not see your phone DO NOT DISCONECT, DO NOT RESTART OR TURN OFF LGUP. Take out the battery and then put it back in.......let the phone restart on its own. LGUP should now see it.....
    Still if you didnt see your G4 on your computer... Run LGUP as an administrator.... Change your lg up compatibility with your current operating system
    Credits to shakeyabooti of XDA for the post of his lgup and joe bara nunez for his method...
    The famous bootloop is not nearly a hardware problem since it was misdiagnosed if its hardware problem it shouldn't turn on.... Its a problem with googles update parameters that is not compatible with lg hardware specification..
    What it does it renders the kernel to stop using the nandflash... Without that the your phone wont startup
    [edit ] : Since they just isolate the problem way back then since they really dont know why on earth it causes bootloop after that update from v10c... And by that time some vulnerabilities was being patched by google in conjuction with stagefright vulnerabilities.... Some users claim that they were just using the messaging app when they experience the bootloop...at that time google gave a temporary vulnerability fix for that inside v10c.... Thats the parameter that is not compatible with lg since its a temporary fix.
    C'é qualcuno in grado di tradurla e renderla comprensibile a tutti?
    Androidiano VIP L'avatar di librari
    Oct 2013
    Ringraziato 841 volte in 708 Posts
    Vi è un modo possibile per risolvere il problema bootloop e heres come farlo e spero Joe Nunez bara può confermare questo dato che rivivere il suo telefono usando questo passaggio .....
    Scarica tutte le KDZ magazzino LG g4 firmware stock in base al modello g4 ...
    Scarica LGUP da herehttp: //www.filedropper.com/g4 o herehttps:? //www.dropbox.com/s/d2dw48uqh4hku8m/G4.rar Dl = 0 o qui Scarica LGUP.zipthank si hyelton per questo link
    Installare LGUP_8994_DLL_Ver_0_0_3_23 prima e poi LGUP_Install_Ver_1_14_3
    O guardare per l'ultima versione di LGUP
    Assicurarsi di aver scaricato il file richiesto KDZ MM o LP
    Inizia LGUP prog sul computer "assicurarsi che il telefono sia collegato"
    Stai avendo difficoltà con LGUP non vedere il cellulare?
    Prova questo ....... prendere la marcia indietro il cellulare in modo da poter arrivare alla batteria. Collega il tuo cellulare tramite USB. Inizia LGUP, se non vede il proprio telefono Non disconect, non si riavvia o si spegne LGUP. Estrarre la batteria e poi reinserirla ....... lasciare che il riavvio del telefono da solo. LGUP dovrebbe ora vedere .....
    Ancora se fatto vedere il G4 sul computer ... Esegui come amministratore LGUP .... Cambia la tua compatibilità lg con il sistema operativo corrente
    Crediti per shakeyabooti di XDA per il posto di suo lgup e Joe Nunez bara per il suo metodo ...
    Il famoso bootloop non è quasi un problema hardware da quando è stato mal diagnosticato se il suo problema hardware non dovrebbe accendere .... E 'un problema con i parametri Googles di aggiornamento che non è compatibile con le specifiche hardware lg ..
    Ciò che fa rende il kernel di smettere di usare il NandFlash ... senza che il vostro telefono solito avvio
    [Modifica]: Dal momento che basta isolare il problema via del ritorno poi perché realmente non so perché sulla terra che provoca bootloop dopo che l'aggiornamento da v10c ... e da quel momento alcune vulnerabilità è stata di essere modificati da Google in combinazione con vulnerabilità Stagefright .. .. Alcuni utenti affermano che erano solo usando l'applicazione di messaggistica quando sperimentano il bootloop ... a quel tempo Google ha dato una soluzione temporanea per la vulnerabilità che dentro v10c .... quello è il parametro che non è compatibile con LG fin dalla sua un correzione temporanea.
    C'é Qualcuno a Grado di tradurla e renderla comprensibile a tutti?
    In pratica secondo loro è solo software il problema!
    solo gli stupidi imparano dalle proprie esperienze,i furbi da quelle degli altri!
    Androidiano L'avatar di Hennet
    Sep 2013
    Huawei G615/ Note 3 neo/ LG G4
    Mi sembra una scemenza, fosse un problema software con un aggiornamento avrebbero risolto per tutti. Invece è qualcosa sulla scheda madre che va a farsi benedire.
    S22 Ultra,Find X2 pro,Mi 10
    Chiudo per inattività e aggiungo che, quando postiamo dobbiamo necessariamente accostare la traduzione al testo originale.
    Per la riapertura contattare me o il moderatore di sezione.
    Sto Guidando (cit. Dieguccio)
