Pagina 58 di 60 primaprima ... 8485657585960 ultimoultimo
Visualizzazione dei risultati da 571 a 580 su 596
Mediacom Pad phone Duo g530 Android 4.3 rom based on Start N9500 S4 clone
  1. #571
    Jan 2014
    Ringraziato 15 volte in 8 Posts
    Ok grazie vocoderism
    Inviato dal mio M-PP2G530 usando Androidiani App
    Jan 2014
    Configuration targets:
    config - Update current config utilising a line-oriented program
    nconfig - Update current config utilising a ncurses menu based program
    menuconfig - Update current config utilising a menu based program
    xconfig - Update current config utilising a QT based front-end
    gconfig - Update current config utilising a GTK based front-end
    oldconfig - Update current config utilising a provided .config as base
    localmodconfig - Update current config disabling modules not loaded
    localyesconfig - Update current config converting local mods to core
    silentoldconfig - Same as oldconfig, but quietly, additionally update deps
    defconfig - New config with default from ARCH supplied defconfig
    savedefconfig - Save current config as ./defconfig (minimal config)
    allnoconfig - New config where all options are answered with no
    allyesconfig - New config where all options are accepted with yes
    allmodconfig - New config selecting modules when possible
    alldefconfig - New config with all symbols set to default
    randconfig - New config with random answer to all options
    listnewconfig - List new options
    oldnoconfig - Same as silentoldconfig but set new symbols to n (unset)
    Other generic targets:
    all - Build all targets marked with[*]
    * vmlinux - Build the bare kernel
    * modules - Build all modules
    modules_install - Install all modules to INSTALL_MOD_PATH (default: /)
    firmware_install- Install all firmware to INSTALL_FW_PATH
    (default: $(INSTALL_MOD_PATH)/lib/firmware)
    dir/ - Build all files in dir and below
    dir/file.[oisS] - Build specified target only
    dir/file.lst - Build specified mixed source/assembly target only
    (requires a recent binutils and recent build (System.map))
    dir/file.ko - Build module including final link
    modules_prepare - Set up for building external modules
    tags/TAGS - Generate tags file for editors
    cscope - Generate cscope index
    gtags - Generate GNU GLOBAL index
    kernelrelease - Output the release version string
    kernelversion - Output the version stored in Makefile
    headers_install - Install sanitised kernel headers to INSTALL_HDR_PATH
    (default: /home/megabit/Scrivania/android_kernel_oppo_r819-android-4.4/usr)
    Static analysers
    checkstack - Generate a list of stack hogs
    namespacecheck - Name space analysis on compiled kernel
    versioncheck - Sanity check on version.h usage
    includecheck - Check for duplicate included header files
    export_report - List the usages of all exported symbols
    headers_check - Sanity check on exported headers
    headerdep - Detect inclusion cycles in headers
    coccicheck - Check with Coccinelle.
    Kernel packaging:
    rpm-pkg - Build both source and binary RPM kernel packages
    binrpm-pkg - Build only the binary kernel package
    deb-pkg - Build the kernel as a deb package
    tar-pkg - Build the kernel as an uncompressed tarball
    targz-pkg - Build the kernel as a gzip compressed tarball
    tarbz2-pkg - Build the kernel as a bzip2 compressed tarball
    tarxz-pkg - Build the kernel as a xz compressed tarball
    perf-tar-src-pkg - Build perf-3.4.5.tar source tarball
    perf-targz-src-pkg - Build perf-3.4.5.tar.gz source tarball
    perf-tarbz2-src-pkg - Build perf-3.4.5.tar.bz2 source tarball
    perf-tarxz-src-pkg - Build perf-3.4.5.tar.xz source tarball
    Documentation targets:
    Linux kernel internal documentation in different formats:
    htmldocs - HTML
    pdfdocs - PDF
    psdocs - Postscript
    xmldocs - XML DocBook
    mandocs - man pages
    installmandocs - install man pages generated by mandocs
    cleandocs - clean all generated DocBook files
    Architecture specific targets (arm):
    * zImage - Compressed kernel image (arch/arm/boot/zImage)
    Image - Uncompressed kernel image (arch/arm/boot/Image)
    * xipImage - XIP kernel image, if configured (arch/arm/boot/xipImage)
    uImage - U-Boot wrapped zImage
    bootpImage - Combined zImage and initial RAM disk
    (supply initrd image via make variable INITRD=<path>)
    dtbs - Build device tree blobs for enabled boards
    install - Install uncompressed kernel
    zinstall - Install compressed kernel
    uinstall - Install U-Boot wrapped compressed kernel
    Install using (your) ~/bin/installkernel or
    (distribution) /sbin/installkernel or
    install to $(INSTALL_PATH) and run lilo
    acs5k_defconfig - Build for acs5k
    acs5k_tiny_defconfig - Build for acs5k_tiny
    afeb9260_defconfig - Build for afeb9260
    ag5evm_defconfig - Build for ag5evm
    am200epdkit_defconfig - Build for am200epdkit
    ap4evb_defconfig - Build for ap4evb
    assabet_defconfig - Build for assabet
    at91rm9200_defconfig - Build for at91rm9200
    at91sam9260_defconfig - Build for at91sam9260
    at91sam9261_defconfig - Build for at91sam9261
    at91sam9263_defconfig - Build for at91sam9263
    at91sam9g20_defconfig - Build for at91sam9g20
    at91sam9g45_defconfig - Build for at91sam9g45
    at91sam9rl_defconfig - Build for at91sam9rl
    at91x40_defconfig - Build for at91x40
    badge4_defconfig - Build for badge4
    bcmring_defconfig - Build for bcmring
    bonito_defconfig - Build for bonito
    cam60_defconfig - Build for cam60
    cerfcube_defconfig - Build for cerfcube
    cm_x2xx_defconfig - Build for cm_x2xx
    cm_x300_defconfig - Build for cm_x300
    cns3420vb_defconfig - Build for cns3420vb
    colibri_pxa270_defconfig - Build for colibri_pxa270
    colibri_pxa300_defconfig - Build for colibri_pxa300
    collie_defconfig - Build for collie
    corgi_defconfig - Build for corgi
    cpu9260_defconfig - Build for cpu9260
    cpu9g20_defconfig - Build for cpu9g20
    da8xx_omapl_defconfig - Build for da8xx_omapl
    davinci_all_defconfig - Build for davinci_all
    dove_defconfig - Build for dove
    ebsa110_defconfig - Build for ebsa110
    edb7211_defconfig - Build for edb7211
    em_x270_defconfig - Build for em_x270
    ep93xx_defconfig - Build for ep93xx
    eseries_pxa_defconfig - Build for eseries_pxa
    exynos4_defconfig - Build for exynos4
    ezx_defconfig - Build for ezx
    footbridge_defconfig - Build for footbridge
    fortunet_defconfig - Build for fortunet
    g3evm_defconfig - Build for g3evm
    g4evm_defconfig - Build for g4evm
    h3600_defconfig - Build for h3600
    h5000_defconfig - Build for h5000
    h7201_defconfig - Build for h7201
    h7202_defconfig - Build for h7202
    hackkit_defconfig - Build for hackkit
    imote2_defconfig - Build for imote2
    imx_v4_v5_defconfig - Build for imx_v4_v5
    imx_v6_v7_defconfig - Build for imx_v6_v7
    integrator_defconfig - Build for integrator
    iop13xx_defconfig - Build for iop13xx
    iop32x_defconfig - Build for iop32x
    iop33x_defconfig - Build for iop33x
    ixp2000_defconfig - Build for ixp2000
    ixp23xx_defconfig - Build for ixp23xx
    ixp4xx_defconfig - Build for ixp4xx
    jornada720_defconfig - Build for jornada720
    kirkwood_defconfig - Build for kirkwood
    kota2_defconfig - Build for kota2
    ks8695_defconfig - Build for ks8695
    lart_defconfig - Build for lart
    lpc32xx_defconfig - Build for lpc32xx
    lpd270_defconfig - Build for lpd270
    lubbock_defconfig - Build for lubbock
    mackerel_defconfig - Build for mackerel
    magician_defconfig - Build for magician
    mainstone_defconfig - Build for mainstone
    marzen_defconfig - Build for marzen
    mini2440_defconfig - Build for mini2440
    mmp2_defconfig - Build for mmp2
    msm_defconfig - Build for msm
    mv78xx0_defconfig - Build for mv78xx0
    mxs_defconfig - Build for mxs
    neponset_defconfig - Build for neponset
    netwinder_defconfig - Build for netwinder
    netx_defconfig - Build for netx
    nhk8815_defconfig - Build for nhk8815
    nuc910_defconfig - Build for nuc910
    nuc950_defconfig - Build for nuc950
    nuc960_defconfig - Build for nuc960
    omap1_defconfig - Build for omap1
    omap2plus_defconfig - Build for omap2plus
    orion5x_defconfig - Build for orion5x
    palmz72_defconfig - Build for palmz72
    pcm027_defconfig - Build for pcm027
    pleb_defconfig - Build for pleb
    pnx4008_defconfig - Build for pnx4008
    pxa168_defconfig - Build for pxa168
    pxa255-idp_defconfig - Build for pxa255-idp
    pxa3xx_defconfig - Build for pxa3xx
    pxa910_defconfig - Build for pxa910
    qil-a9260_defconfig - Build for qil-a9260
    raumfeld_defconfig - Build for raumfeld
    realview_defconfig - Build for realview
    realview-smp_defconfig - Build for realview-smp
    rpc_defconfig - Build for rpc
    s3c2410_defconfig - Build for s3c2410
    s3c6400_defconfig - Build for s3c6400
    s5p64x0_defconfig - Build for s5p64x0
    s5pc100_defconfig - Build for s5pc100
    s5pv210_defconfig - Build for s5pv210
    sam9_l9260_defconfig - Build for sam9_l9260
    shannon_defconfig - Build for shannon
    shark_defconfig - Build for shark
    simpad_defconfig - Build for simpad
    spear3xx_defconfig - Build for spear3xx
    spear6xx_defconfig - Build for spear6xx
    spitz_defconfig - Build for spitz
    stamp9g20_defconfig - Build for stamp9g20
    tct_hammer_defconfig - Build for tct_hammer
    tegra_defconfig - Build for tegra
    trizeps4_defconfig - Build for trizeps4
    u300_defconfig - Build for u300
    u8500_defconfig - Build for u8500
    usb-a9260_defconfig - Build for usb-a9260
    versatile_defconfig - Build for versatile
    vexpress_defconfig - Build for vexpress
    viper_defconfig - Build for viper
    xcep_defconfig - Build for xcep
    xolo_defconfig - Build for xolo
    zeus_defconfig - Build for zeus
    devo dare make oldconfig?
  4. #573
    Senior Droid L'avatar di vocoderism
    Sep 2013
    Ringraziato 140 volte in 97 Posts
    Passa il target e il cross compiler
  5. #574
    Jan 2014
    Originariamente inviato da vocoderism
    Quindi make oldconfig + il cross compiler?
    Ultima modifica di devilmaycry3351; 06-02-14 alle 16:50
  6. #575
    Sep 2013
    Prova cosi
  7. Il seguente Utente ha ringraziato vocoderism per il post:
    devilmaycry3351 (06-02-14)
  8. #576
    Jan 2014
    Compressed ROM boot loader base address?
    che metto?
  9. #577
    Androidiano L'avatar di gecri73
    salve a tutti sono nuovo del posto.....grazie per il lavoro svolto...ma e c'è un ma........Cortesemente potreste rimettere i file per cwm e ultima room funzionante .....grazie...!!!
  10. #578
    Feb 2014
    Nexus 4
    Quote Originariamente inviato da gecri73 Visualizza il messaggio
    I link non sono più funzionanti, qualcuno ha modo di rimetterli?
  11. #579
    Ciao ragazzi ci sono aggiornamenti riguardo la rom grazie
  12. #580
    Feb 2014
    Nexus 4
    nessuno ha modo di mandarmi i file x il root e la custom recovery anche in privato gentilmente? i link sulla prima pagina non sono più disponibili
