Pagina 33 di 62 primaprima ... 23313233343543 ... ultimoultimo
Visualizzazione dei risultati da 321 a 330 su 614
Cyanogenmod 10.1
  1. #321
    GT-i9300
    Quote Originariamente inviato da enzocoll Visualizza il messaggio
    qualcuno riesce almeno a postarmi (tablet avviato con la cyano, non c'è bisogno di linux):
    codice:
    cat /proc/partitions > /sdcard/proc_partitions.txt
    mount > /sdcard/mount.txt
    sono vicino alla soluzione...
    codice:
     major minor  #blocks  name
       7        0      11466 loop0
      93        0    7782400 nand
      93        8      16384 nanda
      93       16      16384 nandb
      93       24      32768 nandc
      93       32     524288 nandd
      93       40    1228800 nande
      93       48      16384 nandf
      93       56      32768 nandg
      93       64     327680 nandh
      93       72     262144 nandi
      93       80    5308416 nandj
     179        0    1955840 mmcblk0
     179        1    1954816 mmcblk0p1
     254        0      11466 dm-0
    codice:
    rootfs / rootfs ro,relatime 0 0
    tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
    devpts /dev/pts devpts rw,relatime,mode=600,ptmxmode=000 0 0
    none /dev/cpuctl cgroup rw,relatime,cpu 0 0
    proc /proc proc rw,relatime 0 0
    sysfs /sys sysfs rw,relatime 0 0
    none /acct cgroup rw,relatime,cpuacct 0 0
    tmpfs /mnt/secure tmpfs rw,relatime,mode=700 0 0
    tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
    tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
    /dev/block/nandd /system ext4 ro,noatime,nodiratime,user_xattr,barrier=0,data=ordered,noauto_da_alloc 0 0
    /dev/block/nande /data ext4 rw,nosuid,nodev,noatime,nodiratime,user_xattr,barrier=0,data=ordered,noauto_da_alloc 0 0
    /dev/block/nandh /cache ext4 rw,nosuid,nodev,noatime,nodiratime,user_xattr,barrier=0,data=ordered,noauto_da_alloc 0 0
    /dev/block/dm-0 /mnt/asec/com.dsemu.drastic-1 ext4 ro,dirsync,nosuid,nodev,noatime,user_xattr,barrier=1 0 0
    /dev/block/vold/93:80 /storage/sdcard0 vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
    tmpfs /storage/sdcard0/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0
    /dev/block/vold/179:1 /storage/sdcard1 vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
    non so se fosse questo ciò che intendevi..purtroppo l sd che ho è solo da 2 gb quindi non posso avviare linux sul tablet.. (com.dsemu.drastic è un emulatore nds che ho installato, non so se possa aver modificato qualcosa in quello che ti interessa)
    Phone: Samsung Galaxy S lll [GT-i9300]
    ROM: PACman 4.3 NIGHTLIES
    Kernel: Googy-Max Kernel 1.7.2
  2. Il seguente Utente ha ringraziato gambit14 per il post:
    enzocoll (16-10-13)
    Ringraziato 54 volte in 48 Posts
    Quote Originariamente inviato da gambit14 Visualizza il messaggio
    perfetto! mi serviva proprio questo
  5. #323
    da che versione di cyano hai eseguito i comandi?
  6. #324
    GT-i9300
    A disposizione
    sto usando la versione modificata con il touch funzionante (quindi non l'ultima release di ugers), ti servivano quelli dell'ultima versione?
    oggi farò un clean flash e posto nuovamente i files..
    non saprei come eseguire i cmd nell'ultima versione col touch non funzionante (non ho con me il cavo otg), se c'è qualche modo sono a disposizione
  7. #325
    senza cavo otg mi sa che l'unico modo è quello di aprire una shell adb, anche se se non ricordo male il debug USB di default è disabilitato sulla cyano
  8. #326
    GT-i9300
    purtroppo non ho modo di reperire il cavo otg a breve :/
  9. #327
    Androidiano VIP L'avatar di Snoob
    Torino
    HTC EVO 3D X515m
    Ringraziato 443 volte in 384 Posts
    impostare prima del flash nel build.prop la release come "debug" al posto di user attiverebbe in automatico il debug usb??
    Clicca QUI per registrarti a dropbox! Guadagneremo entrambi 500mb di spazio in più
  10. #328
    ciao ragazzi, volevo chiedervi dellle informazioni riguardo questa ROM. innanzitutto ho visto che non funziona il WiFi su alcuni modelli, quali sarebbero? e io come faccio a capire che modello ho? un altra cosa che volevo sapere è se questa ROM funziona bene o se presenta bug particolari
  11. #329
    Anche io sarei interessato grazie
    Inviato dal mio POV_TAB-PROTAB25XXL usando Androidiani App
  12. #330
    nessuno può rispondermi? e morta questa discussione?
