Ecco un estratto ad oggi...
<6>[ 6.776943] NET: Registered protocol family 31
<6>[ 6.781169] Bluetooth: HCI device and connection manager initialized
<6>[ 6.787569] Bluetooth: HCI socket layer initialized
<6>[ 6.797354] Bluetooth: Generic Bluetooth USB driver ver 0.6
<6>[ 6.800166] usbcore: registered new interface driver btusb
<6>[ 6.813725] Bluetooth: L2CAP ver 2.14
<6>[ 6.814524] Bluetooth: L2CAP socket layer initialized
<6>[ 6.829966] Bluetooth: RFCOMM TTY layer initialized
<6>[ 6.831986] Bluetooth: RFCOMM socket layer initialized
<6>[ 6.837165] Bluetooth: RFCOMM ver 1.11
<6>[ 6.846470] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 6.848917] Bluetooth: BNEP filters: protocol multicast
<6>[ 6.860424] Bluetooth: SCO (Voice Link) ver 0.6
<6>[ 6.862090] Bluetooth: SCO socket layer initialized
<6>[ 6.908619] dib0700: loaded with support for 13 different device-types
<6>[ 6.912404] usbcore: registered new interface driver dvb_usb_dib0700
<4>[ 6.919168] dvb_usb_nova_t_usb2: Unknown symbol dibusb_pid_filter_ctrl
<4>[ 6.925328] dvb_usb_nova_t_usb2: Unknown symbol dibusb_i2c_algo
<4>[ 6.931412] dvb_usb_nova_t_usb2: Unknown symbol dibusb2_0_streaming_ctrl
<4>[ 6.937888] dvb_usb_nova_t_usb2: Unknown symbol dibusb_dib3000mc_tuner_att
ach
<4>[ 6.945169] dvb_usb_nova_t_usb2: Unknown symbol dibusb_dib3000mc_frontend_
attach
<4>[ 6.952371] dvb_usb_nova_t_usb2: Unknown symbol dibusb2_0_power_ctrl
<4>[ 6.958868] dvb_usb_nova_t_usb2: Unknown symbol dibusb_pid_filter
<4>[ 6.965177] dvb_usb_nova_t_usb2: Unknown symbol dibusb_read_eeprom_byte
<6>[ 6.975514] EXT4-fs (mtdblock8): mounted filesystem without journal
<4>[ 6.986167] EXT4-fs (mtdblock6): warning: mounting unchecked fs, running e
2fsck is recommended
<6>[ 6.996331] EXT4-fs (mtdblock6): mounted filesystem without journal
<4>[ 7.000933] EXT4-fs (mtdblock5): warning: mounting unchecked fs, running e
<6>[ 7.008578] EXT4-fs (mtdblock5): mounted filesystem without journal
<7>[ 7.044834] apanic: kpanic partition erased
<3>[ 7.053883] init: cannot find '/system/bin/flash_image', disabling 'flash_
recovery'
<4>[ 7.066180] rk29_serial_set_termios:fcr=0xa1,irq=67
<6>[ 7.080049] enabling adb
<6>[ 7.084776] adb_open
<4>[ 8.239970] .324.. MMC0 receive the message No-Media from VOLD.====xbw[sd_
mmc]====
<4>[ 8.648592] on_off_spk: 0
<4>[ 8.679470] change to spk, eq=10
<6>[ 9.226131] DWC_OTG: ********vbus detect**********************************
<6>[ 9.615962] DWC_OTG: ********soft connect!!!******************************
<6>[ 9.621965] DWC_OTG: USB SUSPEND
<6>[ 9.724025] DWC_OTG: USB RESET
<6>[ 9.885641] DWC_OTG: USB RESET
<6>[ 10.086615] android_usb <NULL>: high speed config #1: android
<4>[ 10.089562] set_msc_connect_flag status = 1 20101216
<6>[ 14.464328] warning: `zygote' uses 32-bit capabilities (legacy support in
use)
<4>[ 15.216859] gpu: change freq to 552, got 552
Il driver dib0700 viene caricato mentre
ach
attach
Che potrebbe essere il driver specifico per il sintonizzatore....ma nn riesco a capire cosa ci sia che non va....
Fatto sta che non ho risolto il problema...carica il driver grazie al dib0700 ma poi si blocca tutto e dopo un po si spegne il tab..
Per il momento ho tolto tutti i moduli inutili...dal momento che mi carica il firmware suppongo siano sufficenti i moduli che ho inserito. Il fatto che si spegna il tablet dopo il carico firmware sarà dovuto come si diceva ad un crash del kernel per qualcosa dovuto al protocollo usb utilizzato. Ho appena realizzato un accrocco elettronico per fornire alimentazione al sintonizzatore senza prenderlo dal tab e anche qui mezzo cat /proc/kmsg si blocca tutto con firmware caricato correttamente.....Supponendo che il passo successivo dovrebbe essere il fatto che si popoli in dev/dvb.....non è che bisogna creare un utente o assegnare permessi o qualcosa del genere?
non riesco a trovare questa patch.....Qualcuno riesce?
Non hai un'altra pennetta? Tipo le cinesi af9015? Io comunque ho usato su PC la hauppauge dib0700 con ogni kernel uscito negli ultimi 3 anni senza mai nessun kernel panic
PS ma i moduli li hai compilati dai sorgenti dell'odys?
nn so se vi puo interessare ho postato i sorgenti.. nn so se puo risolvere il problema
Ancora nulla...Guardate qui....secondo voi ci tiriamo fuori qualcosa di buono?
http://androidforums.com/google-tv/4...-enjoy-tv.html
Ultima modifica di simulatorhck; 12-01-12 alle 00:34
si, anche con quelli eldiau o qualsiasi 2.3.27
- Non puoi inserire discussioni
- Non puoi inserire risposte
- Non puoi inserire allegati
- Non puoi modificare i tuoi messaggi
Regole del Forum
