Infatti si usano gli update.zip
GRUPPO FACEBOOK DEL MEIZU PRO 5 : CLIKKA QUI
GRUPPO FACEBOOK DEL VERNEE X PRO : CLIKKA QUI
IL MIO SITO : CLIKKA QUI
i
Flyme OS 5.6.3.8 BETA
Aggiunta al Download
Samsung Galaxy S7 Edge (SM-G935F) / Android 6.0.1
SAMSUNG Exynos 8 Octa 8890
Quad-core 2.3 GHz + Quad-core 1.6 GHz
SE TI SONO STATO D'AIUTO, LASCIA UN THANKS
i
Flyme OS 5.6.3.15 BETA
i
Flyme OS 5.6.3.22 BETA
Flyme OS 5.1.4.0 stable released!
After over 2 months of waiting Meizu has finally released a new stable version of Flyme – 5.1.4.0.
The release contains a huge changelog, featuring bug fixes SMS errors, camera improvements and many more.
This is also the first stable release for the m2 & m2 note, but there is one downside.
Fonte:meizufans
While the m2 note received an “A” (Generic) versioning, the m2 is officially running Flyme 5.1.4.0 on top of YunOS, which is getting indicated by the “Y” ending of the firmware.
Yet it is unclear what Meizu’s future plans are with the m2, however it is very likely that it is going to be converted into a YunOS exclusive device.
As of now there is still no official statement from Meizu in this regard, therefore we will keep you updated if there are any updates on this.
For Global users there is still little hope for a release within the next few weeks. Just yesterday Meizu’s overseas team released an update schedule, targeting a release for April (m2 & m2 note) and June (other devices). However, this is the second time that Meizu has postponed the release of the Global Flyme 5 firmware accordingly this announcement has to be enjoyed carefully.
Flyme OS 5.1.4.0 stable (Pro 5)
Changelog:
System
Optimization: Optimization of brightness adjustment.
Optimization: Update Baseband version.
Optimization: Update emoji expression library that supports displaying more emoji expression.
New: floating plans to increase mute function on incoming call notification.
Hi-Fi
Yun Mathematics: Mathematics engineers and experts, with a more scientific approach to a comprehensive update of the underlying algorithms, sound at the end, the sound field performance is more excellent. The overall quality of the leaps and bounds, so that a perfect interpretation of the big tuning PRO 5.
Lock screen
Optimization: Optimization lock screen color capabilities, problem solving scenarios see some time.
Desktop
New: Desktop Application Support folder named input expression.
New: Desktop Folder Naming support copy and paste.
Fix: Even now stuck interface inoperable cases.
Communication
Yellow Collection: Yellow contacts increased collection function.
Optimization: Optimization dial pad and call history of support for Talkback.
Optimization: Pinyin state, support the search box on the input screen instantly associate.
Optimization: When the dial pad stays open.
FIX: When you call, do not display the home even now.
FIX: Dialpad to enter numbers lower part of the scene can not match Contacts.
FIX: Click suspension dialpad button, pop dialpad no animation.
SMS
Yellow Pages recognition: the list of personal numbers add text recognition Yellow Pages.
Short Message: Add a call to adjust the mass of information when an upper limit of five.
Optimization: Modify the long press of a single SMS bomb box style.
Repair: Some scenarios result in error messages card recognition problems.
Search
Recent applications: increase the search page “Recent Applications”, click open the app directly.
SMS search: New SMS search feature is disabled by default.
Search Settings: access setup search, direct search settings.
Search term: set - Accessibility - desktop search, custom search allows items.
Smart: Sorting according to usage of intelligent local results.
Hot words: Home hot word is adjusted to 3 * 2, an increase of hot words for a change function.
Card: Add Instant card guide.
Recommendation word: Add the word suggestion screen function.
Camera
FIX: Record GIF, click on the screen can not focus and metering.
Fix: multi-directional imaging camera using square pattern cutting incorrect.
Fix: slow motion camera sporadic underexposed.
Fix: zoom focus area after an incorrect mapping problems.
FIX: Manual mode, click on the screen after taking a point of focus, blurred preview screen display.
App Store
Featured Plugin: New Desktop App Store Picks widget
Automatic Updates: Automatic updates adjust the trigger condition, the lock screen state of charge, power is greater than 20% before the trigger.
Ranking: Charting a single revision, increase “early adopters list” and “game list”.
Added: Related recommendation and the same developers to add “more” page.
Optimization: “Required” page new revision, to see more intuitive classification.
FIX: Application Management Interface Press uninstall encryption applications can not be uninstalled successfully.
FIX: installation fails after the installation has been a problem in the display.
Input
Optimization: based on user feedback to adjust the keyboard height.
Optimization: Allows input in full-screen landscape view.
FIX: switch to the English keyboard, quick click letter keys, the keyboard stuck.
Set up
Button at the bottom: Accessibility to add “at the bottom of the button style” setting item.
Password Reset: document locking zone and application encryption page in the unlocked increase forgot password entry.
Volume setting: “System and Notification” volume bar is split into “sound systems” and “notifications” two volume bar.
Weather
Optimization: One week weather data increases ‘Yesterday’ data.
Optimization: Weather plug-in supports 12-hour clock.
Optimization: Weather widget theme support adaptation.
Mobile butler
New: Limit the power saving mode the screen brightness to smart regulation.
Power-saving mode: increase “wake-cutting” function switch.
Flow later: the traffic management settings to increase the purchase package flow inlet.
Traffic carried forward: support monthly traffic is not cleared.
Optimization: When the desktop shortcut icon name same time, without permission prompt pop-up shortcut.
Video
Optimization: Adjust the Home screen, display more inlet channels.
Channel Screening: Screening optimization experience within the channel.
Channel Home: Adjust Channel Home interface, and increase the recommended category list page.
Landscaping theme
Purchase history: my themes, wallpapers, fonts module adds “Purchase History”.
Favorites Function: themes, wallpapers, fonts increase collection function, “my” page associated module adds favorites list.
Optimization: Merge My subject / My font “local” and “beta”.
Gallery
Slide multiple choice: slide library to add support for multi-select operations.
Optimization: Modify the picture detail screen background transparency.
Voice assistant
Recommended Home: New Home Recommended function to facilitate the understanding of the use of voice assistant skills.
Weather broadcast: voice broadcast new weather features, support local, remote, specify the date and check the weather broadcast.
Yesterday’s weather: Support inquiry yesterday’s weather.
FIX: Background music, call up voice dialing call assistant, concerts and voice calls overlap.
Map
Added: Settings - to switch cities, increasing urban phonetic lookup function.
New: Find alphabet offline download increase urban functions.
Browser
Card: add “microblogging headlines” and “Shopping” Card.
Check for updates: browser settings increase the “Check for updates” entry.
File Management
Installation package: The installation package management increase the installation status display.
Music: Music Category modifying information display.
Video: Video Classified by folder, adjust the thumbnail size.
Archive / document: Increase the number of files and folder size folder view, displays.
Image: Add all the documents classified, support slide switch. Folder view Add folder size information, all files sorted by date.
Optimization: picture folder view switching view increases memory function.
Optimization: picture category, priority picture folder name Remarks.
Download Manager
Optimization: Download Manager to download only the default environment in WiFi.
Music
Optimization: player interface “similar songs remind” can be turned off.
Fonte:meizufans
Ultima modifica di ultras1911; 30-03-16 alle 13:36
Si è uscita solo la A
