Pagina 19 di 22 primaprima ... 91718192021 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 212
[Box Tv] Minix Neo X8 / X8-H (AMLogic S802/S802-H - 2gb Ram - 16gb Flash)
  1. #181
    wlf
    wlf non è in linea
    Androidiano VIP L'avatar di wlf
    Ringraziato 259 volte in 221 Posts
    Quote Originariamente inviato da Simauro Visualizza il messaggio
    Questa 002 in che ai differenzia?
    Hanno fixato tutta una serie di problemini ...
    MINIX NEO X8/X8-H official 002A firmware change log (from 001 firmware):
    Release date: 13/12/2014
    Android system:
    2A - New ADPUS FOTA update software deployed
    2A - MINIX METRO launcher updated
    2A - Added Logitech Harmony remote support
    2A - Fixed Sopcast V1.1.0 no video issue
    2A - Added "HDMI & SPDIF passthrough" option
    2A - Fixed Vietnam TV streaming app problem
    - Firmware now based on release-keys instead of test-keys to improve app compatibility
    - Added key layout profiles for Mele F10/F10 PRO airmouse (CREDIT to HardwareGuru for providing us the KL files)
    - Fixed PS3 controller Bluetooth pairing issue (WARNING: Rooting the device voids the warranty)
    - Support Google TV remote app (Original Remote app option removed)
    - Fixed some apps got audio but no video issue (e.g. BEIN Sports, NBA Gametime, SPMC, etc.)
    - Fixed Google Contacts sync. issue (CREDIT to Finless Bob of Freaktab.com for providing the solving method)
    - Fixed Google Maps, Google Search...etc crashing issue
    - Fixed NEO M1 airmouse / Logitech K400 random reboot issue when using together
    - MINIX NEO series airmouse gyro sensors driver updated
    - Added support for the NEO A2, NEO A2 Lite airmouses
    - System performance enhancements
    - Added system performance optimizer by long pressing Menu key
    - Ethernet TCP buffer enhancement (CREDIT to Finless Bob of Freaktab.com)
    - Added show/hide status bar option (SETTINGS -> Display)
    - Added status bar safely unmount USB mass storage device option
    - Fixed "Choose date format" bug
    - Added Ethernet MAC address information
    - Enabled NFS/SMB cache
    - Fixed NTFS/NFS disk writing issue
    - Added "No output to USB audio" option (SETTINGS -> Display)
    - Added Dolby DRC setting (SETTINGS -> Display)
    Display:
    - Fixed some 4K TVs compatibility issues
    - Added DVI signal support for older TVs and monitors
    - Fixed HDMI hot plug couldn't get signal issue
    - Fixed various issues realted to HDMI-CEC
    - False HDMI status to allow some apps to run on HDMI output (e.g. SHOWTIME)
    Video:
    - Added 1080p24Hz HDMI output option
    - Fixed 23.976fps videos stuttering issue (@ 1080p24Hz, 1080p60Hz)
    - Fixed some 50fps video playback issue
    - Improved http live streaming performance
    - Fixed fast forward/rewind bug
    - Fixed video/audio unsync. issue of videos taken by cameras/phones/tablets
    Audio:
    - Fixed audio still output to HDMI while headphone is plugged in
    - Fixed audio output mode setting loss after unplugging headphone
    - Fixed passthrough audio going to both HDMI and SPDIF causing strange noises
    XBMC: (Wipe data is required to install this update automatically)
    - Updated to V13.3.3 MINIX XBMC BETA 6 (*Newer BETA 8 is available seperately at: ownCloud)
    - Added native support for auto refresh rate switching (users need to manually activate this feature)
    - 3D switching is now enabled
    - Fixed .ts files streaming issue
    - Fixed 720p user interface issue
    - Fixed vaious playback issues
    Problems NOT fixed on 2A yet:
    Bein Sports MENA -> Fixed - not release, testing internally
    Eurosport -> Still investigating
    Aggiornarnamenti fota che significa??
    Free On The Air, vale a dire aggiornamenti gratuiti automatici (senza procedure come quella dalla 001 alla 002).
    --- Edit ---
    Mi correggo ... "Firmware Over-The-Air"
    Ultima modifica di wlf; 06-03-15 alle 16:11
  2. Il seguente Utente ha ringraziato wlf per il post:
    Simauro (06-03-15)
    Samsung Galaxy Note N7000
    A quanto leggo penso sia necessario allora...grz
  5. #183
    Senior Droid L'avatar di Quak
    Consigliatissimo.... Come il firmware 003 assolutamente da evitare.... Quindi una volta aggiornato allo 002 consiglio non richiedere aggiornamento tramite Fota almeno fino a quando non correggeranno alcuni bugs...
  6. #184
    Quote Originariamente inviato da Quak Visualizza il messaggio
    ciao scusa, martedì sarò possessore dell'X8-H.
    A questo, secondo a quanto dici, conviene non aggiornare tramite Fota (003) e limitarsi al classico aggiornamento 002? Mi confermi questo? Grazie
  7. #185
    Quote Originariamente inviato da spatum Visualizza il messaggio
    Sembra che ci siano molti bugs nel firmware 003. Molti utenti hanno riscontrato problemi con skygo e con la visualizzazione di film in streaming, al momento meglio non aggiornare e rimanere sullo 002. Nb. Probabilmente il tuo minix arriva con FW001 e quindi dovrai aggiornare come tutti al FW002. E poi attendi che esca una versione con meno problemi che sarà aggiornabile via FOTA
  8. #186
    Grazie dell'informazione.
    Un'ultima cosa, posso passare al firm 001 direttamente al fim.002A senza mettere la 002? Oppure è un passaggio obbligato?
  9. #187
    FW 002 Realise date: 25/12/2014
    FW 002A realise date: 13/12/2014
    Io ho installato direttamente FW002
    Il FW 002A non l'ho proprio preso in considerazione...
  10. #188
    Mi sembrava di aver capito il contrario leggendo quanto appresso indicato reperito da un sito specializzato, dal titolo : "Rilasciato un update del firmware 2.0 per Minix NEO X8 e X8HS". In effetti, le date a fianco di ciascuna release sembrerebbero dire il contrario.. bho.
    ...In data odierna è stato rilasciato un aggiornamento del firmware 2.0 per dispositivi Minix NEO X8 e X8H. La nuova versione aggiornata, chiamata revisione A, risolve alcuni fastidiosi bug che alcuni utenti hanno riscontrato nelle ultime settimane.
    Il changelog è il seguente.
    Nel caso di utilizzo del dispositivo senza un airmouse, uno dei 4 core della CPU lavora sempre al 100%. Ne consegue un drastico calo delle prestazioni e, nel giro di pochi minuti il dispositivo si scalderà parecchio. Per questo motivo l’aggiornamento è decisamente consigliato.
    Il NEO X5 IR ora funziona correttamente.
    Fixato il bug che impediva la corretta accensione del led che indica il CAPS LOCK nell’airmouse NEO A2.
    Il bug nella funzione SMB sharing di XBMC Minix Edition è stato risolto, in particolare la versione installata di default di XBMC è ora la V13.3.3 BETA 6.
    Metro Launcher Ethernet/Wifi network broadcast status ->Aggiornato MINIX METRO launcher alla versione V1.6.
    Fixato il bug di Sopcast 1.1.0. Ora funziona perfettamente.
    Opzione HDMI passthrough & SPDIF passthrough aggiunta.
    Risolto il problema con l’app Vietnam Live TV.
    Per evitare confusione, l’opzione remote control è stata unificata nella voce Google TV Remote control.
  11. #189
    Apr 2010
    Scusami, ho appena comprato x8 h plus dove vedo quale firmware monta? Dalle info dice Kernel 3.10.33 del 22 novembre 2014......mi sa che è la 001. Dove trovo la 002? L'aggiornamento bisogna farlo dal computer? Grazie
  12. #190
    credo che il mio x8-h mi abbia abbandonato, all'improvviso
    come faccio a cancellare dati prima di renderlo ad amazon?
