Utente del giorno: megthebest con ben 5 Thanks ricevuti nelle ultime 24 ore
Visualizzazione dei risultati da 1 a 10 su 41
[Asus Zenfone 2] [Z00A] [ROM] Echoe Zen Rom v3 [2.20.40.165] -Overclock CPU GPU
    Nov 2015
    Z00A
    Segnalo questa Custom Rom basata su aggiornamento 2.20.40.165 (Testato e funzionante overclock stabile a 2500 Mhz )
    Link
    Changelog:
    - Updated to the Newest Official Asus Firmware 2.20.40.165
    Release Notes of the New Base
    Hide Spoiler
    1.Fixed Miracast connection issue (with car screen)
    2.Enhance Cell broadcast stability
    3.Remove Dr. Safety
    - Default Kernel: Ael Zen v3.1
    Changelog of the new Kernel:
    - Updated to newest Ramdisk 2.20.40.165
    Additional Changes/Additions:
    - Added a couple more options in the power menu
    - A Bunch of additional important build.prop tweaks for:
    (increased performance, better ram management, reduced ram memory leaks, better battery management, even more reduction of wakelocks, net tweaks and more..)
    - Default SystemUI is the fully modded one but with stock battery. If you want the 3minit battery pls visit the updated OTA kitchen via your settings
    [ASUS Zenfone2] [Z00A] [Z008] [KERNEL] [29 Jan 2016] Ael Zen v3.4
    FEATURES/ HIGHLIGHTS:
    - Built with the newest official Asus Source Code Version M912_V2_20_40
    - Compiled with Hyper Linaro 4.9 Toolchain with O3 and graphite optimizations
    - Newest Linux 3.10.95 (stock was 3.10.20)
    - Enabled CPU Overclocking and Underclocking
    - Unlocked GPU (max=640mhz, min=200 Use Synapse to control GPU)
    - Added the following additional CPU Governors:
    Lionheart, ConservativeX, bioshock, InteractiveX, adaptive, alucard,
    yankactive, lagfree, wheatley, peqasusq, darkness, nightmare, lazy,
    cyan, bluactive
    - Added the following I/O Schedulers:
    zen, sio, sioplus, fiops, fifo, zen, vr, tripNdroid, bfq
    - Enabled Sweep2Sleep (sweep from left to right to put the screen to sleep)
    - USB Keyboard/Mouse Hack
    (use your phone as a mouse and/or keyboard to control other devices- you need this app here: play.google.com/store/apps/det…hid.keyboard.client&hl=en )
    - BLX (Battey Life eXtender) Mod
    - Minimum brightness control [Use Synapse to control it]
    - Added Motorolla's "QuickWakeUp" Driver
    - Added Powersuspend Driver v1.5
    - Added UKSM (Ultra Kernel Same Page Merging)
    - Added Dynamic Fsync v1.5 by faux123
    - Enabled Zram
    - Enabled F2FS
    - Enabled NTFS
    - Enabled Async Fsync (ported from HTC)
    - Added frandom
    - Enabled advanced TCP congestions and added a few more TCP's
    . Added Drivedroid Patch (use your phone as a cd rom/usb to flash .iso images to your pc!!)
    (check here for more info pls: forum.xda-developers.com/showthread.php?t=2196707 )
    - Many more network and battery tweaks
    - Permissive kernel from source
    ## Recommended Kernel Control App: Kernel Adiutor
    ### [b] Synapse Control for certain features like GPU control, Minimum Brightness Control, etc. (to complement kernel adiutor)
    [You will find synapse app in your app drawer after flashing the kernel]
    Link
    Ultima modifica di chinemys; 02-02-16 alle 13:00
    ZenFone 2 ZE551ML
    come va rispetto alla rom di serie?
    Nov 2015
    Z00A
    Quote Originariamente inviato da spyke Visualizza il messaggio
    Ovviamente, molto meglio...consuma meno ed è più reattiva ,ha più opzioni di personalizzazione, il controllo della CPU ...ect....di tutte quelle che ho provato basate su Lollipop ,per me è la migliore .
  5. Il seguente Utente ha ringraziato chinemys per il post:
    spyke (08-02-16)
  6. #4
    ZenFone 2 ZE551ML
    Quote Originariamente inviato da chinemys Visualizza il messaggio
    Tenxx è in download.. erano mesi che non moddavo il telefono, l'ho sempre tenuto aggiornato via ota queto Asus..
    La 6.0 mica l'hai provata? vale la pena? o aspetto la ufficiale?
  7. #5
    Nov 2015
    Z00A
    Si,la sto usando in dual boot con questa ,viaggia molto bene ...per me ne vale la pena se vuoi un anticipo di Marshmallow
  8. #6
    Aug 2015
    Come si installa?
    Nov 2015
    Z00A
    Quote Originariamente inviato da AlviseRecon Visualizza il messaggio
    Come si installa?
    Ti serve avere il bootloader sbloccato,recovery twrp installata,e flash del file zip da recovery .
  10. #8
    ZenFone 2 ZE551ML
    Questa ROM è iperveloce ...volevo comprare un S6 edge ma penso che terròquesto 551ML , anche se ho la cassa audio fottuta e gracchia la voce , inascoltabile...ordinata 3 euro sulla baya chissà..
    Domanda , ho aelkernel3.8, il governatore CPU interactive è il migliore?
  11. #9
    Nov 2015
    Z00A
    Difficile risponderti ,non tutti i dispositivi si comportano nella stessa maniera ,sicuramente "interactive" è uno dei più comuni, e funziona sempre bene in genere.io mi trovò bene con hotplug nell'uso quotidiano ,sperimenta e vedi quello che ti sembra più adatto all'uso che devi farne .
  12. #10
    ZenFone 2 ZE551ML
    Ho fatto dei 3dmark ice storm unlimited con vari govern..il punteggio più alto 19300 l'ho ottenuto con kernel 3.8 default modificando la voce boost da 0 a 1 nel menù modifiche al governor. Tutti gli altri givernor peggiorano il punteggio.
