Pagina 129 di 200 primaprima ... 2979119127128129130131139179 ... ultimoultimo
Visualizzazione dei risultati da 1,281 a 1,290 su 1997
[ROM][4.4] CyanogenMod 11 - S3 mini
  1. #1281
    Senior Droid L'avatar di domenico08
    May 2014
    SIII Mini
    Ringraziato 113 volte in 110 Posts
    Nuova versione della cyanogen mod 11.0 rilasciata ieri
    Changelog:
    CM sources update
    with latest Samsung’s kernel for i8190 which thanks to our community we’ve received in 24 hours!
    new Samsung kernel updated to 3.0.101
    1GHz bug fixed!
    fixed issues with sensors
    fixed all wifi issues
    huge performance boost
    Odin package update
    Features:
    2D/3D HW Acceleration
    audio (both speakers/headphones/microphone)
    GPS and A-GPS – fast fix getting
    Glonass navigation
    compass
    sensors
    Wi-fi
    Bluetooth 4.0 with LE support A2DP
    all native tethers (Wifi/BT/USB)
    Google Play
    CM11 functionallity
    CPU sleep mode
    MTP
    ADB
    no tearing
    tripple buffering
    YouTube HQ
    3.0.101 kernel
    external storage
    full f2fs support – the best filesystem for Android (tutorial here!)
    native 64GB+ sdcard support (exFAT)
    camera
    video playing
    SELinux (temporary disabled)
    BLN (backlight notifications) support
    offline charging
    New BT/GPS/offline charging/sensors drivers – no longer buggy Samsung’s ones!
    built using NovaTP GCC4.9 toolchain
    no 1GHz bug
    USB OTG support (WIP)
    also flashable via Odin
    Issues:
    none
    Qui i link al download diretto senza aspettare le due ore (per i nuovi) recovery : http://get.novafusion.pl/file/581582...a.20140724.zip odin: http://get.novafusion.pl/file/530696....ODIN_TWRP.zip
    Buon Flash!
    Se ti sono stato utile clicca sul tasto Thanks
  2. Il seguente Utente ha ringraziato domenico08 per il post:
    corradiani (29-07-14)
    Androidiano L'avatar di KoRnFactory
    Torino
    Samsung Galaxy S5
    Ringraziato 58 volte in 53 Posts
    Quote Originariamente inviato da domenico08 Visualizza il messaggio
    Changelog:
    CM sources update
    1GHz bug fixed!
    Odin package update
    Features:
    Glonass navigation
    compass
    sensors
    Wi-fi
    Google Play
    CM11 functionallity
    CPU sleep mode
    MTP
    ADB
    no tearing
    tripple buffering
    YouTube HQ
    3.0.101 kernel
    external storage
    camera
    video playing
    offline charging
    no 1GHz bug
    Issues:
    none
    Buon Flash!
    Sei arrivato tardi 😁
    Per rispondere alla domanda, nessun bug, anzi, quella di ieri è una bomba.
    Phone: Samsung Galaxy S5 SM-G900F
    ROM: CyanogenMod 13 Official
  5. Il seguente Utente ha ringraziato KoRnFactory per il post:
    8balls (25-07-14)
  6. #1283
    Androidiano L'avatar di LukeDaniele
    Samsung S3 Mini con CM 11
    Ringraziato 48 volte in 46 Posts
    Quote Originariamente inviato da fabry90 Visualizza il messaggio
    Ragazzi, avrei bisogno di un informazione.
    Volevo sapere se nell'ultima release ci sono bug importanti. Dovrei flasharla sul telefono della mia ragazza e voglio che gli funzioni tutto sopratutto la fotocamera. Posso flashare tranquillo?
    Flasha tranquillo ma ricordati che perdi tutto perciò fai un backup di ecc. Inoltre esporta tutti un contatti in vcf perché la cyano non legge la Sim
    Inviato dal mio S3 Mini con CyanoGenMod 11 usando Androidiani App
    Samsung Galaxy S3 Mini
    CyanogenMod 11
    Recovery: TWRP
    iPod Touch 4g
    iOS 6.1.6
    Jailbreak by p0sixspwn
    Acer Aspire 5755G
    Intel Core i5 2.4 GHz con TurboBoost 3.0 GHz
    4 GB di RAM
    Windows 7 Home Premium
  7. #1284
    May 2014
    SIII Mini
    Quote Originariamente inviato da KoRnFactory Visualizza il messaggio
    Sei arrivato tardi ��
    lo so che è una bomba l'ho flashata ieri sera vedo se con questo kernel riesco a fare lo swap...
    Torino
    Samsung Galaxy S5
    Rispondevo alla domanda del post prima di te.
  9. #1286
    May 2014
    SIII Mini
    Swap fallito, questo kernel non è compatibile per lo swap della ram, speriamo che in una prossima relase maclaw ci faccia questo regalino
    Senior Droid L'avatar di doublefaces95
    Io direi a questo punto di rifare i wipe, e se non va di flashare un'altra versione della rom, rifacendo ancora i wipe, per essere puliti.
    Che versione hai flashato?
    Quella di ieri, ora flasho la stock e vi faccio sapere se non ci sono problemi
  11. #1288
    SurvivalModder
    Quote Originariamente inviato da doublefaces95 Visualizza il messaggio
    [quote name="KoRnFactory" post=5907287]Io direi a questo punto di rifare i wipe, e se non va di flashare un'altra versione della rom, rifacendo ancora i wipe, per essere puliti.
    Quella di ieri, ora flasho la stock e vi faccio sapere se non ci sono problemi[/QUOTE]
    Ma se flashi quella stock sulla cm, quindi in sostanza effettui un downgrade, non ci sono incompatibilità di kernel, etc? Avevo sentito parlare di questi "errori" del downgrade....
    Inviato dal mio M-PPG700 usando Androidiani App
  12. #1289
    Androidiano VIP L'avatar di wonderdroid
    venezia
    google pixel 4 iphone xs
    Ringraziato 227 volte in 208 Posts
    Quando flashi con odin e metti stock fai un erase totale quindi non ci sono problematiche,segui la guida e sei apposto
    Memento audere semper
  13. #1290
    Nov 2013
    Salve ragazzi,ho un problema riguardante la CM11 4.4.4,dopo averla flashata tramite recovery appena partono le schermate per impostare lingua,orario e account cyano crasha l'app gestore temi facendo uscire il messaggio del blocco del processo praticamente ogni secondo rendendomi inutilizzabile la ROM,ciò mi succede anche con la carbon sempre 4.4.4...non so che fare,ho provato a flasharla più volte ma nulla il problema persiste...avete qualche soluzione per questo problema?
    Grazie in anticipo.
