Pagina 8 di 85 primaprima ... 6789101858 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 846
[KERNEL] Franco Kernel |4.0.3| Milestone 2
  1. #71
    Androidiano VIP L'avatar di matiu
    Apr 2009
    Localitā
    Rimini
    Ringraziato 122 volte in 116 Posts
    finalmente!
    Non rispondo a messaggi privati!
    Le domande fatele sul forum.
    Senior Droid L'avatar di pav_87
    LG Nexus 5
    Ringraziato 21 volte in 21 Posts
    A me sembra aumentata la fluiditā,a voi?
    Inviato dal mio Galaxy Nexus usando Tapatalk
    Galaxy Nexus
  4. #73
    Androidiano L'avatar di Bartman
    changelog:
    25th January - nightly #14
    * Bumped up some bus frequencies
    * Added two omap patches that fix two false IO wakeup detections
    * GPU Overclocked again to 384
    * Changed the voltages file to increase stability
    * C4 state patch reverted - according to Colin Cross (Google Android team) it can only save 2mAh max during idle, but it could cause some instability, thats why they reverted it as well. I want stability, so this stays reverted
    * VM_Readahead values hardcore - now it's set to 512kbs
    * CIFS added as a module
    * Writeback values reverted back to stock - they seemed to perform extremely well in conjunction with the Writeback IO backport from 3.2
    * Conservative governor tuned again - what I did this time is pretty simple, this governor now only jumps between min frequency and max frequency. Why this? Because I want to minimize any kind of lag that "can" happen when polling and then ramping up step by step to max frequency. To balance the battery/performance ratio I increased the ramp_up threshold from 60% to 80% CPU load, which means that while it doesn't use the 920 step (in the 700min-1200max scenario, since it's the default and the one that I recommend) it will ramp less times to max frequency. This is wielding the best results in the last 24 hours for me and my testers didn't complain at all, quite the contrary
    Ultima modifica di matiu; 25-01-12 alle 23:36
  5. #74
    Androidiano L'avatar di jigenstyle
    Nella 14 cambiate il governor in conservative...franco ha sbagliato e ha messo perfomance
  6. #75
    Androidiano VIP L'avatar di enricoandreoli
    Sep 2010
    Localitā
    Mirandola (MO)
    Non ho uno smartphone
    Ringraziato 117 volte in 100 Posts
    UUUUUUUPDATE del primo post Ovviamente Nightly 14!
    Caporedattore di Androidiani.com
    Google e il tasto cerca sono i vostri migliori amici
  7. #76
    Scusate ma le gapp le devo flashare???
    Hehehehe
    Sono sempre il primo.... A dare le news
  8. #77
    Senior Droid L'avatar di alexdesire
    Jul 2010
    Galaxy S III
    Ringraziato 91 volte in 83 Posts
    Quote Originariamente inviato da Bartman Visualizza il messaggio
    Hehehehe
    Ahaha bart pensavo lo stessi chiedendo davvero.
    P.s. Non ho modo di provarlo ora. Come vi sembra? Dal changelog sembra migliorare in stabilita e prestazioni.
    Galaxy S III: S4 Revolution v6.0
  9. #78
    Sep 2010
    Localitā
    Mirandola (MO)
    Hehehehe
    Io giuro che ti odio!!!
    Quote Originariamente inviato da alexdesire Visualizza il messaggio
    Io l'ho appena flashato, per ora non dico niente..l'effetto palcebo si sente troppo :P
  10. #79
    Androidiano VIP L'avatar di simone87stilo
    Localitā
    Pontecchio Polesine (ROVIGO)
    LG G4
    Ringraziato 187 volte in 172 Posts
    Appena flashato mo vediamo
    Se il mio aiuto č servito, un click su "Thanks" č sempre gradito!
  11. #80
    Localitā
    LG G4
    Quote Originariamente inviato da jigenstyle Visualizza il messaggio
    Comunque non č vero, nella 14 il governor č in conservative non in performance. Almeno a me č messo corretamente e l'ho flashato 2 minuti fa. Da te era impostato diversamente?
LinkBacks (?)
