Pagina 95 di 191 primaprima ... 45859394959697105145 ... ultimoultimo
Visualizzazione dei risultati da 941 a 950 su 1906
[ROM] CyanogenMod 9
  1. #941
    Androidiano VIP L'avatar di simone87stilo
    Pontecchio Polesine (ROVIGO)
    LG G4
    Ringraziato 187 volte in 172 Posts
    An si davvero? Bene bene quindi quella che sta per usdcire sarà la build 0528? o sbaglio?
    appena esce la fhasho. sai dirmi quando esce oggi magari?
    Se il mio aiuto è servito, un click su "Thanks" è sempre gradito!
    Banned
    update-cm-9-20120529-NIGHTLY-maguro-signed.zip
    fix build, by adding @hide to android.provider.Settings.System.SAFE_HEADSET_VOLU ME_RESTORE (android_frameworks_base)
    phone settings: do not present duplicate operators to the user (android_packages_apps_Phone)
    apps/Phone: Display Short Name/MCCMNC if Long Name is empty in manual search. (android_packages_apps_Phone)
    packages/apps/Phone: squashed clean up of NetworkSettings from CAF (android_packages_apps_Phone)
    Lockscreen weather: option to invert low/high temp display (2/2) (android_packages_apps_Settings)
    Lockscreen weather: option to invert low/high temp display (1/2) (android_frameworks_base)
    Fix typo in queue_property_triggers ident (android_system_core)
    init: Fix charger mode for qcom devices (android_system_core)
    Camera: Hide storage option if device only has one storage (android_packages_apps_Camera)
    Fix Samsung chargermode logic (android_system_core)
    audio/msm7x30: fix voice volume on first call (android_hardware_qcom_media)
    audio/msm8660 fix voice volume on first call (android_hardware_qcom_media)
    audio/msm8660: Fix for no voice during voice call after SSR (android_hardware_qcom_media)
    Lock screen settings: Add dependency for 'Power button instantly locks' pref. (android_packages_apps_Settings)
    Settings: Fixed German translation for activating bluetooth/wlan (android_packages_apps_Settings)
    charger: allow custom charger res (android_system_core)
    Add Finnish predictive dictionary support - spellchecker (android_packages_inputmethods_LatinIME)
    french: weather translations (android_frameworks_base)
    CpuGovernorService for all, optional iobusy server thread (android_frameworks_base)
    Xcode 4.3 compatibility checkin (android_frameworks_base)
    Xcode 4.3 compatibility checkin (android_external_e2fsprogs)
    CMWallpapers: Finnish translation (android_packages_apps_CMWallpapers)
    PT-BR: Navigation bar translations (android_frameworks_base)
    Disable the IllegalStateException on route del (android_frameworks_base)
    PT-BR: Various missing translations (android_packages_apps_Settings)
    system/core: Support for audio routing to WiFi Display device (android_system_core)
    hardware/libhardware_legacy: Add support for audio on WiFi Display device (android_hardware_libhardware_legacy)
    Superuser - Update Italian Translation Thanks To Moreno Pojer (android_packages_apps_Superuser)
    DeskClock - Update Italian Translation (android_packages_apps_DeskClock)
    Settings: added and updated Dutch translations (android_packages_apps_Settings)
    Update to upstream 2012.55 (android_external_dropbear)
    Merge upstream v1.4.14 (android_external_iptables)
    audio: Disable debug messages in log (android_hardware_qcom_media)
    toolbox: implement rm -f flag (android_system_core)
    Settings: Update Spanish translations (android_packages_apps_Settings)
    Settings: Update Spanish translations (Sound Section) (android_packages_apps_Settings)
    Add OMAP_COMPAT and OMAP_ENHANCEMENT frameworks flags (android_frameworks_base)
    libnl2: Add the missing callback handler functions (android_system_core)
    Change APP_SWITCH key event to open Android 4.0 recent apps switcher (android_frameworks_base)
    Make 'Power button instantly locks' toggle work (2/2 settings) (android_packages_apps_Settings)
    Make 'Power button instantly locks' toggle work (1/2 framework) (android_frameworks_base)
    Japanese: add missing translations. (android_packages_apps_Settings)
    SystemUI : Dismiss keyguard on powerwidget longpress (android_frameworks_base)
    Sound preference: Safe volume restore when plugging in a headset (1/2) (android_frameworks_base)
    Sound preference: Safe volume restore when plugging in a headset (2/2) (android_packages_apps_Settings)
    LatinIME: Fix Czech QWERTY keyboard (missing no. 6) (android_packages_inputmethods_LatinIME)
    InCallScreen: change orientation to nosensor (android_packages_apps_Phone)
    Change proximity behaviour for devices with fixed keyboard (android_packages_apps_Phone)
    PT-BR: Flip action translation (android_packages_apps_DeskClock)
    PT-BR: SMS to MMS translations (android_packages_apps_Mms)
    PT-BR: Extended quick controls translations (android_packages_apps_Browser)
    queryContactInfoForPhoneNumber:query only incoming (android_packages_apps_Contacts)
    Torch: Fixed various layout items (android_packages_apps_Torch)
    Torch: modified widget setup UI (android_packages_apps_Torch)
    Fix build on gcc 4.6. (android_bootable_recovery)
    Updated Hebrew Translation: flip to snooze (android_packages_apps_DeskClock)
    Browser: New navbar buttons (android_packages_apps_Browser)
    Add Dutch predictive dictionary support (android_packages_inputmethods_LatinIME)
    Improve Finnish translations (android_packages_apps_DSPManager)
    Ultima modifica di Gynlemon; 29-05-12 alle 11:06
  4. #943
    Androidiano L'avatar di TheDarkness90
    Mar 2011
    Catania, Italy.
    Galaxy Nexus
    Ringraziato 26 volte in 23 Posts
    c'è già la limitazione del kernel??
  5. #944
    Banned
    Quote Originariamente inviato da TheDarkness90 Visualizza il messaggio
    del tipo??
  6. #945
    Mar 2011
    Catania, Italy.
    Galaxy Nexus
    del tipo??
    quella di cuoi si parlava qualche giorno fa o il kernel cm9 o niente..
    e inoltre adesso si possono modificare le icone nel menù notifiche??
    Ultima modifica di TheDarkness90; 29-05-12 alle 12:13
  7. #946
    Banned
    Non ho più seguito quella parte.. non mi riguarda a mio avviso.. Ho su la CM9 con il suo kernel.. se non dovessi più trovarmi con i consumi.. ho in backup la EOS_Team.. non ci metto molto..
  8. #947
    Baby Droid L'avatar di Asteroid
    Ancona
    Google Galaxy Nexus
    Io sono passato alla CM9 da alcuni giorni, provenendo dalla android revolution. Ora sono all'update 0527. Kernel di base.
    Sono contento in generale di tutte le features introdotte. Gli unici problemi che ho riscontrato sono la minore durata della batteria e la luminosità (che potrebbero essere correlati) . Secondo me la luminosità automatica imposta un livello troppo alto. Al buio ad esempio non si setta sul minimo. Sono l'unico?
    Per il resto va alla grande, fluidità spaventosa
  9. #948
    Mar 2011
    Catania, Italy.
    Galaxy Nexus
    e quanto fai di durata con il kernel di base?
  10. #949
    Banned
    Solo spostare o ordinare gli interruttori.. se intendi cambiare icone a mettere a tua scelta no..
    1 giorno pieno con uso mio da sempre.. ( tenendo conto anche che lo scarico e l'installazione di una Nightly comporta consumo )
    1 giorno e mezzo se non lo masturbo ...
    La luminosità è settata in manuale circa 40% e lasciato tutti i valori di default.. non mi piace per nulla la gestione automatica.. però chiaro che un consumo in più ci sta..
    Ultima modifica di Gynlemon; 29-05-12 alle 12:27
  11. #950
    May 2009
    Caserta
    Ringraziato 211 volte in 112 Posts
    Quote Originariamente inviato da Asteroid Visualizza il messaggio
    Prova ad impostare i livelli di luminosità manualmente.
    Ciao
