Pagina 306 di 363 primaprima ... 206256296304305306307308316356 ... ultimoultimo
Visualizzazione dei risultati da 3,051 a 3,060 su 3630
[ROM] [AOSPA 4.2.2 jdq39] PARANOIDANDROID
  1. #3051
    Senior Droid L'avatar di bilel96
    Samsung Galaxy Nexus
    Ringraziato 57 volte in 50 Posts
    Quote Originariamente inviato da ButelBG Visualizza il messaggio
    Installo sempre con wipe cache & dalvich + format system
    Lo hai segnalato il bug?
    Se ti sono stato d'AIUTO clicca sul tasto THANKS
    Senior Droid L'avatar di ButelBG
    Ringraziato 31 volte in 30 Posts
    Quote Originariamente inviato da bilel96 Visualizza il messaggio
    Come devo fare?
  4. #3053
    Come devo fare?
    https://plus.google.com/u/0/app/basi...49478109338346
  5. #3054
    Hammerhead Miui 6.10.13
    Ringraziato 76 volte in 64 Posts
    Come devo fare?
    I bug vanno segnalati qui, nella community i developers non se li ca*ano e rischiano di andare perduti: https://paranoidandroid.atlassian.net
  6. #3055
    Rilasciata 4.4 beta 1!!!! Raccomandano un bel clean install!!
    4.4 BETA1
    On this week’s dose of awesome sauce from PA Headquarters. We are proud to bring you Theme Engine, a stable Hover and a bunch of fixes. Hats off to CM, Clark Scheff, Andrew Mast and Sony mobile, for their work on Theme engine Truly outstanding work. Porting it to an AOSP base was a massive effort, lead by +Carlo Savignano . We tried to do it in a way so that it can be easily ported to other AOSP based ROMs for the benefit of the entire community. We are also proud to mark Hover stable, after many betas and three rewrites. We apologize for all the betas, but we really wanted to try to get this right, we encourage you to compare this build to beta 1, some major improvements have been made. The lessons learned here means more/quicker awesomeness in the future. With Google IO only a month away we are nearing the end of Kitkat, but that doesn't mean development is slowing down. Our team is comprised of numerous students and with school ending we are now doubling down on making PA awesome, we plan to finish strong and have a few Major projects to release that we have been working on internally for quite some time. Awesomeness is coming
    P.S. This is still 4.4.2. We have merged and are testing 4.4.3 internally but it was released too close to our release to allow enough time for adequate testing.
    P.S 2 Like the Themes shown off in the image below they were made by our own +Matt Flaming and +Lo Huot and are available on the play store (PiazzA will be available soon). Show them some love.
    General
    - Translated into over 30 languages!
    - Backported numerous fixes from AOSP master.
    - Improved quicksettings.
    - Removed lockscreen blur feature in favour of custom lockscreen background from
    Theme Engine (it will come back as a component of theme engine in the future).
    Theme Engine
    - Bring full CM11 theme engine. (First AOSP based ROM!!)
    - WARNING: Home button gets refreshed only after reboot or by force killing SystemUI if you want to a avoid reboot. Will be fixed in next build.
    Hover
    - Stable status!!
    - Removed Jank (its a technical term)
    - Fixed remaining bugs, including spam and invisible notifications.
    - Fully working and improved inCallUi.
    - Restored default swipe to dismiss behavior. An upcoming swipe up gesture will let you dismiss
    hover as was replacing the old behavior.
    Pie/Immersive
    - Fixed immersive API Thanks for the developers who helped diagnose the issue
    - Vastly improved triggering, and allow you to trigger from any area on the edge on tablets.
    - Pie now rotates like the navBar (will appear on short edge).
    - Enabled pie only on immersive mode enabled by quick settings tlie (not in app immersive).
    - Fixed AOSP immersive bug issue where apps would register a touch when swiping statusBar
    and/or navBar.
    - Fixed numerous freezes.
    WARNING: We recommend a clean flash this time due to massive changes
    Builds: Stay Paranoid
    Bugs: https://paranoidandroid.atlassian.net
  7. #3056
    LG Nexus 5
    Quote Originariamente inviato da Caluz Visualizza il messaggio
    Clean install quindi compreso il wipe data? Comunque speriamo che il theme engine non porti casini come su cm..
  8. #3057
    Quote Originariamente inviato da kappa04 Visualizza il messaggio
    Esattamente.
    La sto installando.. Vi faccio sapere come gira..
  9. I seguenti 4 Utenti hanno ringraziato Caluz per il post:
    kappa04 (03-06-14),kojakcr (03-06-14),lorythelegend (03-06-14),morfances (03-06-14)
  10. #3058
    Esattamente.
    Ecco nel caso di clean install come riesco poi a ripristinare tutte le app/dati in un colpo solo,come sarebbe per intenderci senza fare il wipe data normalmente?
    Voi come fate(tipo con titanium o altro)?
  11. #3059
    Senior Droid L'avatar di kojakcr
    Sep 2013
    Gnex G2 honor8 Zuk Z1 Op3
    Ringraziato 274 volte in 232 Posts
    [quote name="kappa04" post=5707108]Clean install quindi compreso il wipe data? Comunque speriamo che il theme engine non porti casini come su cm..
    Esattamente.
    La sto installando.. Vi faccio sapere come gira.. [/QUOTE]
    Ciao Caluz, visto che monti questa ROM da un po, volevo sapere come va a consumi avendo una batteria standard da18 mesi e usandolo per lavoro.
  12. #3060
    Salerno
    galaxy nexus
    Ringraziato 85 volte in 79 Posts
    Aggiornata all ultima versione, a parte che non ho capito come si usa themer :-P, sembra un tantino lenta...
