Pagina 1 di 129 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 1289
[ROM] FoxHound 0.4 By SnakeS|4.0.4| (stabile)
    Senior Droid L'avatar di spiritualized
    Apr 2010
    nokia lumia 820 (muletto)
    Ringraziato 73 volte in 53 Posts
    1) Copy the ZIP file (not unzip) the Foxhound in the phone memory
    3) Disconnect the USB stick and restart the phone in recovery mode
    4) Select the "Wipe Data" then "wipe cache partition" just did a wipe select the "advanced" and "Wipe Dalvik Cache"
    5) Now select "Install from sdcard zip" and install the ROM
    7) After installation select "reboot system now"
    *Full AOSP 4.0.3 IML74K
    *Superuser
    *Deodexed
    *Zipalinged
    *Insert Busybox
    *Unsecured Kernel
    *FoxHound bootanimation
    *Nova Launcher By kevin@TeslaCoil
    *Added Power menu
    *New StatusBar whit animation (beautifull) Thanks to shane6374 for halp
    *Insert circle battery icon 1% on default
    *Stock Dialer (more stable)
    *Added STK (sim tool kit)
    *Themed some apk icon (ZeuBug style)
    *New look on stock clok widget
    *Added Facebook sync (Thanks to paulobrien and Romanbb)
    *GPS Tweaks on Europe
    *Egl.cfg tweaks
    *Xloud ported enable to default - improve sound speaker
    *Bravia Engine ported enable to default - more quality image
    *Tweaks JakebitesModsv22 (thanks jakebites)
    *Sd card tweaks speed
    *Crond enabled
    *Improved Audio in Media_Profiles.xml
    *Gapps included with this build
    *Zipalinged app on boot (disable on default)
    *Fix Init.d support
    *Added camera button mod (thanks runandhide05)
    *Included Auto EFS Backup in init.d By Paul (Modaco)
    *Tweaks in Build.prop
    *Last Gapp thanks kejar31
    *Best battery life
    *All app resigned
    *Added all missing live wallpapers
    *Removed AOSP music added music2
    *Added Data Folder and insert this app: (now removable)
    *Added file manager
    *Added Ligth Flow app to change LED notification color
    *Added Flashplayer
    *Added Tork
    *Added Sound Recorder
    Imoseyon_leanKernel_v1.3.0gnexus
    FEATURES
    Patched to latest in Linux 3.0.x branch: 3.0.14, which was released 12/21/11 (lots of new/updated kernel code).
    All unnecessary kernel components removed to make kernel lean and fast!
    OC to 1.35Ghz (Michael Huang, optimized by me). Boot speed is maxed at 1.2ghz within kernel (in addition to ramdisk) for stability.
    GPU overclock (Michael Huang).
    User voltage control (Michael Huang, fixed and enhanced by me).
    InteractiveX V2 (screen-off hotplug of cpu1) added. Select it using setcpu if you want to use it.
    Ramdisk tweaks (sysctl, vm, filesystem speed, etc.)
    SWAP & zram (next generation compcache) support. Run "zram enable" in terminal.
    init.d support in ramdisk.
    Hotplug governor optimized for stability.
    cpufreq backport from Linux 3.2-rc7
    rcu code backport from Linux 3.2-rc7
    other linux 3.2 backports: dm, futex, etc.
    Undervolted by default (1.35ghz/1325, 1.2ghz/1300, 920mhz/1250, 700mhz/1150, 350mhz/950)
    CHANGELOG
    v1.0.0 - Initial release
    v1.0.1 - Fixed power off charging (only upgrade if you care about that).
    v1.1.0 - rcu code updated to linux 3.2-rc7, boot speed max forced to 1.2ghz within kernel (stability), hotplug governor should be more stable now, zram enabled including custom enable script (run "zram enable" in terminal), small bug fixed in voltage control code.
    v1.2.0 - interactiveX V2 with hotplug support, user undervolting works now, and all speeds undervolted by default (clear setcpu settings before flashing), ALSA SoC driver updated to 3.2-rc7
    v1.2.1 - reverted a dep voltage change I made in 1.2.0. Only update if you're experiencing stability issues in 1.2.0 (if your coming directly from a version prior to 1.2.0 make sure you clear custom voltage settings)
    v1.3.0 - re-wrote a lot of my user undervolting code (fixed some bugs and probably introduced others - haha)
    updated dm and futex code to linux 3.2, gpu undervolt at top speed
    some code cleanup. (clear setcpu settings before flashing).
    Oh one more thing: undervolting 1.35ghz and higher is not reliable yet and is not recommended.
    Source Kernel
    FoxHound 1.1 Download
    Fix Phone Call + T9 Dialpad
    Restore Stock icon: Download
    SystemUI without PullDown Animation Download
    CREDIT:
    kevin@TeslaCoil
    shane6374
    Paulobrien and Romanbb
    jakebites
    runandhide05
    imoseyon
    kejar31
    acer73
    Thread XDA
    Ultima modifica di matiu; 13-02-12 alle 13:21
    La cina è buona per le cinesi e per gli smarthphone.
  2. I seguenti 4 Utenti hanno ringraziato spiritualized per il post:
    bilel96 (10-05-12),EnzoTekno (16-03-12),golD (28-12-11),Rock Elite (10-04-12)
    Androidiano VIP L'avatar di mikyfootball
    samsung galaxy s2
    Ringraziato 136 volte in 126 Posts
    Grazie della segnalazione..per l'sgs2 la foxhound era la mia rom preferita..speriamo che sfornerà qualcosa di buono
    Inviato dal mio Galaxy Nexus usando Tapatalk
    Samsung Galaxy S
    Samsung Nexus S
    Samsung Galaxy Nexus Prime
    Samsung Galaxy S2
    Samsung Galaxy S3
    Iphone 5 bianco e nero
    Htc One silver ***ATTUALE***
  5. #3
    Ma con tutto quell'overclock non rischia di consumare troppo la batteria?
  6. #4
    Apr 2010
    Solo provando lo sapremo
  7. #5
    Androidiano L'avatar di CraxyTy
    Feb 2011
    LG G3
    Ringraziato 32 volte in 18 Posts
    La provo subito...
    Ha delle feature interessanti! Raffaele è già sul campo da tempo
  8. #6
    Apr 2010
    Potete scaricare adesso
    Ultima modifica di spiritualized; 28-12-11 alle 21:04
  9. #7
    Apr 2011
    sto scaricando anche io... è molto lenta... altrimenti provo quella del Team Gummy Charged... sono indeciso, qualcuno ha già messo questa?
  10. #8
    Apr 2010
    la gummy l'ho provata per un pò ma sukka troppa batteria per me
  11. #9
    Apr 2010
    in arrivo la versione 1.1, di già ????
  12. #10
    Apr 2011
    Quote Originariamente inviato da spiritualized Visualizza il messaggio
    accazzz grazie per la info... la revolution è parsimoniosa in termini di consumo di batteria, aspetto di scaricare questa allora (con la chiavetta, uffi) ... speriamo bene...
