Utente del mese: megthebest con ben 15 Thanks ricevuti nell'ultimo mese
Visualizzazione dei risultati da 1 a 10 su 27
[ROM] RASBEANJELLY Maguro OTA By Rascarlo
    Senior Droid L'avatar di Avan3t
    Ringraziato 15 volte in 12 Posts
    Ho notato che questa ROM manca in questo forum... mi sono permesso di postarla... Changlog a seguire...
    changelog:
    changelog:
    - first build
    - power menu with screenshot and reboot options
    - power widget
    - volume rocker music control
    - volume rocker wake
    - long press to kill
    - battery percentage
    - expose rotation lock toggle (hidden in stock os)
    - black and holo blue glow ui
    - black ui for contacts
    - frameworks and performance optimization
    ### Flash
    - wipe cache
    - wipe dalvik cache
    - flash zip
    - (opt.) flash kernel since it comes with stock (i would flash trinity)
    - reboot
    - log into google and let it sync
    - (opt.) push your busybox in the way you want or use Stericson BusyBox
    - fix_permissions
    - (opt.) reboot
    ## About busybox
    Quote from stericson email:
    "The free apk, or the binary is fine.
    Actually, I wish more rom devs included the free version in their roms.
    It would help keeping busybox standard across different roms instead of devs having different tweaked modified version of busybox that don't have all the functionality needed by other applications.
    Pleasure is all mine.
    Honored to have an application baked into a rom.
    ### gapps?
    included
    ### md5sum
    you can also download the md5sum file and check in TWRP
    ### Any official thread?
    Support can be found in the trinity kernel thread for your device on xda.
    ### I am @rascarlo on twitter
    Download
    euroskank
    Avevo la rascream ed era ottima. Poche personalizzazioni, durata batteria buona, prestazioni e stabilirà massima magari aspetto che aggiunga altre personalizzazioni prima di provarla.
    Xiaomi Mi3 + MiBand: Miui 6 Android 4.4.4 - Stock
    Galaxy Nexus: Cyanogenmod 11 Android 4.4.4 - Stock CM11
    Optimus One: Cyanogenmod 7.2 Android 2.3.7 - Stock CM7.2
    Optimus Net: Cyanogenmod 7.2 Android 2.3.7 - kido
    anche io aspetto un release performante e con meno bug... in accoppiata con il trinity è divina anche se... ill mio Gnexus non ne vuole proprio sapere di fare benchmark normali... con antutu e company
    È disponibile ma nuova versione
  6. Il seguente Utente ha ringraziato gompaky per il post:
    Avan3t (07-08-12)
  7. #5
    già provata ottima...già si sta formando la ROM
  8. #6
    Siamo già alla quarta versione, lo sviluppo procede spedito
  9. #7
    Bene
  10. #8
    May 2010
    Ringraziato 29 volte in 22 Posts
    Abbinata al trinity é una delle migliori sia come fluidità , sia come consumi
    Tapatalked from my Gnex Trinity powered
  11. #9
    Dec 2009
    Ringraziato 13 volte in 8 Posts
    Ottima veramente... finalmente una durata della batteria ottima!
  12. #10
    La rascream era splendida. Se aggiunge qualche opzione in più per le modifiche la metto subito
