Pagina 59 di 71 primaprima ... 949575859606169 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 706
[Guida] Nexus toolkit | sblocco| root | backup| factory restore
  1. #581
    Androidiano L'avatar di nerodivenere
    vicino ivrea
    Ringraziato 2 volte in 1 Post
    ehm..perdonate..ma non ho letto tutte le 61 pagine..
    ed è una mezza giornata che googlo ..
    ma per chi avesse un nexus JB 4.2.2 e..... il mac ??
    tutte ste guide sono solo per win mi pare di aver capito.......
    Tattoo, BodyPainting, FineArt
    http://www.nerodivenere.com
    Banned
    Quote Originariamente inviato da nerodivenere Visualizza il messaggio
    Sicuro di aver cercato bene? https://www.google.com/webhp?client=...w=1280&bih=800
    Inviato da Gynlemon dal mio Xoom
  4. #583
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    SAMSUNG GALAXY NEXUS TOOLKIT AUTO UPDATE V11.2.0 AVAILABLE!!
    mskip May 8, 2013 Samsung Galaxy Nexus,
    Changelog:
    +Added missing Superuser apk file from chainfire root from V11.0.0 public build
    +Added Clockworkmod Root 1.0.1.8 to replace ChainsDD method for better support
    ALL root methods in the Toolkit now include Clockworkmod Superuser method
    +Added TWRP NAND backup/restore procedures and finally FIXED all NAND procedures
    +Added Universal driver pack from koush which works well on Windows 8
    +Added Sideload another zip file whilst in Recovery to save time [user request]
    +Added Toolkit Hard Reset option in Toolkit Settings screen
    +Added text in driver install screen to test drivers properly
    +Added more stability
    [Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the professional features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other professional features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please email me at toolkit.support@skipsoft.net about them and do not post in the open thread]
    Thread Link: [GNEX TOOLKIT V11.1.0] Drivers, Backup, | Galaxy Nexus > XDA
    Mark.
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
  5. #584
    Senior Droid L'avatar di leonardodettoileo
    Galaxy nexus e ipad 3!!
    Ringraziato 417 volte in 317 Posts
    Quote Originariamente inviato da paolocorpo Visualizza il messaggio
    Changelog:
    Mark.
    Ciao Paolo scusa ma che differenza c'è un questo update rispetto alle 2 versioni precedenti?
    Se ti sono stato di aiuto clicca "mi piace" se no ti vengo a cercare!
  6. #585
    SAMSUNG S20+5G
    Quote Originariamente inviato da leonardodettoileo Visualizza il messaggio
    Se tu eri giunto alla 11.0.0 per successivi update da quelle precedenti (e ciò perchè avevi la donate versione come me) non credo ci siano fondamentali cose ma comunque non costa nulla ... aggiornalo
    Se invece hai usato il toolkit per la prima volta con la 11.0.0 allora si fai questo aggiornamento o meglio reinstalla la public 11.1.0
    Ultima modifica di paolocorpo; 08-05-13 alle 17:29
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  7. Il seguente Utente ha ringraziato paolocorpo per il post:
    leonardodettoileo (08-05-13)
  8. #586
    Banned
    Seguiamo i thread specifici https://www.androidiani.com/forum/mo...one-nexus.html non sporchiamo questo cui si discute solo della tematica presente nelle prime pagine..
  9. #587
    Androidiano VIP L'avatar di Carlinho
    Feb 2011
    Samsung S8 Plus
    Ringraziato 264 volte in 185 Posts
    Non che non voglia fare la donazione di 3 sterline, ma se con il Toolkit così com'è posso almeno flashare la recovery twrp me li risparmio ! Praticamente ho il telefono in bootloop e non ho ne rom ne nandroid nel telefono ! Siccome ho un cavo OTG potrei flashare da USB, ma cwm non supporta tale procedura.
    Se non dovessi riuscire, devo riflashare la factory image ? Non perdo il root ?
    Sono in palla, confuso e ho perso parecchi passaggi ! Avevo già fatto una cazzata del genere e avevo risolto riflashando da toolkit, ma ora nello sconforto non ricordo una cippa ! Cosa mi serve per far ripartire il Nexus, oltre al Toolkit ?
    Ultima modifica di Carlinho; 05-06-13 alle 13:39
    ___________________________________________
    A sx del post c'è il tasto THANKS non FORMAT !
  10. #588
    Banned
    Quote Originariamente inviato da Carlinho Visualizza il messaggio
    Certo che si... vai anche con questa , oltre a quello che ti ho suggerito..
    Ultima modifica di Gynlemon; 05-06-13 alle 13:44
  11. #589
    Feb 2011
    Samsung S8 Plus
    Quello che mi hai detto in pm allora si può fare anche senza donazione ?
  12. #590
    Banned
    Certo .. però visto che ci sei puoi anche scaricarti questo..
  13. Il seguente Utente ha ringraziato Gynlemon per il post:
    Carlinho (05-06-13)
