Pagina 88 di 207 primaprima ... 3878868788899098138188 ... ultimoultimo
Visualizzazione dei risultati da 871 a 880 su 2063
[ROM] [4.2.2] Purity | AOSP JDQ39
  1. #871
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    R: [ROM][JB 4.2] Pure AOSP JOP40D - build04 - mod - bugless
    Quote Originariamente inviato da Hexo07 Visualizza il messaggio
    What do you think... When you will release the next Purity?
    Gesendet von meinem Galaxy Nexus mit Tapatalk 2
    Quote Originariamente inviato da DariosF Visualizza il messaggio
    Soon...Now i'm trying to build rom with gcc 4.7 and some linaro patches...
    Mai provata perché ho il gnex da poco, ma tutti i giudizi sembrano eccezionali!! :thumbup:
    Tapatalkeggiato
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    ci siamo quasi
    Final Purity v5 Changelog...Stay tuned
    Build:
    - Updated code to 4.2.2
    Framework_Base:
    - Revert to cm navbar settings
    - QuickSettings: Honors config_show_cmIMESwitcher setting (1/2)
    - Remove log noise
    - SystemUI: Fix QuickSetting IME tile
    - BrightnessTile : Cleanup controller references
    - Framework: Fix Brightness Tile
    - QuickSettings: Add LTE Tile (1 of 2)
    - SystemUI : QuickSettings Cleanup
    - SystemUI: allow update Mobile Network Type tile display
    - AudioService: allow volume control on analog dock
    - SystemUI: Avoid "phantom" status bar collapsing
    - Bugfix : Quick pulldown sometimes flips when it should not
    - Remove duplicate if statement
    - Make sure we're using an up-to-date disable state when we're reloaded.
    - Services: Adding HSPAP info in Android
    - Fix starting window memory leak
    - Audio continue to played even if paused manually
    - FIX Null Pointer Exception on dialog cancel
    - bootanimation: performance/speedup enhancements
    - policy: always use hardware acceleration for keyguard
    - Lockscreen Targets: Icon Revamp
    - Make system layout fill the window properly on expanded desktop mode
    LatinIME;
    - Revert to stock keyboard
    Settings:
    - Revert to stock cm navbar settings
    - QuickSettings: Honors config_show_cmIMESwitcher setting (2/2)
    - Settings: Add LTE Quick Settings Tile (2 of 2)
    - Quicksettings cleanup
    - Prevent cursor from causing global reference leaks.
    - Settings: fix dinamic tiles NPE
    - Settings: Lockscreen Targets Icon Revamp
    Vendor:
    - Updated Superuser.apk
    - New amazing bootanimation by Daniele Pavan
  4. I seguenti 2 Utenti hanno ringraziato Tex99 per il post:
    fcava (11-03-13),Kaoru01 (11-03-13)
  5. #873
    LG G6-H870DS
    Ringraziato 103 volte in 99 Posts
    ma sto LTE sarebbe?
  6. #874
    Quote Originariamente inviato da Kaoru01 Visualizza il messaggio
    ma sto LTE sarebbe?
    lte dovrebbe essere il 4g. in italia credo sia supportato per ora solo da vodafone e solo in 3 o 4 punti in tutta la penisola. come al solito sotto questo aspetto siamo i più arretrati. in america da una vita che ce l'hanno
  7. #875
    ma sto LTE sarebbe?
  8. #876
    LG G6-H870DS
    Quote Originariamente inviato da Tex99 Visualizza il messaggio
    ma tanto il nexus mica non lo supporta il 4g? xD
  9. #877
    Senior Droid L'avatar di pgr79
    May 2009
    Google LG Nexus 4
    No infatti..
    Google Galaxy Nexus
    EX Google Nexus S
    EX Google Nexus One
    EX Acer Liquid
    EX HTC G1 T-Mobile: Dwang v1.17.1
  10. #878
    Androidiano L'avatar di DariosF
    Apr 2011
    Galaxy Nexus
    Ringraziato 321 volte in 91 Posts
    Purity v5 online!
    Se apprezzi il mio lavoro, considera di effettuare una piccola donazione...:silly:
    Se ti sono stato d'aiuto, ringraziami con un THX :cyclops:
  11. I seguenti 9 Utenti hanno ringraziato DariosF per il post:
    6manu6 (11-03-13),AndreiVolk (11-03-13),Kaoru01 (11-03-13),KingVidal93 (11-03-13),KLAUSDROID (11-03-13),misterblonde (12-03-13),Pelide (11-03-13),Tex99 (11-03-13)
  12. #879
    LG G6-H870DS
    Quote Originariamente inviato da miseusegau Visualizza il messaggio
    Gia' in download....grande dariosF....
    inviato dallo zio....
    We zio te come kernelmi consigli il purity23? Ho letto che ddicevi che il 30 è peggio.
  13. #880
    Aug 2010
    Ringraziato 93 volte in 84 Posts
    spero di sbagliarmi ma.. non si può piu ridimensionare la navbar?
