Pagina 108 di 243 primaprima ... 85898106107108109110118158208 ... ultimoultimo
Visualizzazione dei risultati da 1,071 a 1,080 su 2425
KERNEL][4.2.x][4.3][4.4.x] Fancy Kernel
  1. #1071
    Abruzzo
    Galaxy Nexus
    Ringraziato 27 volte in 22 Posts
    Ragazzi pre 35 02
    http://boypetersen.de/fancykernel/tst/
    Inviato dal mio CyanoNexus usando Androidiani App
    GOOGLE GALAXY NEXUS
    Rom: CM 10.1
    Kernel: Fancy
    CPU: 1350Mhz
    GPU: 384Mhz
    GOOGLE GALAXY NEXUS
    TUTTO STOCK 4.3
  2. I seguenti 2 Utenti hanno ringraziato gnex per il post:
    fedelamb (09-07-13),Pelide (09-07-13)
    Ringraziato 43 volte in 33 Posts
    Ancora una nuova versione
    che ne pensate della zcache ?
    chi l'ha provata come la sente ?
    Hi again,
    I stated earlier that I was not convinced about the whole zcache thing. This has changed a 'little' now, since I have made two changes to get it running considerably better:
    1) I have increased the vfs_cache_pressure (to 120). Higher values will make more use of zcache. Thanks to mpokwsths for mentioning the adjusted settings by faux123.
    Note that the only setting affecting zcache on fancy kernel is vfs_cache_pressure. All of the other variables you can change in faux123's control app are non-effective here.
    2) I have updated the LZO compression library to the latest version. As zcache uses the LZO algorithm to compress and decompress, this will speed things up tremendously. In short, compression is approximately 1.75 times faster, decompression is more than 3.5 times faster.
    Check out these benchmarks.
    Link to the pre-release: http://boypetersen.de/fancykernel/ts...e35-02-ext.zip
    Best regards
  5. I seguenti 4 Utenti hanno ringraziato imthedoctor per il post:
    fedelamb (09-07-13),gnex (09-07-13),oleksandr (09-07-13),Pelide (09-07-13)
  6. #1073
    Senior Droid L'avatar di oleksandr
    Galaxy Nexus GSM
    Ringraziato 303 volte in 193 Posts
    Quote Originariamente inviato da imthedoctor Visualizza il messaggio
    Hi again,
    Best regards
    Io sto provando la per 35-01 e mi trovo una favola, oggi a fine ciclo metto la 02 per vedere la differenza, comunque mi sembra che con la zcache va un po meglio..
    on Stock 4.3 Rom with Fancy Kernel & ViPER4Android AudioEffect
  7. #1074
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da oleksandr Visualizza il messaggio
    io ho messo la 35-02 ora lo testo..
    ci sono impostazioni particolare per la zcache?
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  8. #1075
    Salve raga ha da tempo che sto seguendo questo kernel, e devo dire che in accoppiata alla SlimBean che utilizzo va davvero bene...consumi ottimi e prestazioni altissime..il problema però è che molto spesso ho dei sod :-( ..anche una volta al giorno...ho provato di tt, ho utilizzato la ext e la std ma niente, ho lasciato tt le impostazioni standard, ho provato a modificare i voltaggi ma nn cambia assolutamente niente...può essere che da questi problemi soltanto a me..?! Non credo...qualche soluzione..?
  9. #1076
    Senior Droid L'avatar di ciavarro
    Iphone x & Samsung s8
    Ringraziato 67 volte in 54 Posts
    Quote Originariamente inviato da fabioantonio99 Visualizza il messaggio
    Fai una piallata mettendo la stock e ripeti la procedura x rimettere la slim ed il kernel.a me gira benissimo
  10. #1077
    Sep 2010
    ROMA
    io uso i settaggi in seconda pagina e mai avuto sod
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. #1078
    Abruzzo
    Galaxy Nexus
    GOOGLE GALAXY NEXUS
    TUTTO STOCK 4.3
  12. Il seguente Utente ha ringraziato gnex per il post:
    fedelamb (09-07-13)
  13. #1079
    Sep 2010
    ROMA
    Quote Originariamente inviato da gnex Visualizza il messaggio
    dooooo !!
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  14. #1080
    Androidiano VIP L'avatar di fedelamb
    Ancona
    Honor 8
    Ringraziato 736 volte in 610 Posts
    Ma da quel che leggo su xda sta dando a molti dei problemi …
    Sorry for the defective file... I re-uploaded and tested it. works good. > Boype
    Ultima modifica di fedelamb; 09-07-13 alle 21:17
