Pagina 16 di 18 primaprima ... 61415161718 ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 173
[ROM][4.2.2]BeanStalk
  1. #151
    Androidiano L'avatar di astro1980
    ora posso aggiornare felice a 4.3
    Androidiano VIP L'avatar di fedelamb
    Ancona
    Honor 8
    Ringraziato 736 volte in 610 Posts
    Nuova Build !!
    BeanStalk4.3.1001 - 03/10/2013
    * Merged in the lastest Android 4.3_r3 source code
    * Fixed gapps services fc'ing. Was due to a shady commit.
    * Added device partition information (settings - storage - partitions)
    * Added back external bluetooth GPS support.
    * Added Halo mods.
    * Updated busy dialog animation.
    * Updated how busy dialog information is shown.
    * Rework thumbnail handling
    * Notification long press fix
    * DockAudio: Route audio via dock for Samsung devices
    * Updates to BeanStalk Explorer.
    * Numerous fixes and improvements throughout the build.
    Downloaf---> BeanStalk-4.3.1001-20131002-maguro
  4. Il seguente Utente ha ringraziato fedelamb per il post:
    morfances (04-10-13)
  5. #153
    Baby Droid L'avatar di nexus88gm
    Messina
    Google Galaxy Nexus
    Splendida rom la consiglio a tutti... Ottima anche con Kernel Mpokang v9
  6. #154
    Androidiano VIP L'avatar di erghetto
    Napoli
    Galaxy S6 Flat SM-G920F
    Ringraziato 385 volte in 344 Posts
    ragazzi tra poco arriva una nuova versione. questo il changelog preso da xda:
    BeanStalk 4.3.1009 - 10/16/2013
    * Fixed call log info issue not responding issue
    * Added OTA support for all beanstalk builds that upload to the main Goo.im Downloads - Browsing beanstalk account.
    - OTA wont be available until the next update since this is the first build with the ota support added.
    * Added Thinking bridge traffic meter
    * Major Overhaul to privacy guard and layout changes. All credit to slim
    * Network color preference options. Thanks carbon
    * Keypad shuffler option. for ultra high security.
    * add never sleep screen mode
    * Added performance profiles
    * Merged android-4.3.1_r1 sources
    * Add support for FM feature
    * More cleanup/fixes for Active Display
    * Reverted a bunch of questionable commits. Should be more stable.
    * Huge thanks to Vaughn for compiling the infuse beanstalk build for tonights release. Make sure you thank him if you see him on the threads at all.
    [Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
    [ROM] Noble Nougat Experience 4.5
    [kernel] Kiboi kernel 2.5
  7. Il seguente Utente ha ringraziato erghetto per il post:
    fedelamb (18-10-13)
  8. #155
    Napoli
    è fantastica!!!
    veloce, reattiva, molte personalizzazioni!
    veramente ben fatta!
  9. #156
    Napoli
    ragazzi per caso qualcuno di voi ha ancora la BeanStalk 4.3.1009?
    su goo.im non c'è più e l'ultima nn voglio metterla. in halo non va il floating mode ma il multiwindow che odio
  10. #157
    macijeep
    Dev-Host - BeanStalk-4.4.200-20131219-maguro.zip - The Ultimate Free File Hosting / File Sharing Service
    Changelog preso da XDA:
    BeanStalk Kit Kat 4.4.200 - 12/19/2013
    * Upstream Android 4.4.2
    * Fixed variable lock pattern issue. Works as it should now.
    * Add lockscreen rotation as an optional rotation setting
    * Forward ported power widgets - located in quicksettings and notification drawer menu.
    * Ported fixes and additional power widgets
    * Option to set active/inactive colors for power widgets
    * Option to set headset to launch voice commands
    * Allow to disable quicksettings completely
    * fix for screenshot animation glitch in portrait
    * new busy dlg animation from skyliner
    * Quicksettings fliptile when clicking a tile
    * AudioEffect: Add a stereo widener effect
    * AudioFX: Add center frequency param to bassboost
    * update icons and remove cm specific icons.
    * allow disabling call end sound
    * QS: make dynamic tiles configurable
    * Custom lockscreen handle
    * Beanstalk shortcut options (this is all slims work, just renamed to beanstalk)
    * Custom carrier label
    * Added brightness slider (swipe status bar to control brightness when enabled)
    * Updated density changer to set density on the fly. No longer requires a reboot!
    * Wake on connect/disconnect option
    Io la sto usando e mi sembra ottima
    Ultima modifica di macijeep; 22-12-13 alle 23:04
  11. #158
    macijeep
    Dopo averle provate tutte le versioni K.K. devo dire che questa rom e' FANTASTICA. E' da due giorni che gira perfettamente e non ci penso neanche a toglierla
  12. #159
    Ringraziato 135 volte in 125 Posts
    EDIT sbagliato
  13. #160
    Quote Originariamente inviato da macijeep Visualizza il messaggio
    basta fleshare solo la rom?
    le gapps non sono presenti?
