Pagina 29 di 35 primaprima ... 192728293031 ... ultimoultimo
Visualizzazione dei risultati da 281 a 290 su 350
[ROM][KK - 4.4.x][HALO][PIE][Wifi Display]CM-REMIX-Burst-Kernel-KANG
  1. #281
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    New build is up!!!
    Download
    4th May 2014 - ver 2.9.2
    1. Built with Linaro and qcom bionic optimization. ! fasten your seat belt!
    - Thx to vanir team fixes and LiquidSmooth team modification on build system.
    2. Wallpapercropper fix with gif and bmp (aosp)
    3. Hardware Key binding : Fix Long Press Action when screen is off
    4. On the go mode (Nameless Rom)
    - handle display orientation changes
    - multiuser awared
    5. [add force multi pane switch for Settings (NamelessRom)
    6. Fix Remove Notification Logics with Halo and ActiveDisplay
    7. Custom Color settings to statusbar icon (airplane mode, data, wifi, volume)
    8. PA Peek & custom timout tweak (crdroid)
    note: it is in preliminary stage, really a peek, only display once within timout after new notification comes.
    9. Tiles:
    - battery tile : open up setting thread directly with long click
    - TimeOut Tile : long click action to stay awake
    10. OmniSwitch
    - add quick switcher
    11. Add default value for display color control (CM)
    12. QuickContact: onLongClick save item data to clipboard
    13. Switch to Performance Control by Omni (/w carbon rom mod)
    - less buggy and stable.
    14. Driving Mode under accessibility option (Omni)
    Ultima modifica di morfances; 05-05-14 alle 00:04
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. I seguenti 3 Utenti hanno ringraziato morfances per il post:
    Giovan (04-05-14),LuCiolla90 (05-05-14),vismo (05-05-14)
    Senior Droid L'avatar di Giovan
    Ringraziato 57 volte in 50 Posts
    Ma il peek era già presente nella build precedente??ve lo chiedo perchè mi è comparso 2 volte....pensavo che era per volpa del vino...
  5. #283
    Sep 2010
    ROMA
    2.9.3 coming soon----
    versione di test
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  6. #284
    Sep 2010
    ROMA
    versione di test
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #285
    Morfances da dove salta fuori questo aggiornamento?sul sito di xda non c è
  8. #286
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    Giusto...non è in OP ma bisogna andare negli ultimi post del 3d del sito XDA per trovarlo...
    Edit: post 1427
    Ultima modifica di dado70; 09-05-14 alle 23:30
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  9. #287
    L ho installata e non trovo nessuna differenza con quella precedente e nelle info del telefono mi da sempre la 2.9.2 invece della 2.9.3.anche a voi ?
    Edit:
    Ho trovato un bag MOLTO fastidioso ...quando parlo al telefono (sia se chiamo o ricevo) si sente il famoso bip di quando c è una chiamata in attesa e non intende svanire se non al termine della chiamata.
    Rimetto il backup che è meglio )
    Ultima modifica di Giovan; 10-05-14 alle 00:52
  10. #288
    Sep 2010
    ROMA
    New build is up!!
    13th May 2014 - ver 2.9.3
    1. odex optimization and Enable PLD prefetch support and 32 bit cacheline flag
    - even smoother and speed up response/startup time
    2. Tiles :
    - hidden Fcharge Tile if not support by kernel
    - port WeatherTile (Dokdo Project, GwonHyeok)
    - CPUFreq Tile (PAC.... oops... it need fixing on writing settings)
    - port Equalizer Tile to dynamic tiles system (it show when you play media)
    3. PowerMenu
    - Add Mobile Data Toggle
    4. Notification Contextual header (Omni)
    5. DocumentUI (Evisceration)
    - display external storage by default
    - support apk installation
    6. Halo (CRDroid)
    - allow notification open in floating window or not
    7 . Fix Notification Setting buttons intent
    8. Allow showing second with Clock (Dokdo Project)
    9. Slim Recents
    - fix floating window mode
    - add development shortcut (lion0738)
    10. PA Pie : memory leak fixing and multi user aware.
    11. AppCircleSideBar
    - Custom TriggerWidth
    - add back simple floating window mode
    12. fix Carrier Label force showing up on boot (Vanir)
    13. Store dialpad showing state (PA)
    14. Settings:
    - development tools: add animation scale util (cm)
    - remove useless mobile plan (cm)
    - Add default value for display color control (cm)
    Download
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. #289
    Flashata la 2.9.3 ed ho riscontrato un bug...se si cerca di far scendere la tendina delle notifiche si impalla e scompaiono anche i tasti di navigazione...ho ovviato a questo problema attivando i "tile"( li trovo inutili per come ho settato il mio nexus) e cosi si abbassa regolarmente...ps ma sono rimasto solo io ad installare la miglior rom per nexus? )
  12. #290
    Forlimpopoli (FC)
    Quote Originariamente inviato da Giovan Visualizza il messaggio
    Anche a me succede qualcosa del genere, un bug penso, specialmente quando smanetto con la tendina delle notifiche...spariscono sia statusbar che navbar per un secondo e poi torna tutto normale.....per tile cosa intendi, scorciatoie per abbassare la tendina notifiche?
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
