Pagina 31 di 35 primaprima ... 212930313233 ... ultimoultimo
Visualizzazione dei risultati da 301 a 310 su 350
[ROM][KK - 4.4.x][HALO][PIE][Wifi Display]CM-REMIX-Burst-Kernel-KANG
  1. #301
    May 2014
    grazie comunque
    Senior Droid L'avatar di Giovan
    Ringraziato 57 volte in 50 Posts
    Coming coming....ma quando?
    Inviato dal mio immortale Galaxy Nexus
  4. #303
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da Giovan Visualizza il messaggio
    Uscita 2.9.4
    1. Kernel (beta 2)
    - dm cyrpt update (cm)
    - bfq v7r2 (remove for lockups found)
    - TripnDroid IO
    - cfq tunable tweaks (DirtyV)
    2. Squisher script support.
    png optimized and downsize by ripping off voicedialer and videoeditor
    3. Xposed Framework hook rework
    user experience issue whenever the app get update, so I dropped them by default and user please install it manually.
    Once they are installed, xposed thread will shown up in settings menu
    4. Wifi Display add sink and listen support (vanir)
    5. QuickSettings:
    - add back screencast tile
    - port CM quickaccess ribbon (LiquidSmooth)
    - Pimp-up QuickRecord Tile (slim)
    6. Halo : bug fix
    - match kitkat icon style
    - no notification left, but swiping halo still launchs app after tasking
    - halo button animations don't need to be processed if it's not enabled
    - fix partial flip animation with halo button
    7. Denisty Changer : swich to on the fly mode (slim)
    now it is controlled by different sets of build properties, we should get rid of play store incompatible issue
    8. Peek
    - Peek wake timeout
    - code update from PA upstream
    9. Shake Events to Gesture lab and security (slim)
    Shake to lauch action / program in keyguard and unlock.
    10. Floating mode enhancement
    - Enable Transpatent layer to Appcirclesidebar and recent panel
    11. Add CPU boosting hooks to scrolling function
    12. Allow All Widgets On Keyguard (slim)
    13. New Theme Engine ( CM )
    noted : lockscreen wallpaper color filled function removed to retain compatibility.
    Wallpaper cropper is not function at this moment
    Ultima modifica di morfances; 25-05-14 alle 20:26
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  5. Il seguente Utente ha ringraziato morfances per il post:
    LuCiolla90 (23-05-14)
  6. #304
    Uscita 2.9.4...prime impressioni sono felice della possibilità adesso di impostare il proprio pacchetto icone come predefinite del sistema.un bug che riscontro dalla versione precedente e che ancora non é stato risolto é quello che se si disattivano i tite della barra delle notifiche, qest'ultima se si prova a farla scendere crasha e si riavvia ....cosi all infinito.
  7. #305
    Senior Droid L'avatar di dado70
    Forlimpopoli (FC)
    GNex, Nexus 5, Nexus 5X, RN5..
    Ringraziato 73 volte in 65 Posts
    Ah si', ancora quel bug, uffa...a me con la 2.9.3 mi continuava anche ad apparire il nome operatore in barra..okkey poi in Impo lo si toglie ma anche il crash dei tiles è una vera scocciatura uff...
    ROM
    Recovery
    [TWRP]
    Kernel
    Launcher
  8. #306
    Si è vero...anche a me dava e da il problema della comparsa del nome operatore anche quando lo si disabilita...
  9. #307
    Sep 2010
    ROMA
    2.9.4 build 2
    by burstlam
    "I have remove several bionic changes and pld 32 optiimization pick from vanir commits
    it looks to me they are not playing well with 4.9.1 toolchain."
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  10. #308
    Cosa sarebbe morfances?
  11. #309
    Sep 2010
    ROMA
    Piccolo update xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. #310
    Si l avevo intuito ma non sai cosa va a migliorare? Io cmq già l ho fleshato ma non vedo cambiamenti alla già ottima rom.
