Pagina 6 di 11 primaprima ... 45678 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 103
[ROM][KK- 4.4.x][AOSB] Maguro
  1. #51
    Senior Droid L'avatar di pablomoreno
    Ringraziato 108 volte in 101 Posts
    New build:
    aosb_kk_1.3.3_maguro
    Base: PA PEEK Notification
    Base: PA PEEK wake timeout && configurable timeout
    Base: SmoothProgressBar: update to v0.4.0
    Base: Volumepanel: always show option icon
    Base: Fix STE "OK Google"
    Base: Add support for multiple storage configurations
    Base: UserTile: Fix SystemUI force close
    Base: Launch floating notifications from notification panel (long click)
    Base: Fix setup wizards force close
    Base: Download: add to support pause/resume download by manual
    Base: fonts: Add LBha****aComplexSans font for Sinhala
    Active display huge bug fixes
    Active display douple tab to sleep
    Active display limit notifications
    Active display bypass, pocket and sunlight mods
    Base: Fix SystemUI because Activedisplay
    Base: Squash: Memory leaks, NPEs, races and optimizations for fw/base
    Base: fix LTE toggle
    Base: On-The-Go: Turn stop and start service if screen turns off and on
    Base: On-The-Go: Toggle flashlight when shaking
    Base: Battery saver mode updates
    Vendor: update App Settings to latest version (1.9)
    Vendor: update Xposed Installer to latest version (2.6.1)
    DSPManager: add boeffla sound control! (AOSB kernel support boeffla)
    AOSB Recents: Launch as Floating App
    AOSB Recents: Fix the memory leak and more
    AOSB Recents: reduce memory usage
    AOSB Recents: Improvement thumbnail size also on landscape mode
    AOSB Recents: Attach the default thumbnail size for solutions not conflict with slim recents
    AOSB Recents: Fix possible crash
    ThemeEngine: New CM Theme Engine
    ThemeEngine: Add new themes items to personalization menu
    ThemeEngine: Lockscreen custom wallpaper
    ThemeEngine: add Custom Lockscreen switch
    ThemeEngine: Add wallpaper pickers to seperate package
    Settings: enable QuickBoot Settings UI
    Settings: Add blacklist provider permission
    Settings: On-The-Go Tile
    Settings: PEEK wake timeout
    Settings: detect if device support for Proximity/Gyroscope sensor
    Settings: PEEK configurable pickup timeout
    Settings: Don't Hide navigation bar category
    Settings: Peek wake timeout
    Settings: Add Slim Recents Warning
    Settings: Add option to enable/disable navring
    Settings: Navigation bar width & height
    Settings: Add navbar enablement for hw key devices
    Settings: Mirroring layout on RTL languages
    Settings: Add screen color settings
    Settings: Wifi :: Add support for Ad-hoc (IBSS) networks
    Settings: Fix VoiceWakeup settings crash
    Settings: Show "Eject card" for usb storage
    Settings: Display BTH connected status correctly
    Settings: Apply Processor settings to all cpus
    Settings: Increase allowed duration to connect to a profile
    Settings: Fixes error message during pairing of HOGP devices
    Settings: Add missing mdpi, hdpi, xhdpi drawables for new theme engine
    Settings: Accept all files" option for incoming files via Bluetooth
    Settings: add equalizer tile toggle
    Settings: PowerMenu :: On-The-Go Mode
    Settings: Option to enable Notification Light when screen is on
    Settings: Pumping missing icons mdpi, hdpi, xhdpi drawables for AOSB
    Settings: Follow Xposed 2.6.x
    Mms: QuickMessagePopup: pager fix on multiple messages.
    Mms: Implement SMS mark for unread
    Mms: Enable link to Cell broadcast activity forcibly
    Bluetooth: Release pan proxy object while coming out from tethering menu
    Bluetooth: Improve sending web link with Bluetooth
    Bluetooth: Fix crash when sending SMS from handset instead of MAP
    Bluetooth: add "Accept all files" option for incoming files via Bluetooth
    Dialer: Landscape support
    Dialer (MSIM): display all IMEI/MEID for *#06#
    Dialer: Add support for OpenCNAM paid accounts
    Dialer: restore full compatibility with theme chooser
    LockClock: do not use GPS if Play Services is available
    Camera2: Fix camera application memory leak
    Camera2: Fix default slow shutter option
    Camera2: Prevent autofocus when video snapshot is in progress
    Camera2: Disable ZSL for slow shutter shots
    Camera2: Add 50MP, 37.5MP resolution entry
    Camera: Fix JPEG quality DB update
    DeskClock: Add feature to play random song as an alarm.
    DeskClock: Support double-digit hours for timers
    Kerneltweaker: Add TRDS (Dark-UI)
    Kerneltweaker: add Power key suspend/Wake Timeout option
    Kerneltweaker: MSM Mpdecision Control
    Apollo: Avoid crash when attempting to load many items
    Apollo: Use correct preference keys for artwork download
    Telephony:Fix MSIM Network Settings
    Telephony:Reform toggleLTE is required in order for CM
    Telephony: Fix network selection array
    Telephony:actually fix LTE toggle
    Telephony:Fix crash in network mode settings
    Telephony:Fix mounting of ext4 formated sdcards
    Torch: toggle on/off once
    update Trebuchet , CMFileManager
    Samsung devices: add another camera firmware binary
    Fix Etisalat UAE, TalkTalk,QUAM APNs
  2. Il seguente Utente ha ringraziato pablomoreno per il post:
    morfances (03-06-14)
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Installata!!!provatela ragazzi!!!
    Aggiornata OP!!
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  5. #53
    Sep 2010
    ROMA
    AOSB 1.3.4 with 4.4.3 is Out!!
    DOWNLOAD
    Merge tag 'android-4.4.3_r1.1' #KTU84L
    Merge CM changes
    Battery consumption's issues fixed
    Stability issues patched
    Minor Dialer app redesign
    The Dialer app has a light color scheme instead of dark.
    rearrange contact cards in the Dialer.
    FLAC playback improved/fixed
    improved camera quality
    New Contacts , icons , ...
    Performance improvement is incredible
    Fix resource leaks
    Fix hiding ADB notification
    Excessive battery drain issue
    more compatible with high resolution devices
    apn: national roaming for ONO (Spain)
    Settings: Import init.d.cfg and fix "fi unexpected"
    Enable KSM deferred timer for kernels supporting it
    Telephony: Add setting for WhitePages Canada reverse lookup provider
    Telephony: Add setting for YellowPages Canada reverse lookup provider
    pause downloads of large games from the Play Store
    appops: enforce appop for bluetooth disabled action
    Ultima modifica di morfances; 07-06-14 alle 10:23
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  6. Il seguente Utente ha ringraziato morfances per il post:
    fabris3 (06-06-14)
  7. #54
    Senior Droid L'avatar di vismo
    LG G3
    Ringraziato 166 volte in 146 Posts
    Morf come va la rom? L'ho appena messa in download... Domani penso di provarla...
  8. #55
    Sep 2010
    ROMA
    Quote Originariamente inviato da vismo Visualizza il messaggio
    io ho fatto l'aggiornamento dalla 1.3.3 e andava male : non riuscivo a fare le telefonate ne a riceverle
    prova a fare l'installazione pulita e fammi sapere : ho parlato col dev e questi problemi non ci dovrebbero essere xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. #56
    LG G3
    Ciao morf...l'ho installata qualche ora fa...installazione pulita...va tutto bene tranne la gestione del led di notifica...vediamo come va col passare del tempo...
  10. Il seguente Utente ha ringraziato vismo per il post:
    morfances (08-06-14)
  11. #57
    Sep 2010
    ROMA
    ok allora riprovo XD
    che launcher usi?
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. #58
    LG G3
    Quote Originariamente inviato da morfances Visualizza il messaggio
    che launcher usi?
    Nova
    Ma hai risolto il problema dei led? Mi farebbe comodo usare un colore diverso per gli SMS e sono gli unici che devo impostare fuori dal programma...
  13. #59
    Sep 2010
    ROMA
    Nova
    no,credo sia un bug .
    l'hanno segnalato anche su xda..nella precedente versione funzionava
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  14. #60
    LG G3
    Ok... Speriamo che lo risolvano... A me ha fatto qualche errore la ui... Ma in fondo si sta comportando bene.... Vediamo come si comporta a batteria...
    Ah... Volevo dirti che secondo me ti conviene cambiare il titolo della discussione ed aggiungere la versione Android... Vedrai quanta gente scriverà
