Se il primo screenshot è la bootanimation, mi piace!
La preleverò per la mia rom attuale!![]()
Nexus 6--> NitrogenOS 7.1 /f2fs
GNEX--> [GNEX unified] OMNI 4.4.4 - cMetal ext4/f2fs NautyTRASP.
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
Ce l'ho su da una settimana e devo dire che mi trovo davvero bene.. l'ho messa su al posto della PA e sono veramente soddisfatto.. A parte qualche perdita di segnale un po' insolita e qualche crash della ui mi ci trovo molto bene..
Ed ecco a voi la tanto attesa build 4.4.4 per la AOSB
AOSB KitKat v1.3.6
Android Kitkat 4.4.4r1 KTU84P
Merge CM Changes
Update SuperSu to v2.00
New Bootanimation
Base: iOS8, Bubble Recentes
Bubble: re-work the activities
Bubble: Fix NPE Fully and validate Contact ID/Image
Bubble: check caller name if empty && calculate time duration
Bubble: Make it optional
Recent: Make it compatible with Holo Dark and Multi DPI
Recent: Support landscape layout
FastChargeTile: support m8
Base: FastCharge & Touchpad Tile kernel feature toggle
Base: Sleep Timer for Media Tile
Base: Allow Power Notification Sounds For Wireless
Base: Notification Reminder
Base: Notification Reminder Interval
Base: Notification Reminder New layout
Themes: Use default_wallpaper for HOLO lockscreen wp
Themes: Use first asset entry for lockscreen wallpaper
PEEK: Sensors improvements
HOVER: Option to exclude topmost app
HOVER: notification timeout
HOVER: New Settings
HOVER: Improvements
HOVER: Match notification width on tablets too
HOVER: Theme Engine compatibilities
Settings: add lockscreen themes in interface
Settings: Pimp Custom Recent and Bubble Settings
Settings: HTC Reflection Effect or iOS Flat
Settings: Glowpad Torch
Settings: Partition information menu
Settings: Lockscreen Colors/Image
Settings: Remove ‘More device settings’ menu
Settings: Remove lockscreen slide delay option
dlx: update adreno from qdevnet 24 June 14 KOT49H
m8: add EasyAccessService
m7vzw: update blobs from 4.10.605.3
m7: Update proprietary files from Google Play edition
toroplus: add blobs
galaxysl: add blobs
d801: Enforce known good ADSP images
mako: Remove live wallpaper product entries
mako: Remove libacdbloader makefile entry
gapps Consigliate
Bootanimation flashable
Ultima modifica di morfances; 30-06-14 alle 13:19
Oneplus 9
Oneplus 5 6/64
Nexus 5
la bootanimation è praticamente solo una scritta AOSB un po' animata...non è quella che pensavo....
Prova la rom e dicci!![]()
Oneplus 9
Oneplus 5 6/64
Nexus 5
Ma non ha il PIEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE uff.....![]()
ROM
Recovery
[TWRP]
Kernel
Launcher
Oneplus 9
Oneplus 5 6/64
Nexus 5
