Ogni gnex é diverso... Posso dire esattamente il contrario :nessun caso, nessun problema con hover xD
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
Io mi trovavo meglio con RR più dfk... Avevo più della metà della ram libera.
Ogni gnex é diverso... Posso dire esattamente il contrario :nessun caso, nessun problema con hover xD[/QUOTE]
Ti quoto in pieno..
Cmq vediamo tra qualche giorno... Diamo un po di tempo per assestarla.
Se ti sono stato di aiuto clicca il pollice in su che si trova in basso a sinistra del mio post!
New build is out!!!
TREX -maguro 25.06.2014
android_frameworks_base
-PackageManager: Fix Service WTF in systemReady()
-PackageManager: Fix logic around upgrading text display
-settings: Enable the status bar double-tap to sleep gesture
-Themes: Use INSTALL_LOCATION_INTERNAL_ONLY for legacy icon packs
-Floating window with Multitasking w AppCircleSideBar [1/3] Patch 10
-Implement App circle sidebar [2/3] Patch 10
-properly check that quickboot is enabled
-Implement DocumentsProvider.createDocument and deleteDocument
-StatusBarView: Ensure to not overload in/out animations
-StatusBarView: Avoid unnecessary calls to mHandler.post()
-ExpandHelper: Improve one finger expanding forced handling
-HOVER: Match notification width on tablets too
-HOVER: Ensure to clear after reparenting all notifications
-HOVER: Fix notification content not being updated
-don't show global actions if shutdown sequence was started
-accounts: don't remove accounts while device is in safe mode
-Show notification on adb over network too
-Fix frontOfTask assignment.
-Theme IME switcher alert dialog
-Keyguard: force marquee effect for carrier text
-Keyguard: fix NPE setting lockscreen wallpaper
-Activity chooser "Always" button is not working
-Wifi: Use bss ->age identifier for wifi scan results
-MountService: Handle UUID in list response
-PackageManager: Add option for single threaded dexopt
-Fix Build
android_build
-Update supported languages
* Remove Uyghur, which has no active maintainer in the past 6 months
* Add Kurdish
-Switch to arm-eabi 4.10 (Kernel) for Hammerhead
android_device_samsung_tuna
-Target Custom GCC Chains (LINARO/4.9.1-2014.06)
android_packages_apps_Settings
-Settings: remove auto_brightness_adjustment_title string
-DisplaySettings: Add hardware-framework support for color enhancement
-Settings: Fix build
TREX_Settings
-Implement App circle sidebar [2/2] Patch 12
*Add whitelist app to include
*Add Trigger region control
android_packages_apps_Contacts
-quickcontact: fallback to default secondary action drawable
*If the resource package doesn't have a valid resource drawable, then fallback to default drawable.
Oneplus 9
Oneplus 5 6/64
Nexus 5
Oneplus 9
Oneplus 5 6/64
Nexus 5
Oneplus 9
Oneplus 5 6/64
Nexus 5
Scusate l'ot e l'ignoranza... Ma voi pensate che usciranno delle rom con Android L prossimamente?
Ultima modifica di Nautiluz; 26-06-14 alle 18:29
Nexus 6--> NitrogenOS 7.1 /f2fs
GNEX--> [GNEX unified] OMNI 4.4.4 - cMetal ext4/f2fs NautyTRASP.
