Pagina 72 di 93 primaprima ... 2262707172737482 ... ultimoultimo
Visualizzazione dei risultati da 711 a 720 su 925
[ROM][4.3][Linaro] ♦ PURITY ♦
  1. #711
    Androidiano L'avatar di alcemaschio
    May 2010
    Ravenna
    liquid, dhd,gnexus,nexus4
    Molte bene. Allora aspetto l'ultimo rilascio di Dario e poi la provo. (spero presto) grazie ciao
    ROM: ???
    KERNEL: ???
    Sep 2010
    LG G4 h815
    Ringraziato 53 volte in 43 Posts
    Nuova versione, dovrebbe essere l'ultima 4.3:
    # Purity # 23/10
    Build:
    - O3 thumb_CFLAGS
    Dalvik:
    - vm: fix extraneous parentheses warnings
    - Fix Class.getDeclaringClass bug
    External_chromium:
    - base: fix c++11 narrowing …
    - net: fix preconnect memory leak …
    - net: networking optimizations
    External_clang:
    - Correct build when using grep with coloured output …
    - clang: add support for neon-vfp instructions
    External_llvm:
    - llvm: Add workaround for STLport not being a full C++11 STL
    External_skia:
    - Don't use ISO C++11 constructs in code when building in C++98 mode
    - Neon optimized implementation of S16_opaque_D32_nofilter_DX
    External_v8:
    - libv8: set unused attribute for unused parameters …
    - v8: Fix build in ISO C++ 11 mode
    External_webkit:
    - webkit: workaround incompatible operand types …
    - Fix the problem that m_url is not renewed in WebRequest:nReceivedRe…
    Frameworks_av:
    - libvideoeditor: fix M4OSA_Clock header guard
    Frameworks_base:
    - Fragement, or Fragment: that is the question …
    - Fix App Ops permission mapping structure. …
    - core: fix arithmetic on a pointer to void …
    - interrupter: Use LOCAL_LDLIBS rather than LOCAL_LDFLAGS …
    - Revert "frameworks: Make Spinner widget request the itemtype of the a…
    - Fix various c++11 narrowing violations …
    - Add new permission and API in TelephonyManager to protect the APN …
    - Removed duplicate items on table of contents …
    - Fixed Drag-and-Drop sample code …
    - remove unnecessary switchUser call …
    - improving translation …
    - Fixes a typo. …
    - Update preloaded-classes …
    - Forward compatibility fix …
    - Forward compatibility fixes …
    - Remove ArpPeer; dead code from Google TV.
    - Fix a programmatic smooth scroll bug …
    - aapt: set interlace handling for png_read_update_info …
    - FastScroller: Fix to use appropriate index …
    - onSavePassword dialog can leak when WebViewClassic is destroyed. …
    - Fix for the low processes kept bug
    Frameworks_compile_mclinker:
    - Remove obsolete code. …
    Frameworks_native:
    - Fix
    - binder: fix c++11 narrowing violations
    Frameworks_opt_telephony:
    - If telephony wants ASCII casing, it needs to ask for it. …
    - Add permission and new API in TelephonyManager to protect the APN set…
    Hardware_qcom_media:
    - mm-video: fix arithmetic on a pointer to void
    Latinime:
    - Use aosp latinime as default
    Mms:
    - Mms: reimport translation …
    System_core:
    - Fix build with gcc-4.8 and array boundaries issue …
    - fix valgrind ioctl warning. …
  4. Il seguente Utente ha ringraziato maxdelay per il post:
    Tex99 (24-10-13)
  5. #713
    Androidiano L'avatar di asgard96
    Per aggiornare con l'ultima versione bastano i canonici wipe cache/dalvik?
  6. #714
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    Quote Originariamente inviato da asgard96 Visualizza il messaggio
    Wipe cache wipe dalvik format system flash ROM flash gapps flash supersu
  7. Il seguente Utente ha ringraziato Tex99 per il post:
    asgard96 (24-10-13)
  8. #715
    Solo a me non funziona light flow con questa Rom? Con le altre tutto sempre perfetto, ma quando metto la purity nulla.. C'è qualcuno che riesce a farla funzionare?
  9. #716
    Sep 2010
    LG G4 h815
    Va senza problemi.
  10. #717
    Mi diresti quali campi hai spuntato nella sezione del led nelle impostazioni del sistema? (Impostazioni->display->luce di notifica pulsante)
  11. #718
    perchè quando clicco sul link photosphere in prima pagina mi si apre il sito della slim bean?
  12. #719
    Quote Originariamente inviato da cicco87 Visualizza il messaggio
    sulla purity si possono installare varie gapps e le consigliate sono o le pa gapps o le slim ( con quest'ultime otterrai piena compatibilità con la funziona dark ui e ci saranno più app "dark") se metti le slim minimal gapps il photosphere non è compreso ma c'è un addon che puoi installare in seguito per ottenere tale funzione
  13. Il seguente Utente ha ringraziato Tex99 per il post:
    cicco87 (25-10-13)
  14. #720
    Androidiano L'avatar di topogino
    Dopo il flash dell ultima ROM ho problemi di accesso al mio account google soluzioni???
    inviato dal mio nokia 3310
